Error when setting recording solid-phase conc in CADET-Process
I’m running CADET-Process and trying to get solid-phase concentrations on the resin using the General Rate Model. However, when I set column.solution_recorder.write_solution_solid = False column.solution_recorder.write_solution_solid = True the simulation fails with the error shown below.
A brief snippet of my code:
grm_discretization = GRMDiscretizationFV()
grm_discretization.npar = NPAR_VALUE # This sets an appropriate number of particle shells
column.discretization = grm_discretization # This attaches the above discretization scheme
column.solution_recorder.write_solution_bulk = True
column.solution_recorder.write_solution_particle = True
Interesting that column.solution_recorder.write_solution_particle = True works, because the size of the array should be the same as write_solution_solid(see error message above).
Anyone face this issue?
S.
Made a typo:
Simulation fails when column.solution_recorder.write_solution_solid = True
Hi, thanks for reporting,
please provide a working minimum reproducible example so that we can easily debug your issue.
Here it is! Slightly delayed, but the problem still persists :slight_smile:
import sys, glob
import pandas as pd
from itertools import cycle
import time
from CADETProcess.processModel import MultiComponentColloidal
from CADETProcess.processModel import Inlet, GeneralRateModel, Outlet, GRMDiscretizationFV
from CADETProcess.processModel import Process, solutionRecorder
from CADETProcess.processModel import LumpedRateModelWithoutPores
""" EXPERIMENTAL INPUTS _________________________________________________ """
MODEL_CADET = True
# Load description
VOL_LOAD = 12.5 #mL
C_LOAD = 12. # Load total concentration in g/L
HMW1_LOAD_PERCENT = 2.4 #2.4 # Small HMW (oligo)
HMW2_LOAD_PERCENT = 2.8 #3.5 # Large HMW
C_SALT = 100+17 # mM
# System description
COL_VOL = 0.7 # Column volume (mL)
DEAD_VOL = 0.25 #mL
# Process description
FLOWRATE = 0.18 # mL/min
COLVOL_WASH = 10
COLVOL_GRAD = 10
# UV-300 to concentration calibration curve: abs = a*conc
calibration_const_a = 40 # mAu / (mg/mL)
#Other
HMW_SCALE_FACTOR = 20
""" EXPERIMENTAL SECTION _________________________________________________ """
# Select chromatogram(s) to analyze by index
keep_idx = [0]
# Color cycle (matplotlib default)
color_list = plt.rcParams['axes.prop_cycle'].by_key()['color']
color_cycle = cycle(color_list)
# Create figure with twin axes
fig, ax1 = plt.subplots(figsize=(10,6))
ax2 = ax1.twinx()
# Gather CSV files and pick selected ones
files = sorted(glob.glob("*.csv"))
selected_files = [files[i] for i in keep_idx if 0 <= i < len(files)]
missing = [i for i in keep_idx if not (0 <= i < len(files))]
if missing:
    print(f"Skipping out-of-range indices: {missing}")
""" *** CADET AND CHROMATOGRAPHY MODELING SECTION ************************* """
""" USER INPUTS ___________________________________________________________ """
mab_molecular_weight = 150 #kDa
load_conc = C_LOAD # g/L
column_length = 0.1 # m
column_dia = 0.003  # m
# Resin
column_porosity = 0.4
particle_porosity = 0.65
particle_diameter = 75E-6 # m
c_mab = 0.01*C_LOAD*(100-HMW1_LOAD_PERCENT-HMW2_LOAD_PERCENT)/mab_molecular_weight
c_hmw1 = 0.01*C_LOAD*HMW1_LOAD_PERCENT/mab_molecular_weight
c_hmw2 = 0.01*C_LOAD*HMW2_LOAD_PERCENT/mab_molecular_weight
c_load_array = np.array([C_SALT, c_mab, c_hmw1, c_hmw2])
""" CADET PROCESS MODEL ___________________________________________________ """
# Component System
component_system.add_component('mAb')
component_system.add_component('HMW 1')
component_system.add_component('HMW 2')
# Binding Model
binding_model = MultiComponentColloidal(component_system, name='Colloidal')
binding_model.bound_states = [0, 1, 1, 1]
binding_model.kappa_factor = 0 #k_f
binding_model.kappa_exponential = 0 #k_ef
binding_model.kappa_constant = 4.0E-9 # k_c, m
# ln Ke_i = ka_i * c0^(-kb_i) + kc_i * exp(kd_i * c0)
binding_model.logkeq_power_factor      = [ 0, 3.5, 5.75, 5.5]   # k_a,i
binding_model.logkeq_power_exponent    = [ 0,  0, 0, 0]   # k_b,i
binding_model.logkeq_exponent_factor   = [ 0,  0, 0, 0]   # k_c,i
binding_model.logkeq_exponent_multiplier=[ 0,  0, 0, 0]   # k_d,i
binding_model.logkeq_ph_exponent       = [ 0,  0, 0, 0]   # set nonzero if using pH pseudo-comp
# b_pp,i = ba_i * c0^(bb_i) + bc_i * exp(bd_i * c0)
binding_model.bpp_power_factor         = [ 1,  0.5, 0.5, 0.5]   # b_a,i
binding_model.bpp_power_exponent       = [ 0,  0, 0, 0]   # b_b,i
binding_model.bpp_exponent_factor      = [ 0,  0, 0, 0]   # b_c,i
binding_model.bpp_exponent_multiplier  = [ 0,  0, 0, 0]   # b_d,i
binding_model.bpp_ph_exponent          = [ 0,  0, 0, 0]   # set if modeling pH dependence
binding_model.use_ph = False             # True if you add a pH pseudo-component (component 1)
binding_model.phase_ratio = 4.5e7           # example; tune to your resin
binding_model.coordination_number = 6
binding_model.protein_radius = [1.59e-9, 4.5e-9, 4.5e-9, 4.5e-9]
binding_model.kinetic_rate_constant = [1e10, 1e10, 1e10, 1e10]    # 1/s
binding_model.linear_threshold = 1e-7               # mol/m^3
# Unit Operations
inlet.flow_rate = FLOWRATE/(1000000*60) # m^3/s
column.binding_model        = binding_model
column.length               = column_length
column.diameter             = column_dia
column.bed_porosity         = column_porosity
column.particle_radius      = particle_diameter
column.particle_porosity    = particle_porosity
column.axial_dispersion     = 1e-6
column.film_diffusion       = column.n_comp * [1e-4]
Dp_mAb = 6.0E-12
column.pore_diffusion       = [7e-10, Dp_mAb, Dp_mAb/6, Dp_mAb/12]
column.surface_diffusion    = [4*50E-14, 1*7E-14, 1*7E-14]
column.c =  [C_SALT, 0, 0, 0]
column.cp = [C_SALT, 0, 0, 0]
column.q =  [0, 0, 0]
grm_discretization.npar = 30 # This sets an appropriate number of particle shells
grm_discretization.ncol = 50 # This sets an appropriate number of column slices
# --- New: PFR for tubing ---
pfr = LumpedRateModelWithoutPores(component_system, name='pfr_tubing')
pfr.length = 1.1      # [m] example tubing length
pfr.diameter = 0.0005  # [m] example ID
pfr.axial_dispersion = 1e-6  # small dispersion; adjust as needed
pfr.total_porosity = 0.99
""" CADET PROCESS FLOWSHEET AND RUN _______________________________________ """
#flow_sheet.add_unit(pfr)
#flow_sheet.add_connection(inlet, pfr)
#flow_sheet.add_connection(pfr, column)
load_duration = 60*VOL_LOAD/FLOWRATE
wash_duration = 60*COL_VOL*COLVOL_WASH/FLOWRATE
t_gradient_start = load_duration + wash_duration
gradient_duration = 60*COL_VOL*COLVOL_GRAD/FLOWRATE
process.cycle_time = load_duration + wash_duration + gradient_duration
c_load = c_load_array
c_wash = np.array([C_SALT, 0.0, 0.0, 0.0])
c_elute = np.array([500.0, 0.0, 0.0, 0.0])
gradient_slope = (c_elute - c_wash) / gradient_duration
process.add_event('load', 'flow_sheet.inlet.c', c_load)
process.add_event('wash', 'flow_sheet.inlet.c', c_wash, load_duration)
process.add_event('grad_start', 'flow_sheet.inlet.c', c_gradient_poly, t_gradient_start)
start_time = time.perf_counter()
if MODEL_CADET == True:
    print("Running the chromatography model...")
    if __name__ == '__main__':
    end_time = time.perf_counter()
    # Extract solution data in dedicated arrays
    solution_time   = simulation_results.solution.column.outlet.coordinates['time']
    solution_mL     = solution_time*inlet.flow_rate[0]*1000*1000 + DEAD_VOL #mL
    solution_salt   = simulation_results.solution.column.outlet.total_concentration_components[:,0]
    solution_cond = solution_salt*0.103 # mS/cm
    solution_mab    = simulation_results.solution.column.outlet.total_concentration_components[:,1]
    solution_hmw1   = simulation_results.solution.column.outlet.total_concentration_components[:,2]
    solution_hmw2   = simulation_results.solution.column.outlet.total_concentration_components[:,3]
    solution_total = solution_mab + solution_hmw1+solution_hmw2
    ax1.plot(solution_mL, mab_molecular_weight*solution_mab, 'b--', linewidth=2)
    ax1.plot(solution_mL, HMW_SCALE_FACTOR*mab_molecular_weight*solution_hmw1, 'y--', linewidth=2)
    ax1.plot(solution_mL, HMW_SCALE_FACTOR*mab_molecular_weight*solution_hmw2, 'r--', linewidth=2)
    ax1.plot(solution_mL, mab_molecular_weight*solution_total, 'k--', linewidth=4)
    ax2.plot(solution_mL, solution_cond, linewidth=2, color = 'grey')
    ax1.set_xlim(0, 25)
    ax1.set_ylim(0, 15)
    print("Skipping to run the chromatography model. Only plots.")
# Finalize plot
plt.title("")
fig.tight_layout()
elapsed_time = end_time - start_time
print(f"Solver time: {elapsed_time:.4f} seconds")
EDIT: I just now saw, that you corrected yourself later and your solution fails with column.solution_recorder.write_solution_solid = True. This also fails for me with v0.11.1, however you will be happy to hear the issue is already fixed on the latest dev branch. :slight_smile: You can either pull the latest CADET-Process version from there, if you need it immediately or wait until v0.12.0 is released, which is in planning but might take a few weeks still.
Hi sov_2024,
Thanks for providing the code!
Could you check which version of CADET-Process you are using? It would also be helpful if you could share a list of your environment packages.
For me, your code runs without issues when setting column.solution_recorder.write_solution_solid = False, both with CADET-Process v0.11.1 and with the latest dev branch.
