In CADET 4.0.1 i would like to split a stream after a CSTR (1) and combine the split streams again after some other unit operations (2,4 and 3). The cirquit diagram looks like this:
------ 2 ----- 4 ----
0 ---- 1 --- --- 5
------ 3 ------------
Do I have to specify ports on UO1 to specify that I connect different output Ports to (2) and (3)?
My first approach was using “-1” for all port specifcations (cf. Example below), but that resulted in some UO not influencing the output signal.
mSys.connections = {[0, 1, -1, -1, -1, -1, Q;...
1, 2, -1, -1, -1, -1, Q*0.57;...
1, 3, -1, -1, -1, -1, Q*0.43;...
2, 4, -1, -1, -1, -1, Q*0.57;...
3, 5, -1, -1, -1, -1, Q*0.43;...
4, 5, -1, -1, -1, -1, Q*0.57]};
Next, I tried to specify ports for (1) and (5) :
mCSTR1 = StirredTankModel();
mCSTR2 = StirredTankModel();
mCSTR1.nInputPorts = 1;
mCSTR1.nOutputPorts = 2;
mCSTR2.nInputPorts = 2;
mCSTR2.nOutputPorts = 1;
and I tried
mCSTR1.nInputPorts = [1,NaN];
mCSTR1.nOutputPorts = [1,2];
mCSTR2.nInputPorts = [1,2];
mCSTR2.nOutputPorts = [1,NaN];
But this results in this type of error:
In class ‘StirredTankModel’, no set method is defined for Dependent property ‘nInletPorts’. A Dependent property needs a set method to assign its value.
My Question is:
Is the approach to split the stream I am using correct? If it is, how can I properly set up Input and Ouput ports?
Thanks in advance,
