Difference in colloidal isotherm behavior between v4.4 and v5.0
We’ve observed a difference in the behavior of our model with the colloidal isotherm when switching from cadet v4.4 to 5.0. To try to make sure it wasn’t coming from anything else, I set up the same model with the multicomponent Langmuir model and some dummy parameters, but the difference in the output chromatograms only showed up with the colloidal isotherm.
The script I used to generate the figures is copied below. The only thing I’ve changed is whether the Langmuir or colloidal isotherm is used and whether the cadet_bin_path references the environment where I have cadet 4.4.0 or 5.0.0 installed.
I realize the colloidal isotherm wasn’t official before, but does this mean that the previous version was in some way incorrect?
Code below:
# -*- coding: utf-8 -*-
Inlet > column > outlet with GRM and colloidal isotherm.
import platform
from pathlib import Path
def cadet_config(cadet_bin_path, binding):
    print('\nCADET simulation running!\n')
    set_CADET_path(cadet_bin_path)
    # Create model object
    model = Cadet()
    # Number of unit operations
    n_comp = 2
    init_c = [1e3*10**(-7.4), 0]
    # Inlet ####################################################################
    model.root.input.model.unit_000.ncomp = n_comp
    model.root.input.model.unit_000.sec_000.const_coeff = [1e3*10**(-7.4), 0.0338]
    model.root.input.model.unit_000.sec_001.const_coeff = [1e3*10**(-7.4), 0]
    model.root.input.model.unit_000.sec_002.const_coeff = [1e3*10**(-3.5), 0]
    # General Rate Model #######################################################
    model.root.input.model.unit_001.unit_type = 'GENERAL_RATE_MODEL'
    model.root.input.model.unit_001.ncomp = n_comp
    model.root.input.model.unit_001.init_c = init_c
    model.root.input.model.unit_001.init_cp = init_c
    model.root.input.model.unit_001.init_q = [0, 0]
    ## Geometry
    model.root.input.model.unit_001.col_length = 0.018
    model.root.input.model.unit_001.cross_section_area = 1.963e-05
    model.root.input.model.unit_001.col_porosity = 0.4
    model.root.input.model.unit_001.par_porosity = 0.92
    model.root.input.model.unit_001.par_radius = 0.5*5.41e-05
    ## Transport
    model.root.input.model.unit_001.col_dispersion = [1.80e-08, 1.80e-08, 1.80e-08, 1.80e-08]
    model.root.input.model.unit_001.film_diffusion = [[0.00011, 0.00011, 0.00011, 0.00011], [1.32e-05, 1.32e-05, 1.32e-05, 1.32e-05]]
    model.root.input.model.unit_001.par_diffusion = [8.85e-10, 1.54e-12]
    model.root.input.model.unit_001.adsorption.is_kinetic = True
    model.root.input.model.unit_001.discretization.ncol = 100
    model.root.input.model.unit_001.discretization.npar = 40
    ## Adsorption
    if binding=='Langmuir':
        model.root.input.model.unit_001.adsorption_model = 'MULTI_COMPONENT_LANGMUIR'
        model.root.input.model.unit_001.adsorption.is_kinetic = True    # Kinetic binding
        model.root.input.model.unit_001.adsorption.mcl_ka = [0, 0.2]      # m^3 / (mol * s)   (mobile phase)
        model.root.input.model.unit_001.adsorption.mcl_kd = [0, 1.0]      # 1 / s (desorption)
        model.root.input.model.unit_001.adsorption.mcl_qmax = [0, 300.0,]  # mol / m^3   (solid phase)
    #### Colloidal
    elif binding=='colloidal':
        model.root.input.model.unit_001.adsorption_model = 'MULTI_COMPONENT_COLLOIDAL'
        model.root.input.model.unit_001.adsorption.col_phi = 591000000.0
        model.root.input.model.unit_001.adsorption.col_kappa_exp = 0
        model.root.input.model.unit_001.adsorption.col_kappa_fact = 0
        model.root.input.model.unit_001.adsorption.col_kappa_const = 4
        model.root.input.model.unit_001.adsorption.col_cordnum = 6
        model.root.input.model.unit_001.adsorption.col_logkeq_ph_exp = [0] * n_comp
        model.root.input.model.unit_001.adsorption.col_logkeq_salt_powexp = [0] * n_comp
        model.root.input.model.unit_001.adsorption.col_logkeq_salt_powfact = [0] * n_comp
        model.root.input.model.unit_001.adsorption.col_logkeq_salt_expfact = [0, 30.6]
        model.root.input.model.unit_001.adsorption.col_logkeq_salt_expargmult = [0, -20.9]
        model.root.input.model.unit_001.adsorption.COL_BPP_PH_EXP = [0] * n_comp
        model.root.input.model.unit_001.adsorption.COL_BPP_SALT_POWEXP = [0, -0.152]
        model.root.input.model.unit_001.adsorption.COL_BPP_SALT_POWFACT = [0, 5.73]
        model.root.input.model.unit_001.adsorption.COL_BPP_SALT_EXPFACT = [0] * n_comp
        model.root.input.model.unit_001.adsorption.COL_BPP_SALT_EXPARGMULT = [0] * n_comp
        model.root.input.model.unit_001.adsorption.col_radius = [1.78e-10, 4.488e-09]
        model.root.input.model.unit_001.adsorption.col_kKin = [1e8] * n_comp
        model.root.input.model.unit_001.adsorption.COL_LINEAR_THRESHOLD = 1e-8
        model.root.input.model.unit_001.adsorption.COL_USE_PH = False
    model.root.input.model.unit_001.discretization.nbound = [0, 1]
    model.root.input.model.unit_001.discretization.use_analytic_jacobian = 0
    model.root.input.model.unit_001.discretization.schur_safety = 1e-8
    ## Outlet Model ############################################################
    model.root.input.model.unit_002.ncomp = n_comp
    # Sections
    model.root.input.solver.sections.nsec = 3
    model.root.input.solver.sections.section_times = [0.0, 1440.4, 2040.4, 2640.4]   # s
    model.root.input.solver.sections.section_continuity = [0, 0, 0]
    # units: inlet > Column > Outlet
    # Switches
       0, 1, -1, -1, 2.95e-09,  # [unit_000, unit_002, all components, all components, Q/ m^3*s^-1
       1, 2, -1, -1, 2.95e-09,  # [unit_002, unit_004, all components, all components, Q/ m^3*s^-1
    # Solver settings
    model.root.input.solver.nthreads = 4
    model.root.input.solver.time_integrator.abstol = 1e-8
    model.root.input.solver.time_integrator.algtol = 1e-12
    # Return data
    # dont return data except for outlet unit
    model.root.input['return'].split_components_data = 0
    model.root.input['return'].unit_000.write_solution_bulk = 0
    model.root.input['return'].unit_000.write_solution_inlet = 1
    model.root.input['return'].unit_000.write_solution_outlet = 0
    model.root.input['return'].unit_001.write_solution_bulk = 0
    model.root.input['return'].unit_001.write_solution_inlet = 0
    model.root.input['return'].unit_001.write_solution_outlet = 0
    # return outlet data for outlet unit
    model.root.input['return'].unit_002.write_solution_bulk = 0
    model.root.input['return'].unit_002.write_solution_inlet = 0
    model.root.input['return'].unit_002.write_solution_outlet = 1
    # Solution times
    model.root.input.solver.user_solution_times = np.linspace(0, 2640.4, 5000)
    # Save and run simulation
    model.filename = 'cadet_version_check.h5'
    model.save()
    data = model.run()
    if data.returncode == 0:
         model.load()
         print(data)
         raise Exception('Simulation failed')
    sim_solution = model.root.output.solution
    return sim_solution
def set_CADET_path(cadet_bin_path):
    if platform.system() == 'Windows':
        cadet_path = cadet_bin_path / 'cadet-cli.exe'
        lwe_path = cadet_bin_path / 'createLWE.exe'
         cadet_path = cadet_bin_path / 'cadet-cli'
         lwe_path = cadet_bin_path / 'createLWE'
    if cadet_path.exists() and lwe_path.exists():
        Cadet.cadet_path = cadet_path.as_posix()
    elif cadet_path.exists() and not lwe_path.exists():
        print('CADET was found but createLWE.exe was not found. Please make sure that none of the files have been moved.')
        print('CADET could not be found. Please check the bin path')
def compare(cadet_bin_path, binding):
    CADET_solution = cadet_config(cadet_bin_path, binding)
    CADET_time = CADET_solution.solution_times
    inlet_array = CADET_solution.unit_000.solution_inlet
    CADET_solution_array = CADET_solution.unit_002.solution_outlet
    CADET_protein = CADET_solution_array.T[1]
    fig, ax = plt.subplots()
    ax.plot(CADET_time/60, CADET_solution_array, linewidth=1, color='k')
    # ax.plot(CADET_time/60, CADET_protein, linewidth=1, color='k')
if __name__=='__main__':
    cadet_bin_path = Path('/Users/angelamoser/miniconda3/envs/cadet4-env/bin')
    compare(cadet_bin_path, binding='colloidal')
Good catch, thanks for the report. I’ll look into it.
Ah, yes, now I remember :smiley:
We did change it and didn’t list the change because the isotherm was a “new” addition in v5. Sorry about that. I hope it didn’t eat too much of your time.
Here are the changes, you can see them in the src/libcadet/model/binding/ColloidalBinding.cpp file in this PullRequest
  1. Renamed COL_RADIUS to COL_PROTEIN_RADIUS
  2. Fixed kappa factors not adhering to SI units by changing it from \kappa = \frac{10^9}{\kappa_f c_0^{\kappa_e} + \kappa_c} to \kappa = \frac{1}{\kappa_f c_0^{\kappa_e} + \kappa_c}. So you’ll need to adapt your COL_KAPPA_FACT and COL_KAPPA_CONST by 10^9.
  3. Fixed a bug in the analytical Jacobian, so it works now and can speed up the simulation time if enabled.
Good to know, thanks. Got the expected results after changing the kappa units. :+1:
