Bi-Langmuir q-profiles
I am trying to capture the data on the solid phase concentrations for a case with A and B under various inlet conditions. I can produce plots for outlet concentration but I cannot work out how to get the data of q. My working code is:
#%% (A)
from CADETProcess.processModel import BiLangmuir
    Inlet, LumpedRateModelWithoutPores, Outlet
from CADETProcess.processModel import FlowSheet, Process
C_in = [[7.5, 7.5], [10, 10], [15, 15]]
c_store = []
q_store = []
for i in range(len(C_in)):
    # Bi-Langmuir binding model
    binding_model = BiLangmuir(component_system, n_binding_sites=2, name='langmuir')
    binding_model.adsorption_rate = [0.015, 0.03, 0.02, 0.035]
    binding_model.desorption_rate = [1, 1, 1, 1]
    binding_model.capacity = [100, 100, 100, 100]
    print('hi 1')
    # Column system
    feed.c = C_in[i]
    eluent.c = [0, 0]
    column.length = 0.6
    column.diameter = 0.024
    column.axial_dispersion = 4.7e-6
    column.total_porosity = 0.65
    column.solution_recorder.write_solution_bulk = True
    flow_sheet.add_unit(feed, feed_inlet=True)
    flow_sheet.add_unit(eluent, eluent_inlet=True)
    flow_sheet.add_connection(feed, column)
    flow_sheet.add_connection(eluent, column)
    process = Process(flow_sheet, 'batch elution')
    print('hi 2')
    # Events
    Q = 60 / (60 * 1e6)
    process.add_event('feed_on', 'flow_sheet.feed.flow_rate', Q)
    process.add_event('feed_off', 'flow_sheet.feed.flow_rate', 0.0)
    process.add_event('eluent_on', 'flow_sheet.eluent.flow_rate', Q)
    process.add_event('eluent_off', 'flow_sheet.eluent.flow_rate', 0.0)
    process.add_duration('feed_duration')
    process.add_event_dependency('eluent_on', ['feed_off'])
    process.add_event_dependency('eluent_off', ['feed_on'])
    process.add_event_dependency('feed_off', ['feed_on','feed_duration'], [1,1])
    process.cycle_time = 750
    process.feed_duration.time = 60
    print('hi 3')
    # Run CADET
    print(binding_model.n_binding_sites)
    print(binding_model.n_bound_states)
    if __name__ == "__main__":
        print('hi 4')
        print('hi 5')
        print('hi 6')
    # Extract outlet solution
    outlet_solution = simulation_results.solution.column.outlet
    solid_solution = simulation_results.solution.column.solid
    t_full = outlet_solution.time
    c = outlet_solution.solution
    c_store.append(c)
    q_store.append(solid_solution.solution)
c_store = np.array(c_store)
#q_store = np.array(q_store)
print("DATA GENERATED\n")
plt.figure(figsize=(8,6))
    c = c_store[i]
    cA = c[:,0]
    cB = c[:,1]
    plt.plot(t_full, cA, label=f"A dataset {i}")
    plt.plot(t_full, cB, '--', label=f"B dataset {i}")
plt.xlabel("Time (s)")
plt.ylabel("Outlet concentration")
plt.title("Outlet Chromatograms (Bi-Langmuir)")
plt.legend()
plt.grid()
When I add the line:
column.solution_recorder.write_solution_solid = True
I get the error:
ValueError: Expected size (751, 100, 2)
Which comes after (during the first iteration of the loop):
hi 1
hi 2
hi 3
2
4
hi 4
hi 5
I have also tried using (to the same result):
column.solution_recorder.write_solution_bound
I put all the print(‘hi n’) in to indicate where the code reaches. Note: hi 6 is never printed when i get the error.
Any ideas?
Thanks!
Hi Ollie,
thanks for reaching out. Your issue seems to have been fixed in this PR, so if you use our dev branch, your script should run.
To install it, run the following:
Note, I hope that we can soon make a new release which includes this fix.
Cheers,
Hi Jo,
Ok thank you for the response! I have installed this but the code still does not record any solids. What lines in my code do I actually need to change?
Kind regards,
Ollie
if you add
then
will contain the solid solution.
Sorry this still does not work but it is not of high importance for me to fix right now it was more curiosity, I will try again when the bug is patched :slight_smile:
