Because my absurd quest of hacking chemical reactions in CADET was getting out of hand and difficult to maintain, I took the time and implemented a little tool that should facilitate the creation of reactions matrices.
Let’s assume the following system:
# Components
# 0: H+
# 1: NH4+
# 2: NH3
# 3: Lys2+
# 4: Lys+
# 5: Lys
# 6: Lys-
Then we can now set up a reaction system:
from reactions import ReactionSystem
r = ReactionSystem(n_comp=7)
First, we define the reactions in bulk phase
# 0: NH4+(aq) <=> NH3(aq) + H+(aq)
# 1: Lys2+(aq) <=> Lys+(aq) + H+(aq)
# 2: Lys+(aq) <=> Lys(aq) + H+(aq)
# 3: Lys(aq) <=> Lys-(aq) + H+(aq)
We can use the add_bulk_reaction() function to add the reaction to the system. It takes the component indices, the stoichiometric coefficients, as well as the reaction rate as arguments. If no backward reaction is given, k_fwd is assumed to be the equilibrium constant. The rates then are scaled up by a predefined factor. Moreover, we can set add_pore_reaction, s.t. the same reaction is later automatically added to the particle pores.
r.add_bulk_reaction(
indices=[1, 2, 0],
coefficients=[-1, 1, 1],
k_fwd=10**(-9.2),
add_pore_reaction=True
r.add_bulk_reaction([3, 4, 0], [-1, 1, 1], 10**(-2.20), add_pore_reaction=True)
r.add_bulk_reaction([4, 5, 0], [-1, 1, 1], 10**(-8.90), add_pore_reaction=True)
r.add_bulk_reaction([5, 6, 0], [-1, 1, 1], 10**(-10.28), add_pore_reaction=True)
Defining reactions becomes especially tricky if they span different phases. Let’s assume that we want to model some kind of Adsorption process. The reactions might look something like this:
# 0: NH4+(aq) + H+(s) <=> NH4+(s) + H+(aq)
# 1: Lys2+(aq) + H+(s) <=> Lys2+(s) + H+(aq)
# 2: Lys+(aq) + H+(s) <=> Lys+(s) + H+(aq)
Now we can make use of the add_cross_phase_reaction function. In addition to the previous function, it also takes a phases argument which assumes the index 0 for pores, and 1 for the solid phase
r.add_cross_phase_reaction(
indices=[1, 0, 1, 0],
coefficients=[-1, -1, 1, 1],
phases=[0, 1, 0, 1],
k_fwd=1.5)
r.add_cross_phase_reaction([3, 0, 3, 0], [-1, -1, 1, 1], [0, 1, 0, 1], 5)
r.add_cross_phase_reaction([4, 0, 4, 0], [-1, -1, 1, 1], [0, 1, 0, 1], 0.75)
Now, we can simply query the composed matrices for stoichiometry, exponent modifiers etc.
e.g.
>>> r.stoich_bulk
[[ 1. 1. 1. 1.]
[-1. 0. 0. 0.]
[ 1. 0. 0. 0.]
[ 0. -1. 0. 0.]
[ 0. 1. -1. 0.]
[ 0. 0. 1. -1.]
[ 0. 0. 0. 1.]]
>>> r.stoich_pore
[[ 1. 1. 1. 1. 0. 0. 0.]
[-1. 0. 0. 0. 1. 0. 0.]
[ 1. 0. 0. 0. 0. 0. 0.]
[ 0. -1. 0. 0. 0. 1. 0.]
[ 0. 1. -1. 0. 0. 0. 1.]
[ 0. 0. 1. -1. 0. 0. 0.]
[ 0. 0. 0. 1. 0. 0. 0.]]
>>> r.stoich_solid
[[1. 1. 1.]
[0. 0. 0.]
[0. 0. 0.]
[0. 0. 0.]
[0. 0. 0.]
[0. 0. 0.]
[0. 0. 0.]]
or
>>> r.solid_fwd_modpore
[[0. 0. 0.]
[1. 0. 0.]
[0. 0. 0.]
[0. 1. 0.]
[0. 0. 1.]
[0. 0. 0.]
[0. 0. 0.]]
etc.
I will run some more tests and will publish it somewhere sometime. Just needed to share!
