Brief update:
I have found the cause. It works with the following line of code:
optimization_problem.add_linear_equality_constraint(['axial_dispersion_tubing', 'axial_dispersion_tubing2'], lhs=[1, -1], beq=0, eps=1e-9)
However, I now get an error during optimization:
CADETProcessError Traceback (most recent call last)
Cell In[14], line 2
1 if __name__ == '__main__':
----> 2 optimization_results = optimizer.optimize(
3 optimization_problem, x0,
4 use_checkpoint=True
5 )
File ~\anaconda3\envs\MasterNew\lib\site-packages\CADETProcess\optimization\optimizer.py:260, in OptimizerBase.optimize(self, optimization_problem, x0, save_results, results_directory, use_checkpoint, overwrite_results_directory, exist_ok, log_level, reinit_cache, delete_cache, *args, **kwargs)
256 plt.switch_backend('agg')
258 start = time.time()
--> 260 self.run(self.optimization_problem, x0, *args, **kwargs)
262 self.results.time_elapsed = time.time() - start
264 if delete_cache:
File ~\anaconda3\envs\MasterNew\lib\site-packages\CADETProcess\optimization\pymooAdapter.py:92, in PymooInterface.run(self, optimization_problem, x0)
90 if len(pop) < pop_size:
91 n_remaining = pop_size - len(pop)
---> 92 remaining = optimization_problem.create_initial_values(
93 n_remaining, method='chebyshev', seed=self.seed,
94 burn_in=burn_in
95 )
96 pop = np.vstack((pop, remaining))
97 elif len(pop) > pop_size:
File ~\anaconda3\envs\MasterNew\lib\site-packages\CADETProcess\optimization\optimizationProblem.py:2780, in OptimizationProblem.create_initial_values(self, n_samples, method, seed, burn_in)
2778 while len(values) < n_samples:
2779 if counter > burn_in:
-> 2780 raise CADETProcessError(
2781 "Cannot find invididuals that fulfill constraints."
2782 )
2784 counter += 1
2785 i = rng.integers(0, burn_in)
CADETProcessError: Cannot find invididuals that fulfill constraints.
I think it’s best if I share the whole code with the following experimental data:
NaCl_Normalized.csv (63.0 KB)
from CADETProcess.processModel import Inlet, GeneralRateModel, Outlet,TubularReactor, Cstr,LumpedRateModelWithPores
Q_ml_min = 0.5 # ml/min
Q_m3_s = Q_ml_min/(60*1e6) #m3/s
V_tracer = 5e-8
# Unit Operations
inlet.flow_rate = Q_m3_s
column.length = 0.1
column.diameter = 0.0077
column.bed_porosity = 0.19
column.particle_radius = 3.4e-5
column.particle_porosity = 0.8333
column.axial_dispersion =4.41924993e-08
column.film_diffusion = [1.829e-4]
# Tubing1
tubing1 = TubularReactor(component_system, 'tubing1')
tubing1.length = 0.534
tubing1.cross_section_area = 4.418e-7
tubing1.axial_dispersion = 8.97920728e-04
tubing2 = TubularReactor(component_system, 'tubing2')
tubing2.length = 0.534
tubing2.cross_section_area = 4.418e-7
tubing2.axial_dispersion = 8.97920728e-04
uv_detector = Cstr(component_system, name='uv_detector')
uv_detector.V = 2e-9
uv_detector.c = [0]
flow_sheet.add_unit(tubing1)
flow_sheet.add_unit(tubing2)
flow_sheet.add_unit(uv_detector)
flow_sheet.add_connection(inlet, tubing1)
flow_sheet.add_connection(tubing1, column)
flow_sheet.add_connection(column, tubing2)
flow_sheet.add_connection(tubing2, uv_detector)
flow_sheet.add_connection(uv_detector, outlet)
process.cycle_time = 1200
_ = process.add_event('Pre-Wash', 'flow_sheet.inlet.c', [0],0)
_ = process.add_event('Injection', 'flow_sheet.inlet.c', [500], 60)
_ = process.add_event('Wash', 'flow_sheet.inlet.c', [0],(V_tracer/Q_m3_s+60))
fig, ax = simulation_results.solution.outlet.outlet.plot()
data_uv_2 = np.loadtxt('NaCl_Normalized.csv', delimiter=',')
time_uv_2 = data_uv_2[:, 0] * 60
uv_2 = data_uv_2[:, 1]
reference = ReferenceIO('NaCl experiment', time_uv_2, uv_2)
_ = reference.plot()
comparator = Comparator()
comparator.add_difference_metric(
'PeakPosition', reference,
'outlet.outlet'
'PeakHeight', reference,
'outlet.outlet'
metrics = comparator.evaluate(simulation_results)
print(metrics)
plot= comparator.plot_comparison(simulation_results)
optimization_problem = OptimizationProblem('AxialDispersion_PositionHeight')
name='axial_dispersion_column', parameter_path='flow_sheet.column.axial_dispersion',
lb=1e-10, ub=0.1,
transform='auto'
name='axial_dispersion_tubing', parameter_path='flow_sheet.tubing1.axial_dispersion',
lb=1e-9, ub=0.1,
transform='auto'
name='axial_dispersion_tubing2', parameter_path='flow_sheet.tubing2.axial_dispersion',
lb=1e-9, ub=0.1,
transform='auto'
#optimization_problem.add_linear_equality_constraint(['axial_dispersion_tubing', 'axial_dispersion_tubing2'], lhs=[1e5, -1e5], beq=0, eps=1e-4) # I have also tried this
optimization_problem.add_evaluator(simulator)
comparator,
n_objectives=comparator.n_metrics,
requires=[simulator]
def callback(simulation_results, individual, evaluation_object, callbacks_dir='./'):
simulation_results,
file_name=f'{callbacks_dir}/{individual.id}_{evaluation_object}_comparison.png',
show=False
optimization_problem.add_callback(callback, requires=[simulator])
x0=[[5e-08, 5e-06,5e-06]]
#x0=optimization_problem.create_initial_values(method='chebyshev')
optimizer = U_NSGA3()
optimizer.n_cores = 4
optimizer.pop_size = 50
optimizer.n_max_gen = 5
use_checkpoint=False
Epsilon must be chosen very low, as the axial dispersion is very small. As shown above, I have also tried multiplication with a pre-factor and other possibilities (e.g. with initial values generated by the appropriate method).
Can anyone help me?
