lieres
July 29, 2020, 1:52pm
1
Yiran Wang from BMS (Yiran.Wang@bms.com ) has reported a problem with this
simulation on CADET-WEB. The error message reads:
cadet-cs: error while loading shared libraries: libhdf5_cpp.so.11: cannot open shared object file: No such file or directory
Can someone please check the server setup?
Thanks
Eric
cadet 2.x looks like it is broken on the server. That version can only be selected after clicking on advanced. I will look at just removing the option to run cadet 2.x.
lieres
July 30, 2020, 2:58pm
3
Thank you Bill. The example indeed runs with version 3. Do you recall why we intruduced the option to choose between different simulator versions?
At the time this was written cadet 3 was new I think.
lieres
August 2, 2020, 10:34am
5
Sure, but do you recall any reason for allowing to choose between different versions?
