Dev branch pip install not working
Hi Cadet Team ,
pip uninstall cadet-process
I recently ran the above pip install commands as part of my fortnightly update of my CADET-Process dev branch. Normally this all works fine but despite a “successfully installed” message in miniforge prompt it appears that none of the folder scripts like “fractionation” have copied into the CADET-Process folder in site packages within the environment (See attached image). This hasn’t happened to me before and a little lost on how to fix !
Thanks
I ran into the same issue installing the dev branch directly from github. I ended up cloning the branch locally and installing it from local in editable mode with pip install -e <path_to_cadet_process_dir>. Maybe something with the pyproject.toml changed?
Interesting, thanks for reporting this!
we actually did migrate from setup.cfg to pyproject.toml a while ago but I had forgotten to delete the setup.cfg file :see_no_evil: which I then did a couple of weeks ago. I’ll have to investigate it.
Could you please try the following:
pip install git+https://github.com/fau-advanced-separations/CADET-Process.git@fix_pyproject.toml
I can confirm that this resolves the issue for me at least. Thanks for the quick response!
Thanks for testing. I merged into dev so that should hopefully work again.
Hopefully, this week we can make the following releases
  • CADET-Core v5.0.2
  • CADET-Python v1.0.2
  • CADET-Process v0.10.0
This should fix quite some minor annoyances that have accumulated. Hopefully, in future we can make more regular and smaller releases.
Could you advise on the best way to install the ax platform currently when using the dev branch ? Is th below yml file appropriate?
channels:
  - conda-forge
dependencies:
  - python=3.11  # currently recommended for cadet-process installations
  - pip
  - cadet
  - jupyterlab  # optional, to run jupyter notebooks
  - openpyxl    # optional, to open .xlsx files
#  - git         # optional, for version control
  - pip:
      - git+https://github.com//fau-advanced-separations/CADET-Process.git@dev
      - cadet-process[ax]
