CADET-Process comparator.add_difference_metric()
Hello there,
regarding CADET-Process comparator.add_difference_metric() method: Every example has (…, solution_path=‘outlet.outlet’), which tries to use the whole outlet to compare against, i.e. all components returned at outlet.outlet. If I want to only compare against a single component of the outlet, how would I do that?
Cheers,
Ron
Solved via text-message from @j.schmoelder :
The difference metric constructor takes a components kwarg. So
        ..., ..., 'outlet.outlet', components=["Protein X"]
solves the problem.
