I am getting the attached error. Kindly help me to rectify the error.
Hey naveen567,
The error message tells us that the system is looking for the file libhdf5.200.dylib. It also tells us all the locations it has tried.
You can also search for the file: In the terminal, type
find / -iname 'libhdf5.200.dylib'
This may take some time. Please post the results of that search here.
Please also search for libhdf5.dylib by running
find / -iname 'libhdf5.dylib'
Possible causes for this problem could be:
cadet-cli program to a different computer)Hi s.leweke.
Thank you for your response.
Hereby, I have attached the results.
libhdf5.200.dylib
/Users/naveenj/tensorflow-n/env/lib/python3.8/site-packages/netCDF4/.dylibs/libhdf5.200.dylib
/Users/naveenj/tensorflow-n/env/lib/libhdf5.200.dylib
/Applications/Orange3.app/Contents/Frameworks/Python.framework/Versions/3.8/lib/python3.8/site-packages/h5py/.dylibs/libhdf5.200.dylib
/opt/homebrew/lib/libhdf5.200.dylib
/opt/homebrew/Cellar/hdf5/1.12.2_2/lib/libhdf5.200.dylib
find: /dev/fd/3: Not a directory
find: /dev/fd/4: Not a directory
find: /dev/fd/6: Not a directory
libhdf5.dylib
/Users/naveenj/miniforge3/pkgs/hdf5-1.12.1-nompi_hd9dbc9e_104/lib/libhdf5.dylib
/Users/naveenj/miniforge3/pkgs/hdf5-1.12.1-nompi_hf9525e8_104/lib/libhdf5.dylib
find: /Users/naveenj/.Trash: Operation not permitted
/Users/naveenj/tensorflow-n/env/lib/libhdf5.dylib
/Applications/MATLAB_R2022a.app/bin/maci64/libhdf5.dylib
/opt/homebrew/lib/libhdf5.dylib
/opt/homebrew/Cellar/hdf5/1.12.2_2/lib/libhdf5.dylib
Thanks
I guess, this is the one that was used to compile CADET:
I suggest adding
import os
if 'DYLD_LIBRARY_PATH' in os.environ:
os.environ['DYLD_LIBRARY_PATH'] = '/opt/homebrew/lib/:' + os.environ['DYLD_LIBRARY_PATH']
os.environ['DYLD_LIBRARY_PATH'] = '/opt/homebrew/lib/'
to the top of your Python script / code.
This will add the path /opt/homebrew/lib/ to the DYLD_LIBRARY_PATH environment variable, which is used by the dynamic linker to find missing .dylib files.
Thanks, s.leweke,
I have tried.
I am getting the below error.
CompletedProcess(args=[PosixPath('/Users/naveenj/opt/cadet/bin/cadet-cli'), '/Users/naveenj/noefbq0h.h5'], returncode=-6, stdout=b'', stderr=b"dyld[9122]: Library not loaded: @rpath/libhdf5.200.dylib\n Referenced from: <2F2F5997-E412-3097-AAE1-FE40BF043393> /Users/naveenj/opt/cadet/bin/cadet-cli\n Reason: tried: '/opt/homebrew/lib//libhdf5.200.dylib' (mach-o file, but is an incompatible architecture (have 'arm64', need 'x86_64')), '/Users/naveenj/opt/cadet/bin/../lib/libhdf5.200.dylib' (no such file), '/Users/naveenj/opt/cadet/bin/../lib/libhdf5.200.dylib' (no such file), '/System/Volumes/Preboot/Cryptexes/OS@rpath/libhdf5.200.dylib' (no such file), '/Users/naveenj/opt/cadet/bin/../lib/libhdf5.200.dylib' (no such file), '/Users/naveenj/opt/cadet/bin/../lib/libhdf5.200.dylib' (no such file), '/usr/local/lib/libhdf5.200.dylib' (no such file), '/usr/lib/libhdf5.200.dylib' (no such file, not in dyld cache)\n")
TypeError Traceback (most recent call last)
~/ipykernel_9064/1870842693.py in <cell line: 1>()
----> 1 p_1=Simulation1C(0.2,3)
2 p_2=Simulation1C(0.78,3)
3 p_3=Simulation1C(0.42,3)
4 p_4=Simulation1C(1.5,4.5)
5 p_5=Simulation1C(2.5,2.25)
~/ipykernel_9064/81328248.py in Simulation1C(c0, vel)
13 time = model.root.output.solution.solution_times
14
---> 15 c = c0*model.root.output.solution.unit_001.solution_outlet/(model.root.input.model.unit_000.sec_000.const_coeff)
16 #Set breakthrogh percentage to calculate loading time in minutes
17 pstart = 3.49
TypeError: unsupported operand type(s) for *: 'float' and 'Dict'
Okay, that’s weird. It seems like your system is kind-of thrown together?
The file /opt/homebrew/lib//libhdf5.200.dylib was compiled for arm64 architecture (i.e., Macs with M1 or M2 CPU), but your system needs x86_64 architecture (i.e., it has an Intel CPU).
Maybe someone has taken the hard drive from an M1/M2 Mac and put it into your Intel Mac?
Anyway, there might be a smart solution, but I suggest the sledgehammer:
brew install hdf5No, I am using an M1 mac. But the cadet folder I am using is not compatible with mac M1. Could you pls tell me how to install CADET on Mac M1?
Kindly help me with the above.
Thanks
Hi S. Leweke
Thank you so much for your assistance. I have reconstructed the cadet using the source code, which functions well. Thanks again.
Naveen
