Of course you can!
The problem is that you’re switching from a SingleGRM to a LumpedRateModelWithPores. The SingleGRM is actually a combination of a ModelSystem and a GeneralRateModel.
CADET only simulates systems. In order to make life a little easier if you just want to simulate a single model, the SingleGRM, SingleLRMP, SingleLRM, and SingleCSTR classes are offered. These provide the necessary ModelSystem without the need to fully set it up (i.e., provide InletModel, connect actual model and InletModel, etc.).
Long story short, here’s the relevant section of the loadWashElutionSMAsingle.m file for the LumpedRateModelWithPores:
% Lumped rate model with pores unit operation
mLrmp = SingleLRMP();
% Discretization
mLrmp.nComponents = 4;
mLrmp.nCellsColumn = 16; % Attention: This is very low and only used for illustration (short runtime)
mLrmp.nBoundStates = ones(mLrmp.nComponents, 1); % Number of bound states for each component
% Initial conditions (equilibrated empty column)
mLrmp.initialBulk = [50.0 0.0 0.0 0.0]; % [mol / m^3], also used for the particle mobile phase
mLrmp.initialSolid = [1.2e3 0.0 0.0 0.0]; % [mol / m^3]
% Transport
mLrmp.dispersionColumn = 5.75e-8; % [m^2 / s]
mLrmp.filmDiffusion = [6.9e-6 6.9e-6 6.9e-6 6.9e-6]; % [m/s]
mLrmp.interstitialVelocity = 5.75e-4; % [m/s]
% Geometry
mLrmp.columnLength = 0.014; % [m]
mLrmp.particleRadius = 4.5e-5; % [m]
mLrmp.porosityColumn = 0.37; % [-]
mLrmp.porosityParticle = 0.75; % [-]
% Adsorption
mSma = StericMassActionBinding();
mSma.kineticBinding = false; % Quasi-stationary binding
mSma.lambda = 1.2e3; % Ionic capacity [mol / m^3]
mSma.kA = [0.0 35.5 1.59 7.7]; % Adsorption rate [(m^3 / mol)^nu / s]
mSma.kD = [0.0 1000 1000 1000]; % Desorption rate [(m^3 / mol)^nu / s]
mSma.nu = [0.0 4.7 5.29 3.7]; % Characteristic charge [-]
mSma.sigma = [0.0 11.83 10.6 10.0]; % Steric factor [-]
mLrmp.bindingModel = mSma;
% Specify inlet profile
% Reserve space: nSections x nComponents (a section can be thought of being a
% step in the process, see below)
mLrmp.constant = zeros(3, mLrmp.nComponents);
mLrmp.linear = zeros(3, mLrmp.nComponents);
mLrmp.quadratic = zeros(3, mLrmp.nComponents);
mLrmp.cubic = zeros(3, mLrmp.nComponents);
% Section 1: Loading phase
mLrmp.constant(1,1) = 50.0; % [mol / m^3] component 1
mLrmp.constant(1,2) = 1.0; % [mol / m^3] component 2
mLrmp.constant(1,3) = 1.0; % [mol / m^3] component 3
mLrmp.constant(1,4) = 1.0; % [mol / m^3] component 4
% Section 2: Washing phase (no protein feed)
mLrmp.constant(2,1) = 50.0; % [mol / m^3] component 1
% Section 3: Elution phase (linear salt gradient with step at the beginning)
mLrmp.constant(3,1) = 100; % [mol / m^3] component 1
mLrmp.linear(3,1) = 0.2; % [mol / (m^3 * s)] component 1
Accordingly, for the LumpedRateModelWithoutPores, we get
% Lumped rate model without pores unit operation
mLrm = SingleLRM();
% Discretization
mLrm.nComponents = 4;
mLrm.nCellsColumn = 16; % Attention: This is very low and only used for illustration (short runtime)
mLrm.nBoundStates = ones(mLrm.nComponents, 1); % Number of bound states for each component
mLrm.initialBulk = [50.0 0.0 0.0 0.0]; % [mol / m^3], also used for the particle mobile phase
mLrm.initialSolid = [1.2e3 0.0 0.0 0.0]; % [mol / m^3]
% Transport
mLrm.dispersionColumn = 5.75e-8; % [m^2 / s]
mLrm.interstitialVelocity = 3e-3; % [m/s]
% Geometry
mLrm.columnLength = 0.014; % [m]
mLrm.porosity = 0.37 * (1.0 - 0.37) * 0.75; % [-]
% Adsorption
mLrm.bindingModel = mSma;
mLrm.constant = zeros(3, mLrm.nComponents);
mLrm.linear = zeros(3, mLrm.nComponents);
mLrm.quadratic = zeros(3, mLrm.nComponents);
mLrm.cubic = zeros(3, mLrm.nComponents);
mLrm.constant(1,1) = 50.0; % [mol / m^3] component 1
mLrm.constant(1,2) = 1.0; % [mol / m^3] component 2
mLrm.constant(1,3) = 1.0; % [mol / m^3] component 3
mLrm.constant(1,4) = 1.0; % [mol / m^3] component 4
mLrm.constant(2,1) = 50.0; % [mol / m^3] component 1
mLrm.constant(3,1) = 100; % [mol / m^3] component 1
mLrm.linear(3,1) = 0.2; % [mol / (m^3 * s)] component 1
The model (mLrm or mLrmp) is then passed to the simulator object:
% Construct and configure simulator
sim = Simulator.create();
sim.solutionTimes = linspace(0, 1500, 1001); % [s], time points at which solution is computed
% sectionTimes holds the sections and sectionContinuity indicates whether
% the transition between two adjacent sections is continuous
sim.sectionTimes = [0.0 10.0 90.0 1500.0]; % [s]
sim.sectionContinuity = false(2,1);
% Hand model over to simulator
sim.model = mLrmp; % or mLrm
