CSTR causes hanging simulation with low values
Simulation runs with CSTR init_liquid_volume < 1e-4
Simulation hangs with CSTR init_liquid_volume < 1e-4
import pandas as pd
# import cadet packages
from CADETProcess.processModel import LangmuirLDF
from CADETProcess.processModel import Inlet, LumpedRateModelWithoutPores, Outlet
from CADETProcess.processModel import TubularReactor, Cstr
# setup experiment
# conversion
mLmin_to_m3s = 60*1e6
# input parameters
exp_flow = 8. # MV/min (mL/min)
Q = exp_flow/(mLmin_to_m3s) # convert to m^3/s
# load and wash
loadVol = 60.1 #42.3 #43.0 #60.1 # mL
washVol = 34.8 #33.9 #25.0 #34.8 # mL
protein_c = 3.5 #3.7 #3.6 #3.5 # g/L
total_vol = loadVol + washVol # mL
exp_time = total_vol/exp_flow*60 # seconds
# timepoints
load_time = loadVol/(exp_flow/60.)
wash_time = washVol/(exp_flow/60.)
# device parameters
device_Dax = 5.413e-9 # m^2/s
# protein size
size_kDa = 150.
Qmax = 80 # mg/mL = g/L
Qmax_mMol = Qmax/size_kDa# -> mMolar
# create component system
component_system.add_component('pH') # pH currently dummy variable
component_system.add_component('protein')
# binding model
binding_model = LangmuirLDF(component_system, name='MultiComponentLangmuir_LDF')
binding_model.equilibrium_constant =[0,20000]
binding_model.driving_force_coefficient = [0,1.0]
binding_model.capacity = [0,Qmax_mMol]
binding_model.bound_states=[0,1]
binding_model.check_required_parameters()
# feed
feed.c = [1,protein_c/size_kDa]
# washout
wash = Inlet(component_system, name='wash')
wash.c = [1,0]
# device
device = LumpedRateModelWithoutPores(component_system, name='device')
device.length = 3.305/1000 #
device.diameter = 2.85/100 #
device.total_porosity = 0.804
device.axial_dispersion = 4.25e-07
device.binding_model = binding_model
device.c = [1,0]
#device.q = [1,0]
# feed tubing
load_tubing = TubularReactor(component_system, name='load_tubing')
load_tubing.c = [1,0]
load_tubing.length = 270/100
load_tubing.diameter = 0.75/1000
load_tubing.axial_dispersion = 0.005
# dead_vol
dead_vol = TubularReactor(component_system, name='dead_vol')
dead_vol.c = [1,0]
dead_vol.length = 1.34/100
dead_vol.diameter = 4/1000
dead_vol.axial_dispersion =  0.005531511
# outlet
#outlet.solution_recorder.write_solution_bulk = True
# CSTR
inlet_mixer = Cstr(component_system, name='inlet_mixer')
inlet_mixer.c = [1,0]
#inlet_mixer.V = 0.001 # units?
#inlet_mixer.V = 0.0001
#!!!! ISSUE IS HERE !!!!
inlet_mixer.init_liquid_volume = 1e-5 #m^3
inlet_mixer.const_solid_volume = 0.0
inlet_mixer.flow_rate_filter = Q # 8 mL/min
inlet_mixer.check_required_parameters()
#inlet_mixer.solution_recorder.write_solution_bulk=True
# now we create the Flow Sheet
flow_sheet.add_unit(feed)
flow_sheet.add_unit(wash)
flow_sheet.add_unit(load_tubing)
flow_sheet.add_unit(device)
flow_sheet.add_unit(dead_vol)
flow_sheet.add_unit(inlet_mixer)
flow_sheet.add_connection(feed, load_tubing)
flow_sheet.add_connection(wash, load_tubing)
flow_sheet.add_connection(load_tubing, inlet_mixer)
flow_sheet.add_connection(inlet_mixer,device)
flow_sheet.add_connection(device, dead_vol)
flow_sheet.add_connection(dead_vol, outlet)
# now we create the process, i.e., turning feed on, swap to wash buffer, same flow rate
process = Process(flow_sheet, 'breakthrough')
# breakthrough phase
process.add_event('feed_on','flow_sheet.feed.flow_rate',Q,time=0)
process.add_event('feed_off','flow_sheet.feed.flow_rate',0,time=load_time)
# wash
process.add_event('wash_on','flow_sheet.wash.flow_rate',Q,time=load_time)
process.add_event('wash_off','flow_sheet.wash.flow_rate',0,time=exp_time)
# cycle time
process.cycle_time = exp_time # seconds
print(Q,'m^3/s')
# simluate the process
if __name__ == '__main__':
    process_simulator.time_resolution = 0.01
print('simulation finished')
# save x- and y- axis information
x_axis_sim_init = simulation_results.solution.outlet.outlet.time
x_axis_sim_min = x_axis_sim_init/60.
y_axis_sim_init = simulation_results.solution.outlet.outlet.solution
y_axis_sim_init = y_axis_sim_init[:,1]
#initial_y_max= np.max(y_axis_sim_init)
plt.plot(x_axis_sim_min,y_axis_sim_init,'-r',label='initial simulation')
plt.ylabel('mMol')
plt.xlabel('min')
plt.legend()
environment.yml (7.56 KB)
Hello Rosario,
Thanks for your bug report!
I was able to reproduce the issue you described.
You’re setting the parameter flow_rate_filter of your inlet_mixer equal to your flow_rate. This means that an equivalent amount of pure liquid is drained (and effectively discarded) from the CSTR as fast as it enters. As a result:
  • For init_liquid_volume > 1e-4, the solute concentrations at the outlet become extremely small.
  • For init_liquid_volume < 1e-4, numerical issues arise because almost no liquid with solutes reaches the device and the CSTR becomes a bottleneck.
Please double-check whether you intended to use flow_rate_filter in this way. If not, removing the line:
should resolve the issue.
Hello Hanna, indeed that resolved the issue. I misread the documentation during my initial implementation of CSTR.
Thanks again!
-Rosario
Excellent, happy to help!
