CADET-Python version 1.0 release announcement (updated 2024-12-16)
CADET-Python v1.0.0
CADET-Python has long been used as a file-based interface for CADET-Core. With this release, we’re moving to v1.0.0, reflecting its maturity and expanded functionality. This version introduces a C-API for directly reading simulation results from CADET-Core, enhancing data processing efficiency. Future releases will aim to add more features and further refine the interface.
All users are encouraged to upgrade to CADET-Python v1.0.0 to take advantage of these improvements in performance, usability, and code quality.
This release requires Python 3.10+.
Highlights and new features of this release
New Features
  • C-API Support: Added functionality to directly interface with CADET-Core, allowing for more efficient result retrieval.
  • Autodetect CADET: Enhanced user experience by automating the detection of CADET installation.
  • Extended Test Suite: Broadened test coverage to improve stability and ensure reliability.
  • Enhanced Documentation: Added comprehensive docstrings and type annotations for improved readability and usability.
  • Improved Logging: Enhanced logging to provide better debugging and diagnostic information.
  • PEP8 Formatting: Codebase updated to conform to PEP8, improving code quality and readability.
Breaking changes
  • Updated cadet.run() Return: cadet.run() now returns an instance of the ReturnInformation class, which includes:
    • return_code: int: Status code for execution.
    • error_message: str: Message describing any errors encountered.
    • log: str: Detailed log of the run.
CADET-Python v1.0.2
CADET-Python v1.0.2 is a patch release to fix some inconsistencies between the solution shape when using the CLI vs the C-API.
Full Changelog: Comparing v1.0.1...v1.0.2 · cadet/CADET-Python · GitHub
CADET-Python v1.0.3
CADET-Python v1.0.3 is patch release to fix some inconsistencies in the solution output dimensions when using C-API vs. CLI.
What’s Changed
Full Changelog: Comparing v1.0.2...v1.0.3 · cadet/CADET-Python · GitHub
CADET-Python v1.0.4
CADET-Python v1.0.4 is a patch release to fix an issue when writing string arrays using the new C-API.
What’s Changed
Full Changelog: Comparing v1.0.3...v1.0.4 · cadet/CADET-Python · GitHub
