CADET with multicomponent colloidal isotherm
Forward simulation using colloidal isotherm - load for given time, then wash for given time. Expected binding behavior for protein
I’m getting an issue
CADETProcessError: CADET Error: Simulation failed with b’ERROR: No protein component present\n’, not sure where it’s coming from
import pandas as pd
from scipy import integrate
# import cadet packages
from CADETProcess.processModel import Langmuir, MultiComponentColloidal
from CADETProcess.processModel import (Inlet, LumpedRateModelWithoutPores, Outlet)
# conversion
mLmin_to_m3s = 60*1e6
# input parameters
exp_flow = 8. # MV/min (mL/min)
Q = exp_flow/(mLmin_to_m3s) # convert to m^3/s
# load and wash
loadVol = 42.3 # mL
washVol = 33.9 # mL
total_vol = loadVol + washVol # mL
exp_time = total_vol/exp_flow*60 # seconds
sample_vol = loadVol
# system tubing
tubeIDmm = 0.75 # mm
tubeID = tubeIDmm/1000 # m
tubeLenmm = 2.7*1000 # mm
tubeLen = tubeLenmm/1000
tubeDisp = 0.0055315109901466425
# load time
pulse_time_s = loadVol/(exp_flow/60.)
# device parameters
device_Dax = 5.413e-9 # m^2/s
# protein size
size_kDa = 150
# create component system
component_system.add_component('device')
# binding model
binding_model = MultiComponentColloidal(component_system, name='MultiComponentColloidal')
binding_model.phase_ratio = 4.5e6
binding_model.kappa_exponential = 0
binding_model.kappa_factor = 0
binding_model.kappa_constant = 4e-9
binding_model.kinetic_rate_constant = 100000000
binding_model.logkeq_exponent_factor = [100.0]
binding_model.logkeq_exponent_multiplier = 0
binding_model.logkeq_power_factor = 0
binding_model.logkeq_ph_exponent = 0
binding_model.logkeq_power_exponent = 0
binding_model.bpp_power_factor = 0
binding_model.bpp_exponent_factor = [0.1]
binding_model.bpp_exponent_multiplier = 0
binding_model.bpp_ph_exponent = 0
binding_model.bpp_power_exponent = 0
binding_model.coordination_number = 6
binding_model.protein_radius = 4.509263378751285e-09
binding_model.bound_states=[0,]
# feed (mAb05)
feed.c = [3.6/size_kDa,]
# eluent (washout buffer)
eluent.c = [0,]
# device
device = LumpedRateModelWithoutPores(component_system, name='device')
device.length = 3.305/1000 # from keyence imaging
device.diameter = 2.85/100 # fron Natrix team
device.total_porosity = 0.804
device.axial_dispersion = 4.2507694650704883e-07
device.binding_model = binding_model
# outlet
outlet.solution_recorder.write_solution_bulk = True
# now we create the Flow Sheet
flow_sheet.add_unit(feed, feed_inlet=True)
flow_sheet.add_unit(eluent, eluent_inlet=True)
flow_sheet.add_unit(device)
flow_sheet.add_connection(feed, device)
flow_sheet.add_connection(eluent, device)
flow_sheet.add_connection(device, outlet)
# now we create the process, i.e., turning feed on, swap to wash buffer, same flow rate
process = Process(flow_sheet, 'batch elution')
process.add_event('eluent_on', 'flow_sheet.eluent.flow_rate', Q, 0)
process.add_event('eluent_off', 'flow_sheet.eluent.flow_rate', 0.0)
process.add_event('feed_on', 'flow_sheet.feed.flow_rate', Q)
process.add_event('feed_off', 'flow_sheet.feed.flow_rate', 0.0)
process.add_duration('feed_duration')
process.add_event_dependency('eluent_on', ['feed_off'])
process.add_event_dependency('eluent_off', ['feed_on'])
process.add_event_dependency('feed_off', ['feed_on', 'feed_duration'], [1, 1])
# cycle time
process.cycle_time = exp_time # seconds
# load time
process.feed_duration.time = pulse_time_s
# simluate the process
if __name__ == '__main__':
    process_simulator.time_resolution = 0.1
Hello Rosario,
Thanks for your post!
You define your component system as
However, the MultiComponentColloidal model expects at least two components:
  • A non-binding salt component (index 0).
  • At least one protein component (index 1 or higher).
So your component system should include those, e.g.:
component_system = ComponentSystem(['salt', 'protein'])
Additionally to this change, all component-specific information, such as bound states, feed and eluent concentrations, and concentration changes in events, have to be provided for both components as a list then.
Also, be careful with naming—“device” was used both as a component name and for the binding model later.
For more information in the ComponentSytem() class, also see the CADET-Process documentation. Additionally, find the explanation of the non-binding pseudo component and it’s use in the CADET-core documentation of the MultiComponentColloidal.
Hope that already sheds some light on the issue!
