Modeling IEC using SMA and GRM
Hello everyone,
New to CADET here, I work as a downstream processing specialist particularly Monoclonals purification. I am trying to first understand CADET’s architecture and i have successfully simulated adsorption using Langmuir and LumpedRateModelWithPores, However I am facing challenges modeling IEC using SMA, I followed the tutorial for one component and was able to reproduce chromatograms successfully but I wanted to simulate 3 components,
Since new users can’t upload attachments here is my code
from CADETProcess.processModel import Inlet, LumpedRateModelWithPores, Outlet,GeneralRateModel
# Defining Components
componentSystem = ComponentSystem()
componentSystem.add_component('Salt')
componentSystem.add_component('Impurity A')
componentSystem.add_component('Product')
componentSystem.add_component('Impurity B')
inlet = Inlet(componentSystem,'inlet')
outlet = Outlet(componentSystem,'outlet')
column = GeneralRateModel(componentSystem,'column')
# mmodel.reference
model = StericMassAction(componentSystem,'model')
model.is_kinetic = True
model.steric_factor = [0,25.5,15.2,10.7]
model.characteristic_charge = [0,5.2,5.6,3.3]
model.adsorption_rate = [0,0.30,0.650,0.10]
model.desorption_rate = [0,1,1,1]
model.capacity = 400
# model =Langmuir(componentSystem,'model')
# model.is_kinetic = False
# model.adsorption_rate = [0.0329,0.0037,0.016]
# model.desorption_rate = [1,1,1]
# model.capacity = 100
# model.missing_parameters
column.missing_parameters
column.binding_model = model
column.length = 0.25
column.diameter = 0.0115
column.bed_porosity = 0.37
column.particle_porosity = 0.33
column.axial_dispersion = 2.0e-7
column.film_diffusion = [2.0e-5, 2.0e-7, 2.0e-7, 2.0e-7]
column.pore_diffusion = [7e-5, 1e-9,1e-9,1e-9]
column.surface_diffusion = [0.0, 0.0,0.0,0.0]
# column.q = [model.capacity,0,0,0]
column.check_required_parameters()
sheet = FlowSheet(componentSystem,'flow_sheet')
sheet.add_unit(inlet)
sheet.add_unit(column)
sheet.add_unit(outlet)
sheet.add_connection(inlet,column)
sheet.add_connection(column,outlet)
inlet.flow_rate = 2.88e-8
process = Process(sheet,'process')
# column.c = [0.1,0,0,0]
# process.add_event('equilibration','flow_sheet.inlet.c',[100,0,0,0],0)
process.add_event('equilibration','flow_sheet.inlet.c',[0.001,0,0,0],0)
process.add_event('feed_on','flow_sheet.inlet.c',[0.001,50,100,25],300)
process.add_event('feed_off','flow_sheet.inlet.c',[0.1,0,0,0],1500)
process.add_event('wash','flow_sheet.inlet.c',[5,0,0,0],3000)
# process.add_event('wash','flow_sheet.inlet.c',[1,0,0,0],301)
# process.add_event('gradient_start','flow_sheet.inlet.c',[[0.01,1/60],0,0,0],100)
# process.add_event('step_1','flow_sheet.inlet.c',[10,0,0,0],100)
# process.add_event('step_2','flow_sheet.inlet.c',[20,0,0,0],400)
# process.add_event('step_3','flow_sheet.inlet.c',[200,0,0,0],700)
process.cycle_time = 5000
# simulator.simulate(process)
process.plot_events()
# process.result()
result = simulator.simulate(process)
sec = SecondaryAxis()
sec.components = ["Salt"]
sec.y_label = '$c_{salt}$'
# result.solution.outlet.outlet.plot()
result.solution.column.outlet.plot(secondary_axis=sec)
Code in bold is commented out , I tried simulating different events but the chromatogram shows that the salt elutes with the components which didn’t happen in the tutorial. I tried equilibration instead of predefining a concentration in the column and i tried both, all 3 peaks co-elute together with no separation albeit i tried varying adsorption… how should one go about this ?
Thank you in advance, :slight_smile:
I am sorry if my understanding or code is unclear but I just started this two weeks ago to use it for process development eventually.
Hi yqabil
and a hearty welcome to the CADET community!
Sorry that it took some time to have a look here. Do you still require assistance on this issue? For me your simulation runs unexpectedly long, so I think there might be a general problem in the setup (or the parameters) here.
If it is a IEC with SMA and 3 components you are after, you might want to check the LWE Example in the Documentation for reference, which provides the following working example:
from CADETProcess.processModel import Inlet, GeneralRateModel, Outlet
# Component System
component_system.add_component('C')
# Binding Model
binding_model = StericMassAction(component_system, name='SMA')
binding_model.adsorption_rate = [0.0, 35.5, 1.59, 7.7]
binding_model.desorption_rate = [0.0, 1000, 1000, 1000]
binding_model.characteristic_charge = [0.0, 4.7, 5.29, 3.7]
binding_model.steric_factor = [0.0, 11.83, 10.6, 10]
binding_model.capacity = 1200.0
# Unit Operations
inlet.flow_rate = 6.683738370512285e-8
column.length = 0.014
column.diameter = 0.02
column.particle_porosity = 0.75
column.axial_dispersion = 5.75e-8
column.film_diffusion = column.n_comp * [6.9e-6]
column.pore_diffusion = [7e-10, 6.07e-11, 6.07e-11, 6.07e-11]
column.surface_diffusion = column.n_bound_states * [0.0]
column.c = [50, 0, 0, 0]
column.cp = [50, 0, 0, 0]
column.q = [binding_model.capacity, 0, 0, 0]
process.cycle_time = 2000.0
load_duration = 9
t_gradient_start = 90.0
gradient_duration = process.cycle_time - t_gradient_start
c_load = np.array([50.0, 1.0, 1.0, 1.0])
c_wash = np.array([50.0, 0.0, 0.0, 0.0])
c_elute = np.array([500.0, 0.0, 0.0, 0.0])
gradient_slope = (c_elute - c_wash) / gradient_duration
process.add_event('load', 'flow_sheet.inlet.c', c_load)
process.add_event('wash', 'flow_sheet.inlet.c', c_wash, load_duration)
process.add_event('grad_start', 'flow_sheet.inlet.c', c_gradient_poly, t_gradient_start)
sec.components = ['Salt']
simulation_results.solution.column.outlet.plot(secondary_axis=sec)
Hope that already helps!
All the best,
