Numpy Array Data Type Objects (dtype)
Here’s another fun little example regarding numpy indices.
array = np.array([1, 2])
print(array)
[1 2]
Now, I’m trying to assign a new value to the first item of the array:
array[0] = 1.5
print(array)
[1 2]
This is rather unexpected.
I would have expected the following:
[1.5 2]
The issue here is that numpy automatically detects the data type that describes how the bytes in the fixed-size block of memory corresponding to an array item should be interpreted.
For more information, refer to: Data type objects (dtype) — NumPy v1.25 Manual
To fix this issue, explicitly set the dtype when first creating the array:
array = np.array([1, 2], dtype=np.float64)
now,
array[0] = 1.5
yields the expected result.
print(array)
[1.5 2]
An alternative is to always set the values in the correct type. So following the example, instead of
you could do
array = np.array([1., 2.])
# or
array = np.array([1.0, 2.0])
:wink:
