issue with fitting genetic algorithm isotherm parameters
final callback from genetic algorithm will match simulated chromatogram with same optimized parameters
vastly different chromatogram from final callback from optimization and running subsequent simulations with optimized params.
run genetic algorithm optimizer with population size > 3
Hello Rosario,
Thank you for your post!
Can you provide a MRE Code Example for us to quickly retrace your steps?
Thanks h.lanzrath,
I’ve been reducing the code I’m working on, however, ran into another issue where the simulation is hanging when I make protein a binding species (line 81 in the code provided). But runs when protein is not binding… not sure why this is the case
I’ve uploaded the reference experimental data and the python script as a .txt file
exp_result_device_pH_5.csv (23.8 KB)
simple_colloidal.txt (5.1 KB)
environment.yml (7.6 KB)
Hello Rosario,
Thanks for providing an MRE!
The problem here is, that “the model becomes mathematically singular at zero concentration” (see the CADET-Core documentation for Multi Component Colloidal).
That means the salt concetration representing total ionic stength needs to be > 0.
Thus for example setting
feed.c = [1, 0.022]
wash.c = [1, 0]
device.c = [1, 0]
leads to a running simulation.
We are already working on improving the error messages in a seperate issue.
Thanks to @ronald.jaepel for the help!
I have been able to set up a minimum reproducible example to replicate the issue in Rosario’s original post.
# -*- coding: utf-8 -*-
This is a colloidal isotherm example for fitting lnKe and Bpp parameters
using U_NSGA3 with a callback and forward simulation.
1) User provides "true" parameters
2) A forward simulation is run using those parameters
3) The result of the forward simulation is used as a reference for optimization
4) The results of optimization are used for a forward simulation and plotted
The same functions are used to set up the optimization and forward simulation
from CADETProcess.processModel import MultiComponentColloidal
from CADETProcess.processModel import Inlet, Outlet, GeneralRateModel
from CADETProcess.processModel import FlowSheet, Process
from CADETProcess.optimization import U_NSGA3, Joblib
def set_binding_model(component_system, lnKe, Bpp):
    binding_model = MultiComponentColloidal(component_system, name='MultiComponentColloidal')
    binding_model.phase_ratio = 1.46e8
    binding_model.kappa_exponential = 0
    binding_model.kappa_factor = 0
    binding_model.kappa_constant = 4e-9
    binding_model.coordination_number = 6
    binding_model.logkeq_exponent_factor = [0, lnKe]
    binding_model.logkeq_exponent_multiplier = [0, 0]
    binding_model.logkeq_power_exponent = [0, 0]
    binding_model.logkeq_power_factor = [0, 0]
    binding_model.logkeq_ph_exponent = [0, 0]
    binding_model.bpp_exponent_factor = [0, Bpp]
    binding_model.bpp_exponent_multiplier = [0, 0]
    binding_model.bpp_power_exponent = [0, 0]
    binding_model.bpp_power_factor = [0, 0]
    binding_model.bpp_ph_exponent = [0, 0]
    binding_model.protein_radius = [0, 4.5e-9]
    binding_model.kinetic_rate_constant = 1e8
    binding_model.bound_states = [0, 1]
    return binding_model
def set_column_model(component_system, binding_model):
    column.discretization.ncol = 35
    column.discretization.npar = 35
    column.length = 0.02
    column.diameter = 0.005
    column.cross_section_area = 1.96e-5
    column.particle_radius = 44e-6
    column.bed_porosity = 0.31
    column.particle_porosity = 0.90
    column.axial_dispersion = 2.85e-08
    column.film_diffusion = [9.86e-05, 1.14e-05]
    column.pore_diffusion = [6.5e-10, 3.71e-12]
    column.surface_diffusion = [0]
    column.c = [1e3*10**(-7.0), 0]
    column.cp = [1e3*10**(-7.0), 0]
    column.q = [0]
    return column
def make_process(lnKe, Bpp):
    component_system = ComponentSystem(['H+', 'protein'])
    binding_model = set_binding_model(component_system, lnKe, Bpp)
    column = set_column_model(component_system, binding_model)
    load = Inlet(component_system, name='load')
    load.c = [1e3*10**(-7.0), 0.027]
    wash = Inlet(component_system, name='wash')
    wash.c = [1e3*10**(-7.0), 0]
    flow_sheet.add_unit(load)
    flow_sheet.add_unit(wash)
    flow_sheet.add_connection(load, column)
    flow_sheet.add_connection(wash, column)
    process = Process(flow_sheet, name='proc')
    process.cycle_time = 7920
    # set events
    process.add_event('load_on', 'flow_sheet.load.flow_rate', 3.68e-9, time=0)
    process.add_event('load_off', 'flow_sheet.load.flow_rate', 0, time=5520)
    process.add_event('wash_on', 'flow_sheet.wash.flow_rate', 3.68e-9, time=5520)
    process.add_event('wash_off', 'flow_sheet.wash.flow_rate', 0, time=7920)
    return process
def set_optimization_problem(time, data, process):
    def callback(simulation_results, individual, evaluation_object, callbacks_dir='./'):
        comparator = comparators[evaluation_object.name]
        comparator.plot_comparison(
            simulation_results,
            file_name=f'{callbacks_dir}/{individual.id}_{evaluation_object}_comparison.png',
            show=False
    optimization_problem = OptimizationProblem('fit')
    optimization_problem.add_evaluator(simulator)
    comparators = dict()
    optimization_problem.add_evaluation_object(process, name=process.name)
    fit_component_system = ComponentSystem(['protein'])
    reference = ReferenceIO(name=process.name, time=time, solution=data,
                            component_system=fit_component_system)
    comparator = Comparator(process.name)
    comparator.add_difference_metric('NRMSE', reference, 'outlet.inlet', components='protein')
    comparators[process.name] = comparator
        comparator,
        name=f"Objective {process.name}",
        evaluation_objects=[process],  # limit this comparator to be applied to only this one process
        n_objectives=comparator.n_metrics,
        requires=[simulator]
        name='lnKe',
        parameter_path='flow_sheet.column.binding_model.logkeq_exponent_factor',
        indices=1,
        lb=5, ub=100,
        transform='auto'
        name='Bpp',
        parameter_path='flow_sheet.column.binding_model.bpp_exponent_factor',
        indices=1,
        lb=1, ub=10,
        transform='auto'
    optimization_problem.add_callback(callback, requires=[simulator])
    return optimization_problem
def run_fit(lnKe, Bpp):
    # Create reference data with forward sim
    process = make_process(lnKe, Bpp)
    time = simulation_results.solution.outlet.outlet.time
    data = simulation_results.solution.outlet.outlet.solution
    data = data[:, 1].reshape(-1, 1)
    # Fit data from forward sim
    optimization_problem = set_optimization_problem(time, data, process)
    optimizer = U_NSGA3()
    optimizer.n_max_gen = 5
    optimizer.pop_size = 5
    # print(optimizer.options)
    # parallelize!!
    optimizer.backend = Joblib()
    optimizer.n_cores=-2
    print('\nCADET-Process optimization start!\n')
    optimization_results = optimizer.optimize(optimization_problem)
    print(f'Optimization completed in {optimization_results.time_elapsed:.2f} seconds.\n')
    # Create a new process from the fitting results
    fwd_process = make_process(optimization_results.x[0][0], Bpp)
    print(f'\nFitted lnKe: {optimization_results.x[0][0]:.2f}\n')
    print(f'\nFitted Bpp: {optimization_results.x[0][1]:.2f}\n')
    print('\nForward simulation start!\n')
    simulation_results = simulator.simulate(fwd_process)
    print(f'Simulation completed in {simulation_results.time_elapsed:.2f} seconds.\n')
    final_time = simulation_results.solution.outlet.outlet.time
    final_solution_array = simulation_results.solution.outlet.outlet.solution
    plt.plot(time, data, linestyle=':', color='k', label='reference')
    plt.plot(final_time, final_solution_array[:, 1], color='b', label='fit')
    return optimization_results
if __name__=='__main__':
    run_fit(45, 4)
When running the code with the current values (lnKe=45, Bpp=4), the output I get is
n_gen  |  n_eval  | n_nds  |      eps      |   indicator
     1 |        5 |      1 |             - |             -
Finished Generation 1.
x: [72.88335145  8.99147563], f: [0.05533086]
     2 |       10 |      1 |  0.0348061575 |         ideal
Finished Generation 2.
x: [77.39609336  7.6842273 ], f: [0.0205247]
     3 |       15 |      1 |  0.0032067216 |         ideal
Finished Generation 3.
x: [75.48185755  7.68450607], f: [0.01731798]
     4 |       20 |      1 |  0.000000E+00 |             f
Finished Generation 4.
     5 |       25 |      1 |  0.000000E+00 |             f
Finished Generation 5.
Optimization completed in 264.72 seconds.
Fitted lnKe: 75.48
Fitted Bpp: 7.68
Simulation completed in 23.27 seconds.
The parameter and objective values reported in the results_pareto.csv file that CADET_Process generates match those output in the terminal. The results of using these parameters in a forward simulation looks like this
which is expected because the parameters from the optimization are very different from the “true” values initially provided for the reference data.
However, the CADET-Process callback plot looks like this:
The NRMSE matches the one from the terminal output and results_pareto.csv but the plot for the callback seems to be using different (and at least in this case better) parameters.
I haven’t figured out exactly when this difference happens and when it doesn’t, but I noticed that at least a few times when I was fitting only lnKe and not also fitting Bpp the two plots matched.
Previously, it had seemed like reducing the number of generations sometimes led to matching plots. Using the script above I have found that
optimizer.n_max_gen=1, optimizer.pop_size=5 → plot’s don’t match
optimizer.n_max_gen=1, optimizer.pop_size=1 → plot’s match
So it seems like maybe parameter sets are getting mixed up somewhere
Here’s my environment
environment.yml (13.1 KB)
Hi Angela,
thanks for reporting this. I tried to reproduce the issue and I noticed the following line:
Here, you seem to use the initial value of Bpp instead of the optimized one. Does changing it to
fwd_process = make_process(optimization_results.x[0][0], optimization_results.x[0][1])
solve your problem?
Hey Jo,
Thank for the catch, that’s pretty critical :sweat_smile: :woman_facepalming:
But also no. If you’re seeing what I am seeing, when I run this after fixing that there is still a difference, although it is less dramatic.
Rosario originally spotted this from a different and unrelated model setup, so although it’s possible we could have made the same mistake twice somewhere, I don’t think it was that one in both cases.
Angela
As a followup, here’s as example where the correct Bpp is actually used for the forward plots. Everything else is identical to the code above.
In this case it almost just looks like a shift in the x-axis, but in the last figure looking at the top of the curve it looks like the shape might be different as well. Using a different model I have seen more dramatic differences like what Rosario showed but I am not sure exactly what conditions led to those larger differences to try to reproduce them with this model.
ok, thanks for clarifying it. I’ll have a look.
Hi Angela,
that was a bit more tricky than expected but I figured it out. The problem originates from the casting behavior of arrays in numpy.
Consider the following:
foo = np.array([0, 46])
print(foo)
>>> [ 0 46]
Now, during optimization, what happens is that we want to update index 1
foo[1] = 46.1
Unintuitively, when you inspect that variable, you get
print(foo)
>>> [ 0 46]
Why is that? it has to do with the so-called dtype. Since the array was initialized only with integer types, numpy assumes that it is an array of integers. Now, when you try to update a value with a float, it casts it to an int first.
This can be avoided by explicitly setting the dtype when instantiating the array.
foo = np.array([0, 46], dtype=float)
foo[1] = 46.1
print(foo)
>>> [ 0.  46.1]
To be clear, this should be handled better by the binding model / parameters module of CADET-Process. I’m already working on a fix but there are some details that need some more thinking.
In the meantime, you can simply initialize your binding model parameters with a float, then you should be good to go.
run_fit(45., 4.)
By the way, this means that not only the callbacks were affected but actually all of the evaluations of the objective function(s) were rounded to the next integer. So you can expect much better fits now. Sorry for the inconvenience and thanks for reporting this issue!
I worked on a PR which should solve the problem. Please let me know if it works for you.
Hey Johannes, thanks for looking into it.
Using floats to initialize the parameters did solve the problem.
This also explains some weird looking objective plots I have been seeing.
Just out of curiosity, did you also check whether the PR solves your issue, even when initializing with ints?
A pull request (PR) is a set of proposed changes that we might want to include in another branch (e.g., dev or master). It’s essentially a separate branch containing commits that can be reviewed and discussed before being merged into the main codebase.
To use that branch, either simply checkout that branch or install it in your environment with:
pip install git+https://github.com/fau-advanced-separations/CADET-Process.git@fix/sized_float_list
Please let us know if you have further questions.
