CADET-Core is now on PyPI & we created a metapackage!
We are continuously working to make CADET not only better but also easier to get started with for new users. Concerning this we have two announcements:
1. CADET-Core is now on PyPI
We are happy to share that CADET-Core is now available on PyPI as prebuilt wheels.
https://pypi.org/project/CADET-Core/
This means you can now install CADET-Core directly via pip:
pip install cadet-core
Note: Wheels are currently only available for recent versions. Older CADET-Core releases still need to be built from source or installed via conda as before.
2. Introducing the cadet metapackage
We also introduced a metapackage that can be installed via:
pip install cadet
https://pypi.org/project/cadet/
It includes:
The metapackage defines compatible version combinations so users get a consistent setup out of the box.
Example use
With this, CADET can now be used independently of conda. For example, it can be installed in a venv:
python3 -m venv cadet-env
source cadet-env/bin/activate   # Linux/macOS
# or .\cadet-env\Scripts\Activate.ps1  on Windows
pip install --upgrade pip
pip install cadet
After activation you can:
  • Select this interpreter in your IDE
  • Use CADET directly from Python
  • Run cadet-cli from the command line
CADET is an open source project. If you need specific version combinations in the metapackage, you are always welcome to open a PR or create a feature request. Contributions and feedback are welcome.
