p.ho
July 16, 2020, 8:33am
1
Hi guys,
a newbie here. I have a a problem running a CADET file (on windows), giving the error message “Exception: Simulation failed”. Do you need any more specific information to give me a clue how to solve it?
I am grateful for any advice. Thank you in advance for your help!
Phuong
Hey Phuong, could you maybe also post the error message and the return code?
p.ho
July 16, 2020, 9:40am
4
Hi, Jo. Yes:
runfile('//ibt014/ho/Project PhD (FZJ)/05_Simulations/Compartment_model/compartment-model/driver.py', wdir='//ibt014/ho/Project PhD (FZJ)/05_Simulations/Compartment_model/compartment-model')
Reloaded modules: compartment_simple
CompletedProcess(args=['\\\\ibt014\\ho\\Project PhD (FZJ)\\05_Simulations\\Compartment_model\\cadet\\bin\\cadet-cli.exe', 'C:/Users/ho/compartment.h5'], returncode=3221225781, stdout=b'', stderr=b'')
File "\\ibt014\ho\Project PhD (FZJ)\05_Simulations\Compartment_model\compartment-model\driver.py", line 21, in <module>
results = run_model(cadet, file_name=filename.as_posix())
File "\\ibt014\ho\Project PhD (FZJ)\05_Simulations\Compartment_model\compartment-model\compartment_simple.py", line 208, in run_model
raise Exception("Simulation failed")
I do suspect that the issue lies with the path of the file name.
Please try the following in the driver:
from pathlib import Path
file_name = Path('./compartment.h5')
results = run_model(cadet, file_name=file_name.as_posix())
make sure that the run method looks like this:
def run_model(cadet, file_name):
cadet.filename = file_name
cadet.save()
# run the simulation
data = cadet.run()
if data.returncode == 0:
cadet.load()
print(data)
results = get_results(cadet)
return results
p.ho
July 16, 2020, 3:07pm
6
now I have the following error message when running the driver:
runfile(’//ibt014/ho/Project PhD (FZJ)/05_Simulations/Compartment_model/compartment-model/driver.py’, wdir=’//ibt014/ho/Project PhD (FZJ)/05_Simulations/Compartment_model/compartment-model’)
File “\ibt014\ho\Project PhD (FZJ)\05_Simulations\Compartment_model\compartment-model\driver.py”, line 24
plot_results(results)
IndentationError: unexpected indent
p.ho
7
indentation problem solved.
but now it says that VCRUNTIME140_1.dll cannot be found. A reinstallation of the program might solved the problem.
This should be related to this issue .
Your system lacks the Visual C++ 2019 runtime libraries:
Neueste unterstützte Visual C++ Redistributable-Downloads | Microsoft Learn
You ned vc_redist.x64.exe .
p.ho
July 24, 2020, 9:01am
9
Hi j.schmoelder,
thank you for providing the solution. It works!
Best regards
