Cyclic steady state in CADET
Hi there,
I found this topic where you dicuss the cyclic steady state for SMBs in CADET but I have encountered a problem ((Achieving cyclic steady state in CADET - #4 by j.schmoelder).
I use the last_state_y and last_state_ydot as initial states for a new simulation as stated in the discussion above. However, I have encountered that when a new simulation is run, there is an issue with some of the concentrations. In the attached simulation files and results as images, it is shown that when the new simulation starts, the concentration increases. However, this happens only for some concentrations (not shown).
sim_langmuir_file
When I run the simulation for the same time but ‘in one piece’, these increases are not seen.
sim_langmuir_file_2
I have not been able to figure out why this happens, and any help is appreciated.
I am not able to upload my code because I am a new user.
Thanks in advance,
Jesper
Hey Jesper and welcome to the forum!
Could you please provide us with the code? Otherwise it’s hard to reproduce the error. You can just paste everything here (for nice formatting, put it between backticks `).
Alternatively, you could also create a Github Gist.
Btw, did you check that the init_c/init_state parameters are lower case? That was also the issue in another recent discussion. We’re aware of it and try to improve the interface here.
Hi Johannes,
My code is lower case so that does not solve it unfortunately.
For the run with sequences of SMB runs, the code is:
	#Import packages and lead way to cadet cli
	import pandas as pd
	import timeit
	from scipy.optimize import  least_squares
	Cadet.cadet_path = r'C:\Users\jespfra\Anaconda3\bin\cadet-cli' #working pc
	#%% Functions
	# A function to set the discretization for the units instead of writting in manully for every single unit
	def set_discretization(model, n_bound=None, n_col=20, n_par_types=1):
		columns = {'GENERAL_RATE_MODEL', 'LUMPED_RATE_MODEL_WITH_PORES', 'LUMPED_RATE_MODEL_WITHOUT_PORES'}
		for unit_name, unit in model.root.input.model.items():
			if 'unit_' in unit_name and unit.unit_type in columns:
				unit.discretization.ncol = n_col
				unit.discretization.npar = 5
				unit.discretization.npartype = n_par_types
				if n_bound is None:
					n_bound = unit.ncomp*[0]
				unit.discretization.nbound = n_bound
				unit.discretization.par_disc_type = 'EQUIDISTANT_PAR'
				unit.discretization.use_analytic_jacobian = 1
				unit.discretization.reconstruction = 'WENO'
				unit.discretization.gs_type = 1
				unit.discretization.max_krylov = 0
				unit.discretization.max_restarts = 10
				unit.discretization.schur_safety = 1.0e-8
				unit.discretization.weno.boundary_model = 0
				unit.discretization.weno.weno_eps = 1e-10
				unit.discretization.weno.weno_order = 3
	# General model options
	def SMBmodel(Q1,Q2,Q3,Q4,QD,QE,QF,QR,ts,n_col,j):
		#Setting up the model
		smb_model = Cadet()
		#Speciy number of unit operations: inputs, CSTR, column and output
		smb_model.root.input.model.nunits = 8
		# number of components
		n_comp  = 2
		#First unit operation: inlet
		## Feed
		smb_model.root.input.model.unit_000.unit_type = 'INLET'
		smb_model.root.input.model.unit_000.ncomp = n_comp
		smb_model.root.input.model.unit_000.inlet_type = 'PIECEWISE_CUBIC_POLY'
		## Eluent
		smb_model.root.input.model.unit_001.unit_type = 'INLET'
		smb_model.root.input.model.unit_001.ncomp = n_comp
		smb_model.root.input.model.unit_001.inlet_type = 'PIECEWISE_CUBIC_POLY'
		## Extract
		smb_model.root.input.model.unit_002.ncomp = n_comp
		smb_model.root.input.model.unit_002.unit_type = 'OUTLET'
		## Raffinate
		smb_model.root.input.model.unit_003.ncomp = n_comp
		smb_model.root.input.model.unit_003.unit_type = 'OUTLET'
		## Columns
		smb_model.root.input.model.unit_004.unit_type = 'LUMPED_RATE_MODEL_WITHOUT_PORES'
		smb_model.root.input.model.unit_004.ncomp = n_comp
		smb_model.root.input.model.unit_004.col_dispersion = 3.8148E-20
		smb_model.root.input.model.unit_004.col_length = 0.25
		smb_model.root.input.model.unit_004.total_porosity = 0.83
		smb_model.root.input.model.unit_004.velocity = 1
		smb_model.root.input.model.unit_004.cross_section_area = 3.141592653589793E-4
		smb_model.root.input.model.unit_004.adsorption_model = 'MULTI_COMPONENT_LANGMUIR'
		smb_model.root.input.model.unit_004.adsorption.is_kinetic = 0
		smb_model.root.input.model.unit_004.adsorption.mcl_ka = [ 0.11, 0.148]
		smb_model.root.input.model.unit_004.adsorption.mcl_kd = [ 1.0, 1.0]
		smb_model.root.input.model.unit_004.adsorption.mcl_qmax = [ 5.72/0.11, 7.7/0.148]
		smb_model.root.input.model.unit_004.init_c = [0,0.0]
		smb_model.root.input.model.unit_004.init_q = [0.0,0.0]
		### Copy column models
		smb_model.root.input.model.unit_005 = smb_model.root.input.model.unit_004
		smb_model.root.input.model.unit_006 = smb_model.root.input.model.unit_004
		smb_model.root.input.model.unit_007 = smb_model.root.input.model.unit_004
		#To write out last output to check for steady state
		smb_model.root.input['return'].write_solution_last = True
		#% Input and connections
		n_cycles = 5
		switch_time = ts #s
		#Sections
		smb_model.root.input.solver.sections.nsec = 4*n_cycles
		smb_model.root.input.solver.sections.section_times = [0]
		for i in range(n_cycles):
			smb_model.root.input.solver.sections.section_times.append((4*i+1)*switch_time)
			smb_model.root.input.solver.sections.section_times.append((4*i+2)*switch_time)
			smb_model.root.input.solver.sections.section_times.append((4*i+3)*switch_time)
			smb_model.root.input.solver.sections.section_times.append((4*i+4)*switch_time)
		## Feed and Eluent concentration
		smb_model.root.input.model.unit_000.sec_000.const_coeff = [CfA,CfB] #Inlet flowrate concentration
		smb_model.root.input.model.unit_001.sec_000.const_coeff = [ 0.0, 0.0]
		#Connections
		smb_model.root.input.model.connections.nswitches = 4
		smb_model.root.input.model.connections.switch_000.section = 0
		smb_model.root.input.model.connections.switch_000.connections = [
			4, 5, -1, -1, Q4,#flowrates, Q, m3/s
			5, 6, -1, -1, Q4,
			6, 7, -1, -1, Q2,
			7, 4, -1, -1, Q2,
			0, 4, -1, -1, QF,
			1, 6, -1, -1, QD,
			4, 2, -1, -1, QR,
			6, 3, -1, -1, QE
		smb_model.root.input.model.connections.switch_001.section = 1
		smb_model.root.input.model.connections.switch_001.connections = [
			4,	5,	-1,	-1,	Q2,#flowrates, Q, m3/s
			5,	6,	-1,	-1,	Q4,
			6,	7,	-1,	-1,	Q4,
			7,	4,	-1,	-1,	Q2,
			0,	5,	-1,	-1,	QF,
			1,	7,	-1,	-1,	QD,
			5,	2,	-1,	-1,	QR,
			7,	3,	-1,	-1,	QE
		smb_model.root.input.model.connections.switch_002.section = 2
		smb_model.root.input.model.connections.switch_002.connections = [
			5,	6,	-1,	-1,	Q2,
			6,	7,	-1,	-1,	Q4,
			7,	4,	-1,	-1,	Q4,
			0,	6,	-1,	-1,	QF,
			1,	4,	-1,	-1,	QD,
			6,	2,	-1,	-1,	QR,
			4,	3,	-1,	-1,	QE
		smb_model.root.input.model.connections.switch_003.section = 3
		smb_model.root.input.model.connections.switch_003.connections = [
			5,	6,	-1,	-1,	Q2,
			6,	7,	-1,	-1,	Q2,
			7,	4,	-1,	-1,	Q4,
			0,	7,	-1,	-1,	QF,
			1,	5,	-1,	-1,	QD,
			7,	2,	-1,	-1,	QR,
			5,	3,	-1,	-1,	QE
		#solution times
		smb_model.root.input.solver.user_solution_times = np.linspace(0, n_cycles*4*switch_time, int(n_cycles*4*switch_time))
		#% Solver options: spatial and time
		#Spatial for the units
		set_discretization(smb_model, n_col=n_col, n_bound = list(np.ones(n_comp)))
		#Time
		smb_model.root.input.solver.time_integrator.abstol = 1e-6 #absolute tolerance
		smb_model.root.input.solver.time_integrator.algtol = 1e-10
		smb_model.root.input.solver.time_integrator.reltol = 1e-6 #Relative tolerance
		smb_model.root.input.solver.time_integrator.init_step_size = 1e-6
		smb_model.root.input.solver.time_integrator.max_steps = 1000000
		#Solver options in general (not only for column although the same)
		smb_model.root.input.model.solver.gs_type = 1
		smb_model.root.input.model.solver.max_krylov = 0
		smb_model.root.input.model.solver.max_restarts = 10
		smb_model.root.input.model.solver.schur_safety = 1e-8
		smb_model.root.input.solver.nthreads = 1
		#Specify which results we want to return
		# Return data
		smb_model.root.input['return'].split_components_data = 0
		smb_model.root.input['return'].split_ports_data = 0
		smb_model.root.input['return'].unit_000.write_solution_bulk = 1
		smb_model.root.input['return'].unit_000.write_solution_inlet = 1
		smb_model.root.input['return'].unit_000.write_solution_outlet = 1
		smb_model.root.input['return'].unit_001 = smb_model.root.input['return'].unit_000
		smb_model.root.input['return'].unit_002 = smb_model.root.input['return'].unit_000
		smb_model.root.input['return'].unit_003 = smb_model.root.input['return'].unit_000
		smb_model.root.input['return'].unit_004 = smb_model.root.input['return'].unit_000
		smb_model.root.input['return'].unit_005 = smb_model.root.input['return'].unit_000
		smb_model.root.input['return'].unit_006 = smb_model.root.input['return'].unit_000
		smb_model.root.input['return'].unit_007 = smb_model.root.input['return'].unit_000
		#Saving data
		smb_model.filename = 'Langmuir_sim_gradient_multi_'+str(j)+'.h5'
		smb_model.save()
		#run model
		data = smb_model.run()
		if data.returncode == 0:
			print("Simulation completed successfully")
			smb_model.load()
			print(data)
			raise Exception("Simulation failed")
		df = pd.DataFrame({'Time': smb_model.root.output.solution.solution_times,
						   'Ca_R': smb_model.root.output.solution.unit_002.solution_outlet[:,0],
						   'Cb_R': smb_model.root.output.solution.unit_002.solution_outlet[:,1],
						   'Ca_E': smb_model.root.output.solution.unit_003.solution_outlet[:,0],
						   'Cb_E': smb_model.root.output.solution.unit_003.solution_outlet[:,1] })
		#If cyclic steady state has not been reached
		state_y = smb_model.root.output.last_state_y
		state_ydot = smb_model.root.output.last_state_ydot
		#Try to run SMB_model_SS which is just a new simulation that stores the name differently
		for k in range(0,3):
			df, state_y, state_ydot = SMBmodel_ss(Q1, Q2, Q3, Q4, QD, QE, QF, QR, ts, n_col, j,state_y, state_ydot,k)
			df, state_y, state_ydot = df, state_y, state_ydot
		return df
	def SMBmodel_ss(Q1,Q2,Q3,Q4,QD,QE,QF,QR,ts,n_col,j,state_y, state_ydot,k):
		smb_model = Cadet()
		n_comp  = 2
		## Feed
		## Eluent
		## Extract
		## Raffinate
		## Columns
		smb_model.root.input.model.unit_004.adsorption.mcl_ka = [0.11, 0.148]
		# smb_model.root.input.model.unit_004.init_c = [0.0,0.0]
		# smb_model.root.input.model.unit_004.init_q = [0.0,0.0]
		#Load initial conditions from last state
		smb_model.root.input.model.init_state_y = state_y
		smb_model.root.input.model.init_state_ydot = state_ydot
		# smb_model.root.input.model.unit_004.init_c = [200, 0.0, 0.0, 0] #HERE
		# smb_model.root.input.model.unit_004.init_q = [Lambda_, 0.0,0.0, 0] #HERE
		n_cycles = 3
		switch_time = ts #s
		#Sections
		smb_model.root.input.model.unit_001.sec_000.const_coeff = [0.0, 0.0]
		#Connections
			5, 6, -1, -1, Q4,
			6, 7, -1, -1, Q2,
			7, 4, -1, -1, Q2,
			0, 4, -1, -1, QF,
			1, 6, -1, -1, QD,
			4, 2, -1, -1, QR,
			6, 3, -1, -1, QE
			5,	6,	-1,	-1,	Q4,
			6,	7,	-1,	-1,	Q4,
			7,	4,	-1,	-1,	Q2,
			0,	5,	-1,	-1,	QF,
			1,	7,	-1,	-1,	QD,
			5,	2,	-1,	-1,	QR,
			7,	3,	-1,	-1,	QE
			5,	6,	-1,	-1,	Q2,
			6,	7,	-1,	-1,	Q4,
			7,	4,	-1,	-1,	Q4,
			0,	6,	-1,	-1,	QF,
			1,	4,	-1,	-1,	QD,
			6,	2,	-1,	-1,	QR,
			4,	3,	-1,	-1,	QE
			5,	6,	-1,	-1,	Q2,
			6,	7,	-1,	-1,	Q2,
			7,	4,	-1,	-1,	Q4,
			0,	7,	-1,	-1,	QF,
			1,	5,	-1,	-1,	QD,
			7,	2,	-1,	-1,	QR,
			5,	3,	-1,	-1,	QE
		#solution times
		#Time
		# Return data
		#Saving data
		smb_model.filename = 'Langmuir_sim_gradient_multi_S_'+str(j)+'_'+str(k)+'.h5'
		smb_model.save()
		#run model
			smb_model.load()
			print(data)
		return df, state_y, state_ydot
	#Determining isotherm and function for determining the region of separation
	#%% binding parameters
	#We set the binding parameters
	Ka = 0.148 #l/g
	Kb = 0.11
	gamma_a = 7.7
	gamma_b = 5.72
	Na = gamma_a/Ka #g/L max capacity
	Nb = gamma_b/Kb
	#Inlet concentrations
	CfA = 0.55   #g/L
	CfB = 0.55
	eps = 0.83
	VC = (0.25*0.02**2/4)*np.pi #m3
	ts = 180 #s
	data = []
	n_col = 80
	m2_c = 6
	m3_c = 9
	m1_min = gamma_a
	m4_max = 1/2*(gamma_b + m3_c + Kb*CfB*(m3_c-m2_c)-((gamma_b + m3_c + Kb*CfB*(m3_c-m2_c))**2-4*gamma_b*m3_c)**0.5)
	m1_c = 8.2
	m4_c = m4_max*0.5
	Q1 = -(m1_c*eps - m1_c - eps)*VC/ts
	Q2 = -(m2_c*eps - m2_c - eps)*VC/ts
	Q3 = -(m3_c*eps - m3_c - eps)*VC/ts
	Q4 = -(m4_c*eps - m4_c - eps)*VC/ts
	QD = -VC*(m1_c*eps - m4_c*eps - m1_c + m4_c)/ts
	QE = -VC*(m1_c*eps - m2_c*eps - m1_c + m2_c)/ts
	QF = VC*(m2_c*eps - m3_c*eps - m2_c + m3_c)/ts
	QR = -VC*(m3_c*eps - m4_c*eps - m3_c + m4_c)/ts
	j=0
	#Running the SMB model
	df = SMBmodel(Q1,Q2,Q3,Q4,QD,QE,QF,QR,ts,n_col,j)
	#%% Load data and plot the issue
	ts = 180
	data = []
	filename = 'Langmuir_sim_gradient_multi_0.h5'
	smb_model = Cadet()
	smb_model.filename = filename
	smb_model.load()
					   'Ca_E': smb_model.root.output.solution.unit_002.solution_outlet[:,0],
					   'Cb_E': smb_model.root.output.solution.unit_002.solution_outlet[:,1],
					   'Ca_R': smb_model.root.output.solution.unit_003.solution_outlet[:,0],
					   'Cb_R': smb_model.root.output.solution.unit_003.solution_outlet[:,1] })
	data.append(df)
	filename = 'Langmuir_sim_gradient_multi_S_0_0.h5'
	smb_model = Cadet()
	smb_model.load()
	data.append(df)
	filename = 'Langmuir_sim_gradient_multi_S_0_1.h5'
	smb_model = Cadet()
	smb_model.load()
	data.append(df)
	filename = 'Langmuir_sim_gradient_multi_S_0_2.h5'
	smb_model = Cadet()
	smb_model.load()
	data.append(df)
	#plotting the problem
	plt.plot(np.concatenate((np.array(data[0]['Ca_R'][:]),np.array(data[1]['Ca_R'][:]),np.array(data[2]['Ca_R'][:]),np.array(data[3]['Ca_R'][:]))),label='Ca in Raffinate')
	plt.plot([5*4*ts,5*4*ts],[0,0.005],'--',label='First run')
	plt.plot([5*4*ts+3*4*ts,5*4*ts+3*4*ts],[0,0.005],'--',label='second run')
	plt.plot([5*4*ts+3*4*ts,5*4*ts+3*4*ts],[0,0.005],'--',label='third run')
	plt.plot([5*4*ts+3*4*ts*2,5*4*ts+3*4*ts*2],[0,0.005],'--',label='fourth run')
	plt.legend()
	plt.xlabel('Time(s)')
	plt.ylabel('Concentration')
For the non-sequential simulation, the code is:
	import pandas as pd
	#%% Functions
				if n_bound is None:
		smb_model = Cadet()
		n_comp  = 2
		## Feed
		## Eluent
		## Extract
		## Raffinate
		## Columns
		smb_model.root.input['return'].WRITE_SOLUTION_LAST = True
		n_cycles = 14
		switch_time = ts #s
		#Sections
		#Connections
			5, 6, -1, -1, Q4,
			6, 7, -1, -1, Q2,
			7, 4, -1, -1, Q2,
			0, 4, -1, -1, QF,
			1, 6, -1, -1, QD,
			4, 2, -1, -1, QR,
			6, 3, -1, -1, QE
			5,	6,	-1,	-1,	Q4,
			6,	7,	-1,	-1,	Q4,
			7,	4,	-1,	-1,	Q2,
			0,	5,	-1,	-1,	QF,
			1,	7,	-1,	-1,	QD,
			5,	2,	-1,	-1,	QR,
			7,	3,	-1,	-1,	QE
			5,	6,	-1,	-1,	Q2,
			6,	7,	-1,	-1,	Q4,
			7,	4,	-1,	-1,	Q4,
			0,	6,	-1,	-1,	QF,
			1,	4,	-1,	-1,	QD,
			6,	2,	-1,	-1,	QR,
			4,	3,	-1,	-1,	QE
			5,	6,	-1,	-1,	Q2,
			6,	7,	-1,	-1,	Q2,
			7,	4,	-1,	-1,	Q4,
			0,	7,	-1,	-1,	QF,
			1,	5,	-1,	-1,	QD,
			7,	2,	-1,	-1,	QR,
			5,	3,	-1,	-1,	QE
		#solution times
		#Time
		# Return data
		#Saving data
		smb_model.filename = 'Langmuir_sim_gradient_multi2_'+str(j)+'.h5'
		smb_model.save()
		#run model
			smb_model.load()
			print(data)
		return df
	Ka = 0.148 #l/g
	Kb = 0.11
	gamma_a = 7.7
	gamma_b = 5.72
	Nb = gamma_b/Kb
	CfA = 0.55   #g/L
	CfB = 0.55
	eps = 0.83
	ts = 180 #s
	data = []
	n_col = 80
	m2_c = 6
	m3_c = 9
	m1_min = gamma_a
	m1_c = 8.2
	m4_c = m4_max*0.5
	j=0
	plt.plot(df['Ca_R'],label='Ca in raffinate')
	plt.legend()
Please try disabling consistent initialization for all but the first simulation:
smb_model.root.input.solver.consistent_init_mode = 6 # or 7 or 0
The first simulation needs to have consistent initialization enabled!
When I implement the consistent_init_mode =0 or 6 or 7 for all but the first simulation, the error I get from the second simulation is:
CompletedProcess(args=[‘C:\Users\jespfra\Anaconda3\bin\cadet-cli’, ‘Langmuir_sim_gradient_multi_S_0_0.h5’], returncode=3, stdout=b"[Error: idasErrorHandler::200] In function ‘IDASolve’ of module ‘IDAS’, error code ‘IDA_ERR_FAIL’:\r\nAt t = 0 and h = 2.44141e-10, the error test failed repeatedly or with |h| = hmin.\r\n[Error: integrate::1367] IDASolve returned IDA_ERR_FAIL at t = 0\r\n", stderr=b’SOLVER ERROR: Error in IDASolve: IDA_ERR_FAIL at t = 0.000000\r\n’)
If I try to set the consistent_init_mode =2 or 4, the same error occurs, just at switching time (IDA_ERR_FAIL at t = 0\180s in this case).
Hey Jesper,
I’m having a difficult time trying to understand your code. Maybe we can have a call at some point. Unfortunately, we’re quite busy with preparations for our workshop next week so I hope you can wait a bit longer until I can spend more time on this.
Hey Johannes,
That is totally fine, I’ll attend the workshop myself, then maybe we find time to go through it.
It is not nicely coded, I know :smiley:
Hey Jesper,
I’m curious, did you get everything up and running?
Cheers
Hi Johannes,
It works when using CADET-process but it does not work when using CADET.
A simpler code that demonstrates it is shown below.
import pandas as pd
# from scipy.optimize import  least_squares
#%% Functions
            if n_bound is None:
def SMBmodel(Q1,Q2,Q3,Q4,QD,QE,QF,QR,ts,n_col,j,state_y,state_ydot):
    smb_model = Cadet()
    n_comp  = 2
    ## Feed
    ## Eluent
    ## Extract
    ## Raffinate
    ## Columns
    smb_model.root.input.model.unit_004.col_dispersion = 0
    if j == 0:
        #Disabling consistent initialization mode - Leweke
        # smb_model.root.input.solver.consistent_init_mode = 1
    n_cycles = 4
    switch_time = ts #s
    #Sections
    #Connections
        5, 6, -1, -1, Q4,
        6, 7, -1, -1, Q2,
        7, 4, -1, -1, Q2,
        0, 4, -1, -1, QF,
        1, 6, -1, -1, QD,
        4, 2, -1, -1, QR,
        6, 3, -1, -1, QE
        5,	6,	-1,	-1,	Q4,
        6,	7,	-1,	-1,	Q4,
        7,	4,	-1,	-1,	Q2,
        0,	5,	-1,	-1,	QF,
        1,	7,	-1,	-1,	QD,
        5,	2,	-1,	-1,	QR,
        7,	3,	-1,	-1,	QE
        5,	6,	-1,	-1,	Q2,
        6,	7,	-1,	-1,	Q4,
        7,	4,	-1,	-1,	Q4,
        0,	6,	-1,	-1,	QF,
        1,	4,	-1,	-1,	QD,
        6,	2,	-1,	-1,	QR,
        4,	3,	-1,	-1,	QE
        5,	6,	-1,	-1,	Q2,
        6,	7,	-1,	-1,	Q2,
        7,	4,	-1,	-1,	Q4,
        0,	7,	-1,	-1,	QF,
        1,	5,	-1,	-1,	QD,
        7,	2,	-1,	-1,	QR,
        5,	3,	-1,	-1,	QE
    #solution times
    #Time
    # Return data
    #Saving data
    smb_model.save()
    #run model
        smb_model.load()
        print(data)
    return df,state_y,state_ydot
Ka = 0.148 #l/g
Kb = 0.11
gamma_a = 7.7
gamma_b = 5.72
CfA = 0.55   #g/L
CfB = 0.55
eps = 0.83
ts = 180 #s
n_col = 80
m2_c = 6
m3_c = 9
m1_min = gamma_a
m1_c = 8.2
m4_c = m4_max*0.5
#The first run is run without initialization
state_y = []
state_ydot = []
for j in range(0,4):
    df,state_y,state_ydot = SMBmodel(Q1,Q2,Q3,Q4,QD,QE,QF,QR,ts,n_col,j,state_y,state_ydot)
    state_y,state_ydot = state_y,state_ydot
ts = 180
data = []
smb_model = Cadet()
smb_model.load()
data.append(df)
filename = 'Langmuir_sim_gradient_multi_1.h5'
smb_model = Cadet()
smb_model.load()
data.append(df)
filename = 'Langmuir_sim_gradient_multi_2.h5'
smb_model = Cadet()
smb_model.load()
data.append(df)
filename = 'Langmuir_sim_gradient_multi_3.h5'
smb_model = Cadet()
smb_model.load()
data.append(df)
plt.plot(np.concatenate((np.array(data[0]['Ca_R'][:]),np.array(data[1]['Ca_R'][:]),np.array(data[2]['Ca_R'][:]))))
plt.plot([4*4*ts,4*4*ts],[0,0.005],'--',label='First run')
plt.plot([4*4*ts+4*4*ts,4*4*ts+4*4*ts],[0,0.005],'--',label='second run')
plt.plot([4*4*ts+2*4*4*ts,4*4*ts+2*4*4*ts],[0,0.005],'--',label='third run')
plt.legend()
Hey Jesper,
I’m not familiar with data frames, so I modified the post processing a bit.
ts = 180
data = []
smb_model = Cadet()
smb_model.load()
Ca_E = smb_model.root.output.solution.unit_002.solution_outlet[:,0]
Cb_E = smb_model.root.output.solution.unit_002.solution_outlet[:,1]
Ca_R = smb_model.root.output.solution.unit_003.solution_outlet[:,0]
Cb_R = smb_model.root.output.solution.unit_003.solution_outlet[:,1]
smb_model = Cadet()
smb_model.load()
Ca_E = np.hstack((Ca_E, smb_model.root.output.solution.unit_002.solution_outlet[:,0]))
Cb_E = np.hstack((Cb_E, smb_model.root.output.solution.unit_002.solution_outlet[:,1]))
Ca_R = np.hstack((Ca_R, smb_model.root.output.solution.unit_003.solution_outlet[:,0]))
Cb_R = np.hstack((Cb_R, smb_model.root.output.solution.unit_003.solution_outlet[:,1]))
smb_model = Cadet()
smb_model.load()
smb_model = Cadet()
smb_model.load()
fig, ax = plt.subplots()
ax.plot(Ca_E)
The Raffinate still looks the same. So at least we know there is no issue there.
However, if we examine the Extract stream, I actually don’t think there is an issue with the initial values. Otherwise, this would look very different. Also in your Raffinate stream, the first cycle looks different than the others. So do you think it’s possible that SMB is not correctly configured yet? Where did you you get the parameters from? Do you account for non-idealities like binding kinetics, dispersion etc. in you process design?
Hey Johannes,
I dont think the parameters are the reason.
I have tried to run the example from the CADET-tutorials for SMB ( CADET-Tutorial/01_advanced_chromatography_demonstration_solution.ipynb at master · modsim/CADET-Tutorial · GitHub) with the same functions as used in the tutorials and using linear isotherm.
When I run the simulation, store initial values and run another round, it shows the same result.
The simple code is shown below (run, store values, run).
def get_cadet_template(n_units=3, split_components_data=False):
    cadet_template = Cadet()
    cadet_template.root.input.model.nunits = n_units
    # Store solution
    cadet_template.root.input['return'].split_components_data = split_components_data
    cadet_template.root.input['return'].split_ports_data = 0
    cadet_template.root.input['return'].unit_000.write_solution_inlet = 1
    cadet_template.root.input['return'].unit_000.write_solution_outlet = 1
    cadet_template.root.input['return'].unit_000.write_solution_bulk = 1
    cadet_template.root.input['return'].unit_000.write_solution_particle = 1
    cadet_template.root.input['return'].unit_000.write_solution_solid = 1
    cadet_template.root.input['return'].unit_000.write_solution_flux = 1
    cadet_template.root.input['return'].unit_000.write_solution_volume = 1
    cadet_template.root.input['return'].unit_000.write_coordinates = 1
    cadet_template.root.input['return'].unit_000.write_sens_outlet = 1
    for unit in range(n_units):
        cadet_template.root.input['return']['unit_{0:03d}'.format(unit)] = cadet_template.root.input['return'].unit_000
    cadet_template.root.input.solver.time_integrator.abstol = 1e-6
    cadet_template.root.input.solver.time_integrator.algtol = 1e-10
    cadet_template.root.input.solver.time_integrator.reltol = 1e-6
    cadet_template.root.input.solver.time_integrator.init_step_size = 1e-6
    cadet_template.root.input.solver.time_integrator.max_steps = 1000000
    # Solver settings
    cadet_template.root.input.model.solver.gs_type = 1
    cadet_template.root.input.model.solver.max_krylov = 0
    cadet_template.root.input.model.solver.max_restarts = 10
    cadet_template.root.input.model.solver.schur_safety = 1e-8
    # Run the simulation on single thread
    cadet_template.root.input.solver.nthreads = 1
    return cadet_template
            if n_bound is None:
def run_simulation(cadet, file_name=None):
    if file_name is None:
        f = next(tempfile._get_candidate_names())
        cadet.filename = os.path.join(tempfile.tempdir, f + '.h5')
        cadet.filename = file_name
    # save the simulation
    cadet.save()
    # run the simulation and load results
    data = cadet.run()
    cadet.load()
    # Remove files
        os.remove(os.path.join(tempfile.tempdir, f + '.h5'))
    # Raise error if simulation fails
        print(data)
smb_model = get_cadet_template(n_units=8)
## Feed
smb_model.root.input.model.unit_000.ncomp = 2
## Eluent
smb_model.root.input.model.unit_001.ncomp = 2
## Extract
smb_model.root.input.model.unit_002.ncomp = 2
## Raffinate
smb_model.root.input.model.unit_003.ncomp = 2
## Columns
smb_model.root.input.model.unit_004.ncomp = 2
smb_model.root.input.model.unit_004.adsorption_model = 'LINEAR'
smb_model.root.input.model.unit_004.adsorption.lin_ka = [5.72, 7.7]
smb_model.root.input.model.unit_004.adsorption.lin_kd = [1.0, 1.0]
### Discretization column settings
set_discretization(smb_model, n_col=40, n_bound=[1,1])
n_cycles = 10
switch_time = 180
# Sections
smb_model.root.input.model.unit_000.sec_000.const_coeff = [0.003,0.003]
smb_model.root.input.model.unit_001.sec_000.const_coeff = [0.0,0.0]
# Connections
    4, 5, -1, -1, 7.66e-7,
    5, 6, -1, -1, 7.66e-7,
    6, 7, -1, -1, 8.08e-7,
    7, 4, -1, -1, 8.08e-7,
    0, 4, -1, -1, 0.98e-7,
    1, 6, -1, -1, 1.96e-7,
    4, 2, -1, -1, 1.4e-7,
    6, 3, -1, -1, 1.54e-7
    4, 5, -1, -1, 8.08e-7,
    6, 7, -1, -1, 7.66e-7,
    0, 5, -1, -1, 0.98e-7,
    1, 7, -1, -1, 1.96e-7,
    5, 2, -1, -1, 1.4e-7,
    7, 3, -1, -1, 1.54e-7
    5, 6, -1, -1, 8.08e-7,
    7, 4, -1, -1, 7.66e-7,
    0, 6, -1, -1, 0.98e-7,
    1, 4, -1, -1, 1.96e-7,
    6, 2, -1, -1, 1.4e-7,
    4, 3, -1, -1, 1.54e-7
    0, 7, -1, -1, 0.98e-7,
    1, 5, -1, -1, 1.96e-7,
    7, 2, -1, -1, 1.4e-7,
    5, 3, -1, -1, 1.54e-7
#set the times that the simulator writes out data for
# Run simulation and plot results
smb_model.filename = 'Johannes.h5'
smb_model.save()
#run model
    smb_model.load()
    print(data)
#Run the same model the 2nd time
smb_model1 = get_cadet_template(n_units=8)
## Feed
smb_model1.root.input.model.unit_000.unit_type = 'INLET'
smb_model1.root.input.model.unit_000.ncomp = 2
smb_model1.root.input.model.unit_000.inlet_type = 'PIECEWISE_CUBIC_POLY'
## Eluent
smb_model1.root.input.model.unit_001.unit_type = 'INLET'
smb_model1.root.input.model.unit_001.ncomp = 2
smb_model1.root.input.model.unit_001.inlet_type = 'PIECEWISE_CUBIC_POLY'
## Extract
smb_model1.root.input.model.unit_002.ncomp = 2
smb_model1.root.input.model.unit_002.unit_type = 'OUTLET'
## Raffinate
smb_model1.root.input.model.unit_003.ncomp = 2
smb_model1.root.input.model.unit_003.unit_type = 'OUTLET'
## Columns
smb_model1.root.input.model.unit_004.unit_type = 'LUMPED_RATE_MODEL_WITHOUT_PORES'
smb_model1.root.input.model.unit_004.ncomp = 2
smb_model1.root.input.model.unit_004.col_dispersion = 3.8148E-20
smb_model1.root.input.model.unit_004.col_length = 0.25
smb_model1.root.input.model.unit_004.total_porosity = 0.83
smb_model1.root.input.model.unit_004.velocity = 1
smb_model1.root.input.model.unit_004.cross_section_area = 3.141592653589793E-4
smb_model1.root.input.model.unit_004.adsorption_model = 'LINEAR'
smb_model1.root.input.model.unit_004.adsorption.is_kinetic = 0
smb_model1.root.input.model.unit_004.adsorption.lin_ka = [5.72, 7.7]
smb_model1.root.input.model.unit_004.adsorption.lin_kd = [1.0, 1.0]
# smb_model1.root.input.model.unit_004.init_c = [0.0,0.0]
# smb_model1.root.input.model.unit_004.init_q = [0.0,0.0]
smb_model1.root.input.model.init_state_y = state_y
smb_model1.root.input.model.init_state_ydot = state_ydot
smb_model1.root.input.model.unit_005 = smb_model1.root.input.model.unit_004
smb_model1.root.input.model.unit_006 = smb_model1.root.input.model.unit_004
smb_model1.root.input.model.unit_007 = smb_model1.root.input.model.unit_004
set_discretization(smb_model1, n_col=40, n_bound=[1,1])
smb_model1.root.input['return'].write_solution_last = True
n_cycles = 10
switch_time = 180
# Sections
smb_model1.root.input.solver.sections.nsec = 4*n_cycles
smb_model1.root.input.solver.sections.section_times = [0]
    smb_model1.root.input.solver.sections.section_times.append((4*i+1)*switch_time)
    smb_model1.root.input.solver.sections.section_times.append((4*i+2)*switch_time)
    smb_model1.root.input.solver.sections.section_times.append((4*i+3)*switch_time)
    smb_model1.root.input.solver.sections.section_times.append((4*i+4)*switch_time)
smb_model1.root.input.model.unit_000.sec_000.const_coeff = [0.003,0.003]
smb_model1.root.input.model.unit_001.sec_000.const_coeff = [0.0,0.0]
# Connections
smb_model1.root.input.model.connections.nswitches = 4
smb_model1.root.input.model.connections.switch_000.section = 0
smb_model1.root.input.model.connections.switch_000.connections = [
smb_model1.root.input.model.connections.switch_001.section = 1
smb_model1.root.input.model.connections.switch_001.connections = [
smb_model1.root.input.model.connections.switch_002.section = 2
smb_model1.root.input.model.connections.switch_002.connections = [
smb_model1.root.input.model.connections.switch_003.section = 3
smb_model1.root.input.model.connections.switch_003.connections = [
smb_model1.root.input.solver.user_solution_times = np.linspace(0, n_cycles*4*switch_time, int(n_cycles*4*switch_time))
smb_model1.filename = 'Johannes1.h5'
smb_model1.save()
#run model
data = smb_model1.run()
    smb_model1.load()
    print(data)
plt.figure()
plt.plot(np.concatenate((np.array(smb_model.root.output.solution.unit_002.solution_outlet[:,1]),np.array(smb_model1.root.output.solution.unit_002.solution_outlet[:,1])),axis=0))
plt.ylabel('Concentration (mM)')
plt.title('Extract')
plt.figure()
plt.plot(np.concatenate((np.array(smb_model.root.output.solution.unit_003.solution_outlet[:,0]),np.array(smb_model1.root.output.solution.unit_003.solution_outlet[:,0])),axis=0))
# plt.plot(np.concatenate((np.array(smb_model.root.output.solution.unit_003.solution_outlet[:,1]),np.array(smb_model1.root.output.solution.unit_003.solution_outlet[:,1])),axis=0))
plt.title('Raffinate')
For those interested.
I found a mistake in the SMB setup.
I had switched around the extract and raffinate in the flows.
Maybe it should be corrected in the tutorial for the SMB as well?
Below is the corrected code for the tutorial example above.
However, it does not solve the issue.
    # Store solution
    # Solver settings
            if n_bound is None:
    cadet.save()
    data = cadet.run()
    cadet.load()
    # Remove files
        print(data)
## Feed
## Eluent
## Extract
## Raffinate
## Columns
n_cycles = 10
switch_time = 180
# Sections
# Connections
    4, 3, -1, -1, 1.4e-7,
    6, 2, -1, -1, 1.54e-7
    5, 3, -1, -1, 1.4e-7,
    7, 2, -1, -1, 1.54e-7
    6, 3, -1, -1, 1.4e-7,
    4, 2, -1, -1, 1.54e-7
    7, 3, -1, -1, 1.4e-7,
    5, 2, -1, -1, 1.54e-7
smb_model.save()
#run model
    smb_model.load()
    print(data)
## Feed
## Eluent
## Extract
## Raffinate
## Columns
n_cycles = 10
switch_time = 180
# Sections
# Connections
smb_model1.save()
#run model
    smb_model1.load()
    print(data)
plt.figure()
plt.plot(np.concatenate((np.array(smb_model.root.output.solution.unit_002.solution_outlet[:,0]),np.array(smb_model1.root.output.solution.unit_002.solution_outlet[:,0])),axis=0))
plt.figure()
