Hi all
I’m trying to use CADET-Process to fit model parameters to my experimental data. I’m following this case study (which runs fine).
In my case, instead of fitting porosity and axial dispersion, I want to fit film difffusion, axial dispersion, and the linear isotherm adsorption rate.
When adding either film diffusion or the linear isotherm adsorption rate, I get the following error:
ValueError: Scalar parameters cannot have index slices.
Which appears to happen when adding variables in lists.
Here is what I am doing:
optimization_problem = OptimizationProblem('fit_param', use_diskcache=False)
name='film_diffusion',
parameter_path='flow_sheet.column.film_diffusion',
indices=0, # <-- I've tried with and without this
lb=1e-10, ub=1.0,
transform='auto'
name='axial_dispersion',
parameter_path='flow_sheet.column.axial_dispersion',
lb=1e-10, ub=0.1, transform='auto'
The full error:
ValueError Traceback (most recent call last)
Cell In[14], line 5
1 optimization_problem = OptimizationProblem('fit_param', use_diskcache=False)
3 optimization_problem.add_evaluation_object(process)
----> 5 optimization_problem.add_variable(
6 name='film_diffusion',
7 parameter_path='flow_sheet.column.film_diffusion',
8 indices=0,
9 lb=1e-10, ub=1.0,
10 transform='auto'
11 )
13 optimization_problem.add_variable(
14 name='axial_dispersion',
15 parameter_path='flow_sheet.column.axial_dispersion',
16 lb=1e-10, ub=0.1, transform='auto'
17 )
19 # optimization_problem.add_variable(
20 # name='isotherm_constant',
21 # parameter_path='flow_sheet.column.binding_model.adsorption_rate',
22 # lb=1e-2, ub=10.0,
23 # transform='auto'
24 # )
File ~\miniconda3\envs\cadet\lib\site-packages\CADETProcess\optimization\optimizationProblem.py:347, in OptimizationProblem.add_variable(self, name, evaluation_objects, parameter_path, lb, ub, transform, indices)
342 if parameter_path is not None and len(evaluation_objects) == 0:
343 raise ValueError(
344 "Cannot set parameter_path for variable without evaluation object "
345 )
--> 347 var = OptimizationVariable(
348 name, evaluation_objects, parameter_path,
349 lb=lb, ub=ub, transform=transform,
350 indices=indices,
351 )
353 self._variables.append(var)
355 with warnings.catch_warnings():
File ~\miniconda3\envs\cadet\lib\site-packages\CADETProcess\optimization\optimizationProblem.py:2962, in OptimizationVariable.__init__(self, name, evaluation_objects, parameter_path, lb, ub, transform, indices, precision)
2960 self.evaluation_objects = evaluation_objects
2961 self.parameter_path = parameter_path
-> 2962 self.indices = indices
2963 else:
2964 self.evaluation_objects = None
File ~\miniconda3\envs\cadet\lib\site-packages\CADETProcess\optimization\optimizationProblem.py:3169, in OptimizationVariable.indices(self, indices)
3167 _ = self.indices
3168 except (ValueError, TypeError) as e:
-> 3169 raise e
File ~\miniconda3\envs\cadet\lib\site-packages\CADETProcess\optimization\optimizationProblem.py:3167, in OptimizationVariable.indices(self, indices)
3165 # Since indices are constructed on `get`, call the property here:
3166 try:
-> 3167 _ = self.indices
3169 raise e
File ~\miniconda3\envs\cadet\lib\site-packages\CADETProcess\optimization\optimizationProblem.py:3126, in OptimizationVariable.indices(self)
3124 parameter_shape = self._get_parameter_shape(eval_obj)
3125 if isinstance(parameter_shape, tuple):
-> 3126 eval_ind = generate_indices(parameter_shape, eval_ind)
3127 else:
3128 if not isinstance(eval_ind, list):
File ~\miniconda3\envs\cadet\lib\site-packages\CADETProcess\dynamicEvents\section.py:663, in generate_indices(shape, indices)
661 size = np.prod(shape)
662 if size == 1:
--> 663 raise ValueError("Scalar parameters cannot have index slices.")
665 if indices is None:
666 indices = np.s_[:]
What am I missing?
If needed I can provide the full code but I think this is enough as I am using the code from the case study and just adding a binding model. Then choosing different optimization variables, as shown above.
