Issues after CADET-Process Installation
Hey all,
I am currently trying to migrate to CADET-Process.
I expected the appended script to work without issues because it has worked on another computer (On which we haven’t used CADET before)
Installation was done in a fresh environment and the error occured on multiple computers that previously had cadet 4.3.0 running.
Thanks in advance for any help!
The error I get on these Computers is:
C:\Users\ak46oqoz\AppData\Local\anaconda3\envs\CADET_Process_env\Lib\site-packages\cadet\cadet.py:510: FutureWarning: Cadet.run_load() will be removed in a future release. Please use Cadet.run_simulation()
  warnings.warn(
There was an exception in simulate_n_cycles
  File "C:\Users\ak46oqoz\AppData\Local\anaconda3\envs\CADET_Process_env\Lib\site-packages\CADETProcess\log.py", line 172, in wrapper
  File "C:\Users\ak46oqoz\AppData\Local\anaconda3\envs\CADET_Process_env\Lib\site-packages\CADETProcess\simulator\simulator.py", line 308, in simulate_n_cycles
    return self.run(process, **kwargs)
  File "C:\Users\ak46oqoz\AppData\Local\anaconda3\envs\CADET_Process_env\Lib\site-packages\CADETProcess\simulator\cadetAdapter.py", line 133, in wrapper
  File "C:\Users\ak46oqoz\AppData\Local\anaconda3\envs\CADET_Process_env\Lib\site-packages\CADETProcess\simulator\cadetAdapter.py", line 233, in run
    return_information = cadet.run_load(timeout=self.timeout)
  File "C:\Users\ak46oqoz\AppData\Local\anaconda3\envs\CADET_Process_env\Lib\site-packages\cadet\cadet.py", line 515, in run_load
    return_information = self.run_simulation(timeout=timeout, clear=clear)
  File "C:\Users\ak46oqoz\AppData\Local\anaconda3\envs\CADET_Process_env\Lib\site-packages\cadet\cadet.py", line 539, in run_simulation
    return_information = self.cadet_runner.run(
        simulation=self,
        timeout=timeout
  File "C:\Users\ak46oqoz\AppData\Local\anaconda3\envs\CADET_Process_env\Lib\site-packages\cadet\runner.py", line 162, in run
    error_message=data.stderr.decode('utf-8'),
UnicodeDecodeError: 'utf-8' codec can't decode byte 0xfc in position 100: invalid start byte
UnicodeDecodeError                        Traceback (most recent call last)
File c:\users\ak46oqoz\faubox\promotion\abschlussarbeiten\müller\linear_isotherm.py:147
    144 from CADETProcess.simulator import Cadet
    146 process_simulator = Cadet()
--> 147 simulation_results = process_simulator.simulate(process)
    149 signal=simulation_results.solution.column.outlet.solution
    150 time=simulation_results.solution.column.outlet.time
File ~\AppData\Local\anaconda3\envs\CADET_Process_env\Lib\site-packages\CADETProcess\simulator\simulator.py:252, in SimulatorBase.simulate(self, process, previous_results, **kwargs)
    249     raise CADETProcessError("Process is not configured correctly.")
    251 if not self.evaluate_stationarity:
--> 252     results = self.simulate_n_cycles(
    253         process, self.n_cycles, previous_results, **kwargs
    254     )
    255 else:
    256     results = self.simulate_to_stationarity(
    257         process, previous_results, **kwargs
    258     )
File ~\AppData\Local\anaconda3\envs\CADET_Process_env\Lib\site-packages\CADETProcess\log.py:150, in log_time.<locals>.log_time_decorator.<locals>.wrapper(*args, **kwargs)
    147 @wraps(function)
    148 def wrapper(*args, **kwargs):
    149     start = time.time()
--> 150     result = function(*args, **kwargs)
    151     elapsed = time.time() - start
    152     logger = get_logger(logger_name, level=None)
File ~\AppData\Local\anaconda3\envs\CADET_Process_env\Lib\site-packages\CADETProcess\log.py:201, in log_results.<locals>.log_results_decorator.<locals>.wrapper(*args, **kwargs)
    197 logger = get_logger(logger_name, level=None)
    199 logger.debug('{} was called with {}, {}'.format(
    200         function, *args, **kwargs))
--> 201 results = function(*args, **kwargs)
    202 logger.debug(f'Results: {results}')
    204 return results
File ~\AppData\Local\anaconda3\envs\CADET_Process_env\Lib\site-packages\CADETProcess\log.py:180, in log_exceptions.<locals>.log_exception_decorator.<locals>.wrapper(*args, **kwargs)
    177 logger.exception(err)
    179 # re-raise the exception
--> 180 raise e
File ~\AppData\Local\anaconda3\envs\CADET_Process_env\Lib\site-packages\CADETProcess\log.py:172, in log_exceptions.<locals>.log_exception_decorator.<locals>.wrapper(*args, **kwargs)
    170 logger = get_logger(logger_name, level=None)
    171 try:
--> 172     return function(*args, **kwargs)
    173 except Exception as e:
    174     # log the exception
    175     err = "There was an exception in "
File ~\AppData\Local\anaconda3\envs\CADET_Process_env\Lib\site-packages\CADETProcess\simulator\simulator.py:308, in SimulatorBase.simulate_n_cycles(self, process, n_cyc, previous_results, **kwargs)
    305 if previous_results is not None:
    306     self.set_state_from_results(process, previous_results)
--> 308 return self.run(process, **kwargs)
    310 self.n_cycles = n_cyc_orig
File ~\AppData\Local\anaconda3\envs\CADET_Process_env\Lib\site-packages\CADETProcess\simulator\cadetAdapter.py:133, in Cadet.locks_process.<locals>.wrapper(self, process, *args, **kwargs)
    130     process.lock = True
    131     locked_process = True
--> 133 results = func(self, process, *args, **kwargs)
    135 if locked_process:
    136     process.lock = False
File ~\AppData\Local\anaconda3\envs\CADET_Process_env\Lib\site-packages\CADETProcess\simulator\cadetAdapter.py:233, in Cadet.run(self, process, cadet, file_path)
    231 try:
    232     start = time.time()
--> 233     return_information = cadet.run_load(timeout=self.timeout)
    234     elapsed = time.time() - start
    235 except TimeoutExpired:
File ~\AppData\Local\anaconda3\envs\CADET_Process_env\Lib\site-packages\cadet\cadet.py:515, in Cadet.run_load(self, timeout, clear)
    495 """
    496 Run the CADET simulation and load the results.
    497
    508     Information about the simulation run.
    509 """
    510 warnings.warn(
    511     "Cadet.run_load() will be removed in a future release. "
    512     "Please use Cadet.run_simulation()",
    513     category=FutureWarning
    514 )
--> 515 return_information = self.run_simulation(timeout=timeout, clear=clear)
    517 return return_information
File ~\AppData\Local\anaconda3\envs\CADET_Process_env\Lib\site-packages\cadet\cadet.py:539, in Cadet.run_simulation(self, timeout, clear)
    519 def run_simulation(
    520         self,
    521         timeout: Optional[int] = None,
    522         clear: bool = True
    523 ) -> ReturnInformation:
    524     """
    525     Run the CADET simulation and load the results.
    526
    537         Information about the simulation run.
    538     """
--> 539     return_information = self.cadet_runner.run(
    540         simulation=self,
    541         timeout=timeout
    542     )
    544     if return_information.return_code == 0:
    545         self.cadet_runner.load_results(self)
File ~\AppData\Local\anaconda3\envs\CADET_Process_env\Lib\site-packages\cadet\runner.py:162, in CadetCLIRunner.run(self, simulation, timeout)
    152     raise ValueError("Filename must be set before run can be used")
    154 data = subprocess.run(
    155     [self.cadet_path, str(simulation.filename)],
    156     timeout=timeout,
    157     capture_output=True
    158 )
    160 return_info = ReturnInformation(
    161     return_code=data.returncode,
--> 162     error_message=data.stderr.decode('utf-8'),
    163     log=data.stdout.decode('utf-8')
    164 )
    166 return return_info
When executing the following script I run into this error, but only on the computers that had a older CADET version installed (specifically cadet 4.3.0):
from CADETProcess.processModel import Inlet
from CADETProcess.processModel import Linear
from CADETProcess.processModel import LumpedRateModelWithoutPores
from CADETProcess.processModel import Outlet
component_system = ComponentSystem(1)
c_inj_hom=1
Q = 0.7/(60*1e6) #feed flow m^3/s
inlet.flow_rate = Q  # m^3 / s
inlet.c = c_inj_hom  # mol / m^3
binding_model = Linear(component_system, n_binding_sites=1, name='linear')
binding_model.adsorption_rate = [1]  # m^3 / (mol * s)   (mobile phase)
binding_model.desorption_rate = [1]  # 1 / s (desorption)
NTP=7351    #determined
column.length = 0.1  # m
column.diameter = 0.0046  # m
column.total_porosity = 0.61  # total porosity of system
column.set_axial_dispersion_from_NTP(NTP, Q)
column.c = [0]
column.q = [0]
process = Process(flow_sheet, 'Process')
process.cycle_time = 10000
environment.yml (11.7 KB)
Hi Jan, thanks for reporting the issue,
I tried to run it locally but unfortunately, I cannot reproduce the issue on Ubuntu 24.04. Maybe it’s a Windows issue?
If we can’t reproduce it, this would be a good topic for our next office hours.
Hi Jan,
Unfortunately, I wasn’t able to reproduce your issue on Windows either.
Could you please try running CADET-Process in a fresh environment and see if the error persists?
Here’s a minimal example environment you can use:
channels:
  - conda-forge
dependencies:
  - python=3.13.2
  - pip
  - pip:
      - CADET-Process
      - CADET-Python
It’s possible that another package is interfering, so isolating it in a clean setup might help.
All the best,
