Hi everyone,
I am following the tutorial script and am getting the following error on the ‘data=model.run()’ command:
PermissionError: [WinError 5] Access is denied
Full error is below:
PermissionError Traceback (most recent call last)
Cell In[6], line 6
3 model.filename = 'model.h5'
4 model.save()
----> 6 data = model.run()
8 if data.returncode == 0:
9 print("Simulation completed successfully")
File ~\AppData\Local\anaconda3\Lib\site-packages\cadet\cadet.py:213, in Cadet.run(self, timeout, check)
212 def run(self, timeout = None, check=None):
--> 213 data = self.cadet_runner.run(simulation=self.root.input, filename=self.filename, timeout=timeout, check=check)
214 #self.return_information = data
215 return data
File ~\AppData\Local\anaconda3\Lib\site-packages\cadet\cadet.py:237, in CadetFile.run(self, filename, simulation, timeout, check)
235 def run(self, filename = None, simulation=None, timeout = None, check=None):
236 if filename is not None:
--> 237 data = subprocess.run([self.cadet_path, filename], timeout = timeout, check=check, capture_output=True)
238 return data
239 else:
File ~\AppData\Local\anaconda3\Lib\subprocess.py:548, in run(input, capture_output, timeout, check, *popenargs, **kwargs)
545 kwargs['stdout'] = PIPE
546 kwargs['stderr'] = PIPE
--> 548 with Popen(*popenargs, **kwargs) as process:
549 try:
550 stdout, stderr = process.communicate(input, timeout=timeout)
File ~\AppData\Local\anaconda3\Lib\subprocess.py:1026, in Popen.__init__(self, args, bufsize, executable, stdin, stdout, stderr, preexec_fn, close_fds, shell, cwd, env, universal_newlines, startupinfo, creationflags, restore_signals, start_new_session, pass_fds, user, group, extra_groups, encoding, errors, text, umask, pipesize, process_group)
1022 if self.text_mode:
1023 self.stderr = io.TextIOWrapper(self.stderr,
1024 encoding=encoding, errors=errors)
-> 1026 self._execute_child(args, executable, preexec_fn, close_fds,
1027 pass_fds, cwd, env,
1028 startupinfo, creationflags, shell,
1029 p2cread, p2cwrite,
1030 c2pread, c2pwrite,
1031 errread, errwrite,
1032 restore_signals,
1033 gid, gids, uid, umask,
1034 start_new_session, process_group)
1035 except:
1036 # Cleanup if the child failed starting.
1037 for f in filter(None, (self.stdin, self.stdout, self.stderr)):
File ~\AppData\Local\anaconda3\Lib\subprocess.py:1538, in Popen._execute_child(self, args, executable, preexec_fn, close_fds, pass_fds, cwd, env, startupinfo, creationflags, shell, p2cread, p2cwrite, c2pread, c2pwrite, errread, errwrite, unused_restore_signals, unused_gid, unused_gids, unused_uid, unused_umask, unused_start_new_session, unused_process_group)
1536 # Start the process
1537 try:
-> 1538 hp, ht, pid, tid = _winapi.CreateProcess(executable, args,
1539 # no special security
1540 None, None,
1541 int(not close_fds),
1542 creationflags,
1543 env,
1544 cwd,
1545 startupinfo)
1546 finally:
1547 # Child is launched. Close the parent's copy of those pipe
1548 # handles that only the child should have open. You need
1551 # pipe will not close when the child process exits and the
1552 # ReadFile will hang.
1553 self._close_pipe_fds(p2cread, p2cwrite,
1554 c2pread, c2pwrite,
1555 errread, errwrite)
First thing I did was look this up on stack overflow - they said to update folder permissions.
I have updated security permissions in the AppData folder and am running this in Jupyter notebook with administrator rights.
Not sure what’s going wrong and would greatly appreciate any input ![]()
