Hello All,
I was trying to simualte injection of dextrane to a column like Dextran pulse excise. I get an error like this.
“CompletedProcess(args=[‘c:/cadet/bin/cadet-cli.exe’, ‘model.h5’], returncode=3221225477, stdout=b’‘, stderr=b’')”
The errror message is simple. Anyone has some hints for me? Thanks !
Cadet.cadet_path = 'c:/cadet/bin/cadet-cli.exe'
model = Cadet()
model.root.input.model.unit_000.ncomp = 1
model.root.input.model.unit_001.unit_type = 'LUMPED_RATE_MODEL_WITH_PORES'
# Geometry
model.root.input.model.unit_001.col_length = 0.6 # col len in m
model.root.input.model.unit_001.cross_section_area = 1.e-4 # CX section area in m2
model.root.input.model.unit_001.col_porosity = 0.37 # col porosity
model.root.input.model.unit_001.par_porosity = 0.33 # particle or bead porosity
model.root.input.model.unit_001.par_radius = 4.5e-5 # particle or bead radius
## Transport
model.root.input.model.unit_001.col_dispersion = 2.0e-7 # m^2 / s (interstitial volume)
model.root.input.model.unit_001.film_diffusion = [0.0] # m / s
model.root.input.model.unit_001.init_c = [0.0,]
model.root.input.model.unit_002.ncomp = 1
### Grid cells
model.root.input.model.unit_001.discretization.ncol = 100
model.root.input.model.unit_001.discretization.npar = 5
model.root.input.model.unit_001.discretization.npartype = 1
### Bound states
model.root.input.model.unit_001.discretization.nbound = 3*[0]
### Other options
model.root.input.solver.sections.nsec = 2
model.root.input.solver.sections.section_times = [0.0, 50, 1200,] # s
model.root.input.solver.sections.section_continuity = []
## Inlet Profile
model.root.input.model.unit_000.sec_000.const_coeff = [1.0,] # mol / m^3
## Switches
0, 1, -1, -1, 1e-7, # [unit_000, unit_001, all components, all components, Q/ m^3*s^-1
1, 2, -1, -1, 1e-7] # [unit_001, unit_002, all components, all components, Q/ m^3*s^-1
# Return data
model.root.input['return'].split_components_data = True
model.root.input['return'].unit_000.write_solution_bulk = 1
model.root.input['return'].unit_000.write_solution_inlet = 1
#set the times that the simulator writes out data for
model.root.input.solver.user_solution_times = np.linspace(0, 1200, 1001)
model.filename = 'model.h5'
model.save()
data = model.run()
if data.returncode == 0:
print("Simulation completed successfully")
model.load()
print(data)
raise Exception("Simulation failed")
model.save()
data = model.run()
model.load()
print(data)
CompletedProcess(args=['c:/cadet/bin/cadet-cli.exe', 'model.h5'], returncode=3221225477, stdout=b'', stderr=b'')
Exception Traceback (most recent call last)
~\AppData\Local\Temp\ipykernel_11896\2242269908.py in <module>
9 else:
10 print(data)
---> 11 raise Exception("Simulation failed")
Exception: Simulation failed
