How to solve equilibrium reactions numerically stable and efficient with Sundials?
Dear CADET-Team,
I am currently working on my bachelor’s thesis at the chair of Bioseparation Engineering at TU Munich on a (separately written) simulation of “High Gradient Magnetic Separation”. As you do in CADET-Core, I am using C++ and Sundials to solve the resulting ODE system (finite volume discretization of a 1D PDE) including convection, dispersion, magnetic capture terms and equilibrium reactions (mass action law, langmuir adsorption, truesdell jones activity model).
The reaction’s stiffness (modeled kinetically / as terms in the ODEs so far) or another effect of them causes much bigger problems than I expected. With CVODE + Backward Differentiation Formulas I get convergence errors for most rate constants with no clear pattern arising (probably because of non invertible jacobians). On the other hand, ERKODE (explicit Runge Kutta) indicates that the implementation of the reactions seems to be correct but of course is forced to extremely small step sizes. And all approaches I tried so far also struggle with arising negative concentrations.
Therefore I have also thought about modeling the reactions as algebraic constraints (reactions are considered infinitesimally fast in our modeling) and solve with KINSOL or IDA.
I saw that IDA occurs quite often in the CADET Solver class but I did not understand how exactly the system is represented as a DAE system by CADET because if I simultaneously want to enforce the ODE (convection, etc.) and the algebraic equations (reactions) the system is overdetermined.
Therefore, I would like to ask you how you handle this in CADET and if you have some advice for me on how to tackle it?
E.g. IDA (algebraic constraints) vs alternating solving in CVODE/ARKODE and KINSOL (algebraic constraints) vs ARKODE/MRIStep (fast kinetic reactions) with splitting into stiff and non-stiff part etc.
Concerning efficiency, I have 26 components and about 100 finite volumes, so it is in the order of a few thousand coupled equations.
Thank you very much!
Hi Frank Zillmann and welcome to the forum !
as you’ve described, having different time scales for transport effects coupled with, e.g., reactions is a common source of stiffness and therefore computationally demanding. If reactions are fast enough so that their kinetics can be effectively neglected, one can indeed reduce stiffness by modeling them as algebraic equations (which we call rapid-equilibrium) instead of ODE. That worked quite well for us with binding models and I would encourage you do pursue in that direction. Recently, we’ve worked on rapid-equilibrium for reactions and came across the same problem you described - an overdetermined system of equations. The solution is to enforce algebraic constraints for some conserved moieties, not necessarily the original solution variables but combination(s) defined by the stoichiometric matrix. A detailed description on how to formulate the equations for conserved moieties to get a well-defined equation system is given in @s.leweke’s PhD thesis, chapter 4.2.
Following that procedure, the Jacobian should not be singular anymore. IDA will be able to solve the resulting global system of differential-algebraic equations and I believe you should try that first before thinking about dividing the problem into stiff/non-stiff parts and integrating them separately.
I hope that helps, and please don’t hesitate to ask further questions.
Welcome to the forum, @Frank_Zillmann. Can you post some equations?
In addition, are you sure that the Jacobians are correct?
Dear Mr Breuer,
Dear Mr Leweke,
thank you very much for your anwers! To add some context this is what my script / the component and reaction system looks like now:
    ComponentSystem cs{
        {// Format: Component(name).setCharge(...).setMolarMass(...).setTruesdellJonesAlpha(...).setTruesdellJonesBeta(...)
         Component("H2O").setMolarMass(18.01528),
         Component("H+").setCharge(1).setMolarMass(1.008).setTruesdellJonesParameters(4.78, 0.24),
         Component("OH-").setCharge(-1).setMolarMass(17.007).setTruesdellJonesParameters(10.65, 0.21),
         Component("Na+").setCharge(1).setMolarMass(22.990).setTruesdellJonesParameters(4.32, 0.06),
         Component("Cl-").setCharge(-1).setMolarMass(35.453).setTruesdellJonesParameters(3.71, 0.01),
         Component("TrisH+").setCharge(1).setMolarMass(121.14).setTruesdellJonesParameters(4.0, 0.0),
         Component("Tris").setMolarMass(121.14),
         Component("AcH").setMolarMass(60.052),
         Component("Ac-").setCharge(-1).setMolarMass(59.044).setTruesdellJonesParameters(4.5, 0.0),
         Component("GlyH2+").setCharge(1).setMolarMass(
             75.067),  // TODO: No truesdell_jones paramters available -> better to use Debye-Hückel model or 1?
         Component("GlyH").setMolarMass(75.067),
         Component("Gly-").setCharge(-1).setMolarMass(74.059).setTruesdellJonesParameters(4.0, 0.0),
         Component("hIgG").setCharge(1).setMolarMass(150000),  // Human Immunoglobulin G (IgG) antibody, roughly 150 kDa
         Component("MNP_OH2+").setType(Type::MagneticNanoParticleGroup).setCharge(1).setMolarMass(18.015),
         Component("MNP_OH").setType(Type::MagneticNanoParticleGroup).setMolarMass(17.007),
         Component("MNP_O-").setType(Type::MagneticNanoParticleGroup).setCharge(-1).setMolarMass(15.999),
         Component("MNP_hIgG").setType(Type::MagneticNanoParticleGroup).setMolarMass(150000),
         Component("MNP1").setType(Type::MagneticNanoParticle).setRadius(1039e-9).setDensity(5170).setMagneticSaturation(3.5e5),
         Component("MNP2").setType(Type::MagneticNanoParticle).setRadius(1209e-9).setDensity(5170).setMagneticSaturation(3.5e5),
         Component("MNP3").setType(Type::MagneticNanoParticle).setRadius(1406e-9).setDensity(5170).setMagneticSaturation(3.5e5),
         Component("MNP4").setType(Type::MagneticNanoParticle).setRadius(1635e-9).setDensity(5170).setMagneticSaturation(3.5e5),
         Component("MNP5").setType(Type::MagneticNanoParticle).setRadius(1901e-9).setDensity(5170).setMagneticSaturation(3.5e5),
         Component("MNP6").setType(Type::MagneticNanoParticle).setRadius(2211e-9).setDensity(5170).setMagneticSaturation(3.5e5),
         Component("MNP7").setType(Type::MagneticNanoParticle).setRadius(2571e-9).setDensity(5170).setMagneticSaturation(3.5e5),
         Component("MNP8").setType(Type::MagneticNanoParticle).setRadius(2990e-9).setDensity(5170).setMagneticSaturation(3.5e5),
         Component("MNP9").setType(Type::MagneticNanoParticle).setRadius(3477e-9).setDensity(5170).setMagneticSaturation(3.5e5),
         Component("MNP10").setType(Type::MagneticNanoParticle).setRadius(4043e-9).setDensity(5170).setMagneticSaturation(3.5e5)}};
    // Other physical parameters
    const realtype MNP_Ns = 1.08 * 1e-5;        // [mol/m²] - number of hydroxyl groups per area
    const realtype MNP_specific_surface = 1e5;  // m²/kg
    // ========================== REACTIONS ========================
    TruesdellJonesActivityModel truesdellJonesActivityModel(cs);
    ReactionSystem reactionSystem(cs, truesdellJonesActivityModel);
    realtype K_W = std::pow(10, -14);           // [mol²/(m³)²]
    realtype c_W = 1000 / cs("H2O").molarMass;  // [mol/L] - Concentration of water
    realtype Ks_W = K_W / c_W * 1e3;              // [mol/m³] - Equilibrium constant for water dissociation in mol/m³
    realtype Ks_Tris = std::pow(10, -8.3) * 1e3;  // [mol/m³]
    realtype Ks_AcH = std::pow(10, -4.75) * 1e3;  // [mol/m³]
    realtype Ks_GlyH2 = std::pow(10, -2.35) * 1e3;                      // [mol/m³]
    realtype Ks_GlyH = std::pow(10, -9.78) * 1e3;                       // [mol/m³]
    realtype Ks_MNP_OH2_plus = std::pow(10, -(7.9 - 0.5 * 2.5)) * 1e3;  // [mol/m³]
    realtype Ks_MNP_OH = std::pow(10, -(7.9 + 0.5 * 2.5)) * 1e3;        // [mol/m³]
    realtype kf_ion = 1e2;  // 5.5 (for 10 cells); // [1/s]
    realtype kb_W = (kf_ion / Ks_W);                        // [m³/(mol*s)]
    realtype kb_Tris = (kf_ion / Ks_Tris);                  // [m³/(mol*s)]
    realtype kb_AcH = (kf_ion / Ks_AcH);                    // [m³/(mol*s)]
    realtype kb_GlyH2 = (kf_ion / Ks_GlyH2);                // [m³/(mol*s)]
    realtype kb_GlyH = (kf_ion / Ks_GlyH);                  // [m³/(mol*s)]
    realtype kb_MNP_OH2_plus = (kf_ion / Ks_MNP_OH2_plus);  // [m³/(mol*s)]
    realtype kb_MNP_OH = (kf_ion / Ks_MNP_OH);              // [m³/(mol*s)]
    reactionSystem.add(massActionLaw(cs, "H2O <=> H+ + OH-", kf_ion,
                                     kb_W));  // H2O concentration is included in the equilibrium constant
    reactionSystem.add(massActionLaw(cs, "TrisH+ <=> Tris + H+", kf_ion, kb_Tris));
    reactionSystem.add(massActionLaw(cs, "AcH <=> H+ + Ac-", kf_ion, kb_AcH));
    reactionSystem.add(massActionLaw(cs, "GlyH2+ <=> H+ + GlyH", kf_ion, kb_GlyH2));
    reactionSystem.add(massActionLaw(cs, "GlyH <=> H+ + Gly-", kf_ion, kb_GlyH));
Plus two additional ion reactions between the hydroxl groups of the Magnetic Nano Particles (MNP) which include an extra correlation factor derived after the Gouy-Chapman model (more details on that: Modeling magnetic separation for hIgG purification: A theoretical and experimental study - ScienceDirect ).
Most importantly, I want to model the adsorption from hIgG to the MNP for which we use the Langmuir model with pH depented K_b and q_max. The other reactions are only needed to determine the pH value for this adsorption reaction.
So far, I added normal ODE terms as such:
Reaction massActionLaw(std::vector<std::pair<size_t, int>> reactant_terms,
                       std::vector<std::pair<size_t, int>> product_terms,
                       realtype k_forward,
                       realtype k_backward) {
    return Reaction([reactant_terms, product_terms, k_forward, k_backward](realtype t, const ConstArrayMap& activities,
        ArrayMap& dc_dt) {
        const auto n_cells = activities.rows();
        const auto n_components = activities.cols();
        // Calculate forward and backward rates for all cells simultaneously
        ColVector rate_fwd = ColVector::Constant(n_cells, k_forward);
        ColVector rate_bwd = ColVector::Constant(n_cells, k_backward);
        // Calculate forward reaction rates (vectorized)
        for (const auto& [idx, power] : reactant_terms) {
            for (int i = 0; i < power; ++i) {
                rate_fwd *= activities.col(idx);
        // Calculate backward reaction rates (vectorized)
        for (const auto& [idx, power] : product_terms) {
                rate_bwd *= activities.col(idx);
        // Calculate net reaction rates for all cells
        ColVector net_rate = rate_fwd - rate_bwd;
        // Apply stoichiometric changes (vectorized)
            dc_dt.col(idx) -= power * net_rate;
            dc_dt.col(idx) += power * net_rate;
I used the jacobians via automatic differentiation, so I have no implementations for them since the derivation should be doable but quite difficult trivial because of the activity model, surface complexiation and Langmuir parameter interpolation.
Also, I read the chapter 2.4 of your PhD thesis and find it a very interesting and elegant approach because it solves both problems together in one solver. On the other hand, I am unsure if it is the right approach for me since:
  1. I surely would have some difficulties to deeply understand and apply this quite advanced approach on my system :wink:
  2. Since I noticed that the other parts of the system are not to stiff, (I can solve the 6500 s of realtime experiment in about 30 s with ERKStep). I am thinking about solving the reactions and the rest in an alternating manner which would not be possible with IDA.
Specifically, I am thinking about modelling my reaction system algebraicly (equilibrium constraints + mass conservation + charge neutrality) which should be quite easy. And after each (or some) ERK step(s) I could compute a residual e.g. r_H+ = H+_current - H+_approx_eq = H+_current - K (HAc / Ac–) (equivalently for the other equations) which estimates the error of the H+ and hIgG-MNP concentrations. If this error surpasses a tolerance I could solve the system with KINSOL for the respective cells which would bring the jacobians down to 27*27 (instead of 2500*2500).
What do you think about this and do you have other ideas / would you recommend using only one solver and e.g. try analytic or sparse jacobians?
And would you recommend to model H2O as a component which (very slightly) varying concentrations or as a constant, which it basically is since we deal we relatively small concentrations, although this means the reactions generate and destroy mass (H+ and OH-) out of nothing?
Thank you!
Hi, sorry for the long delay !
Did you implement your approach in the meanwhile? It does seem reasonable to me and I’d be curious about the results.
Using sparse Jacobians will, depending on the size and sparsity pattern, significantly reduce computational overhead. Providing the full analytic Jacobian can further impove performance but can be tedious to derive, so I recommend to first only compute the sparsity pattern and give that to some preconditioner. Depending on in what language you’re implementing this, you can also get the Jacobain via Automatic Differentiation easily.
Is H2O orders of magnitude different from other components? I assume that’s why you want to avoid simulating this and keep it constant instead, which seems reasonable to me. Maybe you can compute the change of mass over the course of the simulation to get some confidence on the impact of that simplification?
