I have trouble to run the tutorial section after following the instructions:
git clone https://github.com/modsim/CADET-Process_Tutorial
conda env create -f ./environment1.yml
conda activate cadet-process
I changed the prompt a bit because I have installed another version of tutorial package before:
However, when I started playing tutorial script, it always showed me the error:
ModuleNotFoundError Traceback (most recent call last)
~\AppData\Local\Temp\ipykernel_27492\3050325500.py in
----> 1 from CADETProcess.processModel import ComponentSystem
2 from CADETProcess.processModel import Inlet, LumpedRateModelWithPores, Outlet
3 from CADETProcess.processModel import FlowSheet
4 from CADETProcess.processModel import Process
5
~\Anaconda3\lib\site-packages\CADETProcess_init_.py in
29 from . import metric
30 from . import performance
—> 31 from . import optimization
32 from . import comparison
33 from . import stationarity
~\Anaconda3\lib\site-packages\CADETProcess\optimization_init_.py in
3 from .optimizer import *
4 from .scipyAdapter import COBYLA, TrustConstr, NelderMead, SLSQP
----> 5 from .pymooAdapter import NSGA2, U_NSGA3
~\Anaconda3\lib\site-packages\CADETProcess\optimization\pymooAdapter.py in
9 from pymoo.core.problem import Problem
10 from pymoo.factory import get_reference_directions
—> 11 from pymoo.util.termination.default import MultiObjectiveDefaultTermination
12 from pymoo.core.repair import Repair
13
ModuleNotFoundError: No module named ‘pymoo.util.termination’
Can anyone please help? Thank you very much!
Kind regards,
Annie
