I am new here in this forum, beginner in cadet. I have completed all the tutorials of Cadet (Python based) and now moved to cadet match. Getting error in Lesson 8 cadet match tutorial. I am using in macOS.
Error screen shot attached herewith. Please someone help this regard.
Thank you
Hey,
could you please post the entire error message or even the entire script?
please see complete script (Lesson:8 Cadet match). Sorry for the delay.
#Example: Automatic determination of porosity and axial dispersion of a Column
%run ../utils.ipynb
from addict import Dict
base_dir = Path('./').absolute()
match_config = Dict()
match_config.CADETPath = Cadet.cadet_path
match_config.baseDir = base_dir.as_posix()
match_config.resultsDir = 'results'
dextran_model = create_dextran_model()
run_simulation(dextran_model, 'dextran_reference.h5')
parameter1 = Dict()
parameter1.location = '/input/model/unit_001/COL_DISPERSION'
parameter1.min = 1e-10
parameter1.max = 1e-6
parameter1.component = -1
parameter1.bound = -1
parameter1.transform = 'null'
parameter2 = Dict()
parameter2.location = '/input/model/unit_001/COL_POROSITY'
parameter2.min = 0.2
parameter2.max = 0.7
parameter2.component = -1
parameter2.bound = -1
parameter2.transform = 'null'
match_config.parameters = [parameter1, parameter2]
experiment1 = Dict()
experiment1.name = 'dextran'
experiment1.csv = '../resources/dextran_experiment.csv'
experiment1.HDF5 = 'dextran_reference.h5'
experiment1.output_path = '/output/solution/unit_002/SOLUTION_OUTLET_COMP_000'
match_config.experiments = [experiment1,]
feature1 = Dict()
feature1.name = "Pulse"
feature1.type = 'SSE'
experiment1.features = [feature1,]
match_config.searchMethod = 'NSGA3'
match_config.population = 12
match_config.stallGenerations = 10
match_config.finalGradRefinement = True
match_config.gradVector = True
#Saving the config and running the optimization
from CADETMatch.jupyter import Match
match_config_file = base_dir / 'dextran.json'
with open(match_config_file.as_posix(), 'w') as json_file:
json.dump(match_config.to_dict(), json_file, indent='\t')
match = Match(match_config_file)
match.start_sim()
#Create corner plots
match.plot_corner()
#Best plots
match.plot_best()
Please have a look. @j.schmoelder
Thank you
Hey,
sorry for the late reply, I was travelling. I will have a look later.
Ok, I think I found the issue. If you look at the error message, it says:
----> 6 json.dump(match_config.to_dict(), json_file, indent='\t')
TypeError: Object of type PosixPath is not JSON serializable
So what I did next was to check the contents of match_config. This is the output when i print it:
{'CADETPath': PosixPath('/opt/tljh/user/bin/cadet-cli'),
'baseDir': '/home/jupyter-j.schmoelder/cadet-tutorial/08_CADET-Match_Introduction',
'resultsDir': 'results',
'parameters': [{'location': '/input/model/unit_001/COL_DISPERSION',
'min': 1e-10,
'max': 1e-06,
'component': -1,
'bound': -1,
'transform': 'null'},
{'location': '/input/model/unit_001/COL_POROSITY',
'min': 0.2,
'max': 0.7,
'component': -1,
'bound': -1,
'transform': 'null'}],
'experiments': [{'name': 'dextran',
'csv': '../resources/dextran_experiment.csv',
'HDF5': 'dextran_reference.h5',
'output_path': '/output/solution/unit_002/SOLUTION_OUTLET_COMP_000',
'features': [{'name': 'Pulse', 'type': 'SSE'}]}],
'searchMethod': 'NSGA3',
'population': 12,
'stallGenerations': 10,
'finalGradRefinement': True,
'gradVector': True}
Here you can see that actually, the cadet path seems to be the culprit. If you convert it to a proper path, it runs:
match_config.CADETPath = Cadet.cadet_path.as_posix()
Once again, sorry it took so long!
It’s working now by changing path. Thank you for your help. I got the results.
