Hi @j.schmoelder. I have experienced a problem trying to install cadet inside docker. So the problem is that the architecture of the publically available cadet-coredocker image is not compatible with the architecture of the docker. Or am I missing something? if yes, could you please mention the steps so that i can cross check if everything i did was right? Also how to install cadet python in the docker?
Hi and welcome to the Forum!
I don’t believe we have an official CADET Docker image (yet). Where did you get this from, if I may ask?
@ronald.jaepel is this maybe related to your recent activities?
I had made a dockerfile a while back to build a CADET-Process image and run a container locally for my own testing, I’ve copied it here for reference if it is helpful. If you want CADET-Python specifically you can change the pip install command accordingly.
You’ll also need the env.yaml in this case as well (also included below).
# Base image with Python 3.12
FROM python:3.12.7-slim
# Set working directory
WORKDIR /app
# Update and install essential tools
RUN apt-get update && apt-get install -y \
wget \
build-essential \
&& rm -rf /var/lib/apt/lists/*
# Download and install Miniforge
RUN wget https://github.com/conda-forge/miniforge/releases/latest/download/Miniforge3-Linux-x86_64.sh -O /tmp/miniforge.sh && \
bash /tmp/miniforge.sh -b -p /opt/conda && \
rm /tmp/miniforge.sh
# Add a cadet directory
RUN mkdir -p /opt/cadet
# Add Conda to PATH
ENV PATH="/opt/conda/bin:$PATH"
# Install mamba for faster package installation
RUN conda install mamba -n base -c conda-forge
# Copy environment.yaml to the container
COPY env.yaml /tmp/env.yaml
# Create the conda environment from the yaml file
RUN conda env create -f /tmp/env.yaml && \
conda clean -a && \
rm /tmp/env.yaml
# Install cadetmatch via pip
RUN pip install cadet-process
# Expose the working directory to interact with the CLI
VOLUME ["/app"]
# Default command: Open a shell for manual testing
CMD ["/bin/bash"]
channels:
- conda-forge
- defaults
- https://repo.anaconda.com/pkgs/main
- https://repo.anaconda.com/pkgs/r
- https://repo.anaconda.com/pkgs/msys2
dependencies:
- cadet
- pip
