CADET does not run with a specific version with CADET-Python on Linux
Simulation runs with no errors.
Simulation failed and returned message:
CompletedProcess(args=[‘/home/zhangwx37/.conda/pkgs/cadet-5.0.0-hbe33008_0/bin/cadet-cli’, ‘8f7380c7-4926-4668-aa1e-59be173593e3.h5’], returncode=127, stdout=b’‘, stderr=b’/home/zhangwx37/.conda/pkgs/cadet-5.0.0-hbe33008_0/bin/cadet-cli: error while loading shared libraries: libhdf5.so.310: cannot open shared object file: No such file or directory\n’)
System: Linux (Red Hat)
CADET: 5.0.0
CADET-Python: 0.14.1
Python: 3.12.8
Example code:
Cadet.cadet_path = r"/home/zhangwx37/.conda/pkgs/cadet-5.0.0-hbe33008_0/bin/cadet-cli"
## fixed params
n_sites = 2
n_x = 1
model = Cadet()
# number of unit operations
#inlet model
model.root.input.model.unit_000.ncomp = n_x
#time sections
model.root.input.solver.sections.nsec = 1
model.root.input.solver.sections.section_times = [0.0, 7500.0,]   # s
model.root.input.solver.sections.section_continuity = []
model.root.input.model.unit_000.sec_000.const_coeff = n_x*[0.0,]
model.root.input.model.unit_000.sec_000.lin_coeff =   n_x*[0.0,]
model.root.input.model.unit_000.sec_000.quad_coeff =  n_x*[0.0,]
model.root.input.model.unit_000.sec_000.cube_coeff =  n_x*[0.0,]
model.root.input.model.unit_001.unit_type = 'GENERAL_RATE_MODEL'
## Geometry
model.root.input.model.unit_001.col_length = 1.0                   # m
model.root.input.model.unit_001.cross_section_area = 36/1e6         # m^2, length x area should be the reactor volume
model.root.input.model.unit_001.col_porosity = 0.33                  # 1
model.root.input.model.unit_001.par_porosity = 0.97                  # 1
model.root.input.model.unit_001.par_radius = 0.045/1e3             # m
## Transport
model.root.input.model.unit_001.col_dispersion = 0.0               # m^2/s
model.root.input.model.unit_001.film_diffusion = [1.48e-5, ]       # m/s,     1.35e-5, no film diffusion resistances
model.root.input.model.unit_001.par_diffusion =  [1e-12, ]          # m^2/s
model.root.input.model.unit_001.par_surfdiffusion = n_sites * [0.0, ]
model.root.input.model.unit_001.adsorption_model = 'MULTI_COMPONENT_BILANGMUIR'
model.root.input.model.unit_001.adsorption.is_kinetic = 1
model.root.input.model.unit_001.adsorption.mcbl_ka = [2.0, 2.0]            ##  m^3 mobile phase / mol protein / s   ml/mg=m^3/kg    1 kda = 1 kg/mol
model.root.input.model.unit_001.adsorption.mcbl_kd = n_sites * [1.0, ]                                            ##  1/s
model.root.input.model.unit_001.adsorption.mcbl_qmax = [5.0, 5.0]                                        ##  mol protein / m^3 solid phase (not resin)
model.root.input.model.unit_001.init_c = [5/150, ]                                             ##  mg/ml=kg/m^3, kg/mol, mol/m^3
model.root.input.model.unit_001.init_q = n_sites * [0.0, ]
### Grid cells
model.root.input.model.unit_001.discretization.ncol = 1             ## make sure this is 1
model.root.input.model.unit_001.discretization.npar = 100
### Bound states
model.root.input.model.unit_001.discretization.nbound = [n_sites, ]
### Other options
model.root.input.model.unit_001.discretization.weno.weno_order = 2
## Outlet
model.root.input.model.unit_002.ncomp = n_x
# Connections
Q = 0 # volumetric flow rate
    0, 1, -1, -1, Q,
    1, 2, -1, -1, Q,
]  # Q, volumetric flow rate
# numerical solver configuration
model.root.input.solver.time_integrator.abstol = 1e-5
model.root.input.solver.time_integrator.algtol = 1e-8
model.root.input.solver.time_integrator.reltol = 1e-5
model.root.input.solver.time_integrator.init_step_size = 1e-18
# Return data
model.root.input['return'].split_components_data = 0
model.root.input['return'].unit_000.write_solution_bulk = 0
model.root.input['return'].unit_000.write_solution_inlet = 0
model.root.input['return'].unit_000.write_sens_outlet=0
model.root.input['return'].unit_000.write_sens_bulk=0
# Solution times
model.root.input.solver.user_solution_times = np.linspace(0, 7250.0, 100)
model.filename = 'test.h5'
model.save()
data = model.run()
model.load()
print(data)
tl = model.root.input.solver.user_solution_times
cl = model.root.output.solution.unit_001.solution_outlet*150
environment.yml (7.93 KB)
Hi Flynn,
thanks for reporting the issue. Unfortunately, I cannot reproduce the issue, but I have a couple of questions / ideas:
  • Is the cadet_path in the same conda environment as you’re running the code from?
  • If so, it’s actually no longer required to set the install path if you use the “standard” installation; it should be autodetected.
  • Update CADET-Core to v5.0.3
  • Setup a new (clean) environment and try again.
Let us know if this helped.
Hi Johannes, thanks for your reply! Is there a method we can call in CADET for older versions like above to find the cadet_path from standard installation?
You can specify the path to a separate version just the way you did it. However, if this is in another conda environment, there might be issues with dependencies. Maybe in your case, the cadet-cli was dynamically linked against a specific version of HDF5 which is then not used in the environment you’re currently on.
Just out of curiosity, why don’t you update to the latest CADET-Core version?
Hello Jo, I think this is not about CADET but rather CADET-Python.
  1. I updated CADET to 5.0.3. If I don’t specify the path to cadet_cli, it gives an error:
  2. If I specify the following path: "/home/zhangwx37/.conda/pkgs/cadet-5.0.3-hbe33008_0/bin/cadet-cli" , it gives the same error:
However, I did realize I was specifying the wrong path… Inside the .conda/ folder there are two folders, one is pkgs and the other is env. I can find cadet_cli in both of them. However, only the one in env works. Anyway, problem solved.
Another quick question, for newer versions, I still define cadet_path to specify customized cadet_cli? Would this cause any problems regarding dynamic links?
