Hey, so my code is this:
import matplotlib.pyplot as plt; plt.show()
ComponentSystem, MultiComponentColloidal, Inlet, GeneralRateModel, Outlet, FlowSheet, Process
# =============== Components (Salt, pH, A, B, C) ===============
component_system.add_component('Salt') # 0
component_system.add_component('pH') # 1
component_system.add_component('EAV') # 2
component_system.add_component('MP') # 3
component_system.add_component('fBV') # 4
component_system.add_component('cAV')
component_system.add_component('cBV')
# =============== Binding model (your params) ==================
binding_model = MultiComponentColloidal(component_system, name='MultiComponentColloidal')
binding_model.is_kinetic = 1
binding_model.kinetic_rate_constant = [0.0, 0.0, 1e+10, 1e+10, 1e+10, 1e+10, 1e+10]
binding_model.protein_radius = [1e-10, 1e-10, 1e-7, 1e-7, 1e-7, 1e-7, 1e-7]
binding_model.kappa_constant = 1e-2
binding_model.kappa_exponential = 0.0
binding_model.kappa_factor = 0.0
binding_model.logkeq_ph_exponent = [0.0, 0, 1.14, 1.07, 1.20, 1.14, 1.15]
binding_model.logkeq_power_exponent = [0.0]*7
binding_model.logkeq_power_factor = [0.0]*7
binding_model.logkeq_exponent_factor = [0.0, 0.0, 1.0, 1.0, 1.0, 1.0, 1.0]
binding_model.logkeq_exponent_multiplier = [0.0]*7
binding_model.bpp_ph_exponent = [0.0]*7
binding_model.bpp_power_exponent = [0.0]*7
binding_model.bpp_power_factor = [0.0]*7
binding_model.bpp_exponent_multiplier = [0.0]*7
binding_model.bpp_exponent_factor = [1e-12]*7
binding_model.use_ph = True
binding_model.linear_threshold = 1e-12
binding_model.phase_ratio = 5.0e7
binding_model.coordination_number = 5
binding_model.bound_states = [0, 0, 1, 1, 1, 1, 1] # 5 variants bound
print("Binding model OK?:", binding_model.check_required_parameters())
# =============== Units =======================================
inlet.flow_rate = 2.3e-8 # m^3/s
column.length = 0.204
column.diameter = 0.0066
column.bed_porosity = 0.44
column.particle_radius = 5e-5
column.particle_porosity = 0.902
column.axial_dispersion = 2.43e-07
# transport coeffs per component (len=7); keep >0
column.film_diffusion = [1e-04, 1e-04, 2.83e-05, 9.27e-05, 1.48e-05, 9.42e-05, 2.67e-05]
column.pore_diffusion = [5e-10, 5e-10, 4.89e-12, 1.70e-11, 1.75e-11, 7.61e-12, 4.90e-12]
column.surface_diffusion = [1e-5, 1E-5, 1e-5, 1e-5, 1e-5]
# Initial mobile/intraparticle concentrations (len=7)
column.c = [0.1, 1e-7, 0.0, 0.0, 0.0, 0.0, 0.0]
column.cp = [0.1, 1e-7, 0.0, 0.0, 0.0, 0.0, 0.0]
# =============== Flow sheet ==================================
# =============== Process & events =============================
process.cycle_time = 240.0 * 60.0 # seconds
t_wash_start = 50 * 60
t_elution_start = 150 * 60
t_strip_start = 200 * 60
EA_load = (2.64 * 0.198 / 100615.0) * 1e3
MP_load = (2.64 * 0.499 / 100615.0) * 1e3
FB_load = (2.64 * 0.138 / 100615.0) * 1e3
CA_load = (2.64 * 0.102 / 100615.0) * 1e3
CB_load = (2.64 * 0.064 / 100615.0) * 1e3
# [Salt, pH, EA, MP, FB, CA, CB]
c_load = np.array([0.1, 7, EA_load, MP_load, FB_load, CA_load, CB_load])
c_wash = np.array([0.1, 7, 0.0, 0.0, 0.0, 0.0, 0.0])
c_elute = np.array([0.1, 4.02 , 0.0, 0.0, 0.0, 0.0, 0.0])
c_strip = np.array([0.1, 3 , 0.0, 0.0, 0.0, 0.0, 0.0])
process.add_event('load', 'flow_sheet.inlet.c', c_load)
process.add_event('wash', 'flow_sheet.inlet.c', c_wash, t_wash_start)
process.add_event('elute', 'flow_sheet.inlet.c', c_elute, t_elution_start)
process.add_event('strip', 'flow_sheet.inlet.c', c_strip, t_strip_start)
# =============== Simulate ====================================
results = simulator.simulate(process)
from CADETProcess.fractionation import Fractionator
frac = Fractionator(results, components=['EAV','MP','fBV','cAV','cBV'])
frac.add_fractionation_event('elute_on', 'MP', 160*60)
frac.add_fractionation_event('elute_off', -1, 185*60)
perf = frac.performance
print(perf)
_ = frac.plot_fraction_signal()
I get this output:
Performance(mass=array([0.00000000e+00, 8.34115553e-07, 0.00000000e+00, 0.00000000e+00,
0.00000000e+00]), concentration=array([0. , 0.02417726, 0. , 0. , 0. ]), purity=array([0. , 0.75128976, 0. , 0. , 0. ]), recovery=array([0.00000000e+000, 1.79769313e+308, 0.00000000e+000, 0.00000000e+000,
0.00000000e+000]), productivity=array([0. , 0.00015123, 0. , 0. , 0. ]), eluent_consumption=array([nan, inf, nan, nan, nan]) mass_balance_difference=array([3.58611698e-07, 9.03400389e-07, 2.50188963e-07, 1.84739365e-07,
1.15922674e-07]))
I’m interested in the purity array. But as you can see it only gives me the purities for one component, and I would like to know for all.
My environment is this:
cadet_env.yml (5.0 KB)
