Protein A affinity PCC modelling
I am working on modeling Protein A affinity PCC chromatography. Since I am not very familiar with SMB Builder, I tried using the scheduling method.
Expected result:
I was expecting a proper elution for different cycles.
Output:
Minimum reproducible code:
from CADETProcess.processModel import ComponentSystem, Inlet, Outlet, GeneralRateModel
from CADETProcess.processModel import FlowSheet, Process
from CADETProcess.processModel import MobilePhaseModulator
def create_pcc_process():
    CYCLE_TIME = 40 * 60
    load_time = 37 * 60  # 37 minutes
    wash_zone1_time = 3 * 60  # 3 minutes
    # Zone 3 timings - total 40 minutes
    t_w1 = 1 * 60  # 1 minute
    t_w2 = 4 * 60  # 4 minutes
    t_w3 = 6 * 60  # 6 minutes
    t_elute = 6 * 60  # 6 minutes
    t_clean1 = 2 * 60  # 2 minutes
    t_pause = 15 * 60  # 15 minutes
    t_clean2 = 1 * 60  # 1 minute
    t_equil = 5 * 60  # 5 minutes
    mLmin_to_m3s = 60 * 1e6
    FLOW_LOAD = 3.03 / mLmin_to_m3s
    FLOW_OTHER = 4.55 / mLmin_to_m3s
    # pH and concentration parameters
    mol_wt = 146.5
    conc = 5.3
    conc_load = conc / mol_wt  # mol/L
    pH_bind = 7
    pH_elute = 3.5
    pH_b_H = 10**(-pH_bind)
    pH_e_H = 10**(-pH_elute)
    #components
    sys = ComponentSystem()
    sys.add_component('Salt')
    sys.add_component('Protein')
    #binding model
    binding_model = MobilePhaseModulator(sys, name='MPM')
    binding_model.adsorption_rate = [0, 5.19e-08]
    binding_model.desorption_rate = [0, 1.0]
    binding_model.capacity = [0, 10]
    binding_model.ion_exchange_characteristic = [0, 1.54]
    binding_model.hydrophobicity = [0, 0]
    binding_model.bound_states = [0, 1]
    #Inlets
    feed = Inlet(sys, 'feed')
    feed.c = [pH_b_H, conc_load]
    wash_z1 = Inlet(sys, 'wash_z1')
    wash_z1.c = [pH_b_H, 0]
    wash1 = Inlet(sys, 'wash1')
    wash1.c = [pH_b_H, 0]
    wash2 = Inlet(sys, 'wash2')
    wash2.c = [pH_b_H, 0]
    wash3 = Inlet(sys, 'wash3')
    wash3.c = [pH_b_H, 0]
    eluent = Inlet(sys, 'eluent')
    eluent.c = [pH_e_H, 0]
    cip = Inlet(sys, 'cip')
    cip.c = [10**(-3.0), 0]
    equil = Inlet(sys, 'equil')
    equil.c = [pH_b_H, 0]
    #columns
    cols = []
    for i in range(3):
        column = GeneralRateModel(sys, name=f'col_{i+1}')
        column.length = 0.058  # m
        column.diameter = 0.01  # m
        column.bed_porosity = 0.899998
        column.particle_porosity = 0.49956
        column.particle_radius = 50e-6
        column.axial_dispersion = 9.21e-7
        column.film_diffusion = [1e-4, 9.93e-5]
        column.pore_diffusion = [1e-9, 9.54e-11]
        column.discretization.ncol = 50
        column.discretization.npar = 12
        column.c = [pH_b_H, 0]
        cols.append(column)
    #Outlets
    product = Outlet(sys, 'product')
    waste = Outlet(sys, 'waste')
    #flowsheet
    fs = FlowSheet(sys)
    for u in [feed, wash_z1, wash1, wash2, wash3, eluent, cip, equil, product, waste]:
        fs.add_unit(u)
    for c in cols:
        fs.add_unit(c)
    #connections
    # Connect ALL inlets to ALL columns
    for inlet in [feed, wash_z1, wash1, wash2, wash3, eluent, cip, equil]:
        fs.add_connection(inlet, cols[0])
        fs.add_connection(inlet, cols[1])
        fs.add_connection(inlet, cols[2])
    # Col1 output states: [product, waste, col_2]
    fs.add_connection(cols[0], product)
    fs.add_connection(cols[0], waste)
    fs.add_connection(cols[0], cols[1])
    # Col2 output states: [product, waste, col_3]
    fs.add_connection(cols[1], product)
    fs.add_connection(cols[1], waste)
    fs.add_connection(cols[1], cols[2])
    # Col3 output states: [product, waste, col_1]
    fs.add_connection(cols[2], product)
    fs.add_connection(cols[2], waste)
    fs.add_connection(cols[2], cols[0])
    #Process
    process = Process(fs, 'PCC_Chromatography')
    #total process time
    process.cycle_time = 3 * CYCLE_TIME
    #add events for all 3 phases
    def add_phase_events(state_idx):
        state 0: Load C1->C2, Recover C3 (0-40 mins)
        state 1: Load C2->C3, Recover C1 (40-80 mins)
        state 2: Load C3->C1, Recover C2 (80-120 mins)
        t_base = state_idx * CYCLE_TIME
        #[to_column1, to_column2, to_column3]
        to_c1 = [1, 0, 0]
        to_c2 = [0, 1, 0]
        to_c3 = [0, 0, 1]
        if state_idx == 0:
            load_dest = to_c1
            rec_inlet_map = to_c3
            rec_col_name = 'col_3'
        elif state_idx == 1:
            load_dest = to_c2
            rec_inlet_map = to_c1
            rec_col_name = 'col_1'
            load_dest = to_c3
            rec_inlet_map = to_c2
            rec_col_name = 'col_2'
        #LOADING (0-37 min): Z1
        process.add_event(f'S{state_idx}_load_start', 'flow_sheet.feed.flow_rate', FLOW_LOAD, t_base)
        process.add_event(f'S{state_idx}_load_dest', 'flow_sheet.output_states.feed', load_dest, t_base)
        if state_idx == 0:
            process.add_event(f'S{state_idx}_c1_conn', 'flow_sheet.output_states.col_1', [0, 0, 1], t_base)  # C1->C2
            process.add_event(f'S{state_idx}_c2_conn', 'flow_sheet.output_states.col_2', [0, 1, 0], t_base)  # C2->Waste
            process.add_event(f'S{state_idx}_c2_conn', 'flow_sheet.output_states.col_2', [0, 0, 1], t_base)  # C2->C3
            process.add_event(f'S{state_idx}_c3_conn', 'flow_sheet.output_states.col_3', [0, 1, 0], t_base)  # C3->Waste
            process.add_event(f'S{state_idx}_c3_conn', 'flow_sheet.output_states.col_3', [0, 0, 1], t_base)  # C3->C1
            process.add_event(f'S{state_idx}_c1_conn', 'flow_sheet.output_states.col_1', [0, 1, 0], t_base)  # C1->Waste
        #WASH (37-40 min): Z1
        t_chase = t_base + load_time
        process.add_event(f'S{state_idx}_load_stop', 'flow_sheet.feed.flow_rate', 0.0, t_chase)
        process.add_event(f'S{state_idx}_z1w_start', 'flow_sheet.wash_z1.flow_rate', FLOW_LOAD, t_chase)
        process.add_event(f'S{state_idx}_z1w_dest', 'flow_sheet.output_states.wash_z1', load_dest, t_chase)
        # Stop
        process.add_event(f'S{state_idx}_z1w_stop', 'flow_sheet.wash_z1.flow_rate', 0.0, t_base + CYCLE_TIME)
        #Z2: RECOVERY STEPS
        cur_t = t_base
        def set_rec_out(time, dest_type):
            vec = [0, 1, 0] if dest_type == 'waste' else [1, 0, 0]
            process.add_event(f'{rec_col_name}_out_{state_idx}_{int(time)}',
                            f'flow_sheet.output_states.{rec_col_name}', vec, time)
        #Wash 1
        process.add_event(f'w1_start_{state_idx}', 'flow_sheet.wash1.flow_rate', FLOW_OTHER, cur_t)
        process.add_event(f'w1_dest_{state_idx}', 'flow_sheet.output_states.wash1', rec_inlet_map, cur_t)
        set_rec_out(cur_t, 'waste')
        cur_t += t_w1
        process.add_event(f'w1_stop_{state_idx}', 'flow_sheet.wash1.flow_rate', 0.0, cur_t)
        #Wash 2
        process.add_event(f'w2_start_{state_idx}', 'flow_sheet.wash2.flow_rate', FLOW_OTHER, cur_t)
        process.add_event(f'w2_dest_{state_idx}', 'flow_sheet.output_states.wash2', rec_inlet_map, cur_t)
        cur_t += t_w2
        process.add_event(f'w2_stop_{state_idx}', 'flow_sheet.wash2.flow_rate', 0.0, cur_t)
        #Wash 3
        process.add_event(f'w3_start_{state_idx}', 'flow_sheet.wash3.flow_rate', FLOW_OTHER, cur_t)
        process.add_event(f'w3_dest_{state_idx}', 'flow_sheet.output_states.wash3', rec_inlet_map, cur_t)
        cur_t += t_w3
        process.add_event(f'w3_stop_{state_idx}', 'flow_sheet.wash3.flow_rate', 0.0, cur_t)
        #Elution
        process.add_event(f'elute_start_{state_idx}', 'flow_sheet.eluent.flow_rate', FLOW_OTHER, cur_t)
        process.add_event(f'elute_dest_{state_idx}', 'flow_sheet.output_states.eluent', rec_inlet_map, cur_t)
        set_rec_out(cur_t, 'product')
        cur_t += t_elute
        process.add_event(f'elute_stop_{state_idx}', 'flow_sheet.eluent.flow_rate', 0.0, cur_t)
        #Clean 1
        process.add_event(f'cip1_start_{state_idx}', 'flow_sheet.cip.flow_rate', FLOW_OTHER, cur_t)
        process.add_event(f'cip1_dest_{state_idx}', 'flow_sheet.output_states.cip', rec_inlet_map, cur_t)
        cur_t += t_clean1
        #Pause
        process.add_event(f'pause_start_{state_idx}', 'flow_sheet.cip.flow_rate', 0.0, cur_t)
        cur_t += t_pause
        #Clean 2
        process.add_event(f'cip2_start_{state_idx}', 'flow_sheet.cip.flow_rate', FLOW_OTHER, cur_t)
        cur_t += t_clean2
        process.add_event(f'cip2_stop_{state_idx}', 'flow_sheet.cip.flow_rate', 0.0, cur_t)
        #Equilibration
        process.add_event(f'eq_start_{state_idx}', 'flow_sheet.equil.flow_rate', FLOW_OTHER, cur_t)
        process.add_event(f'eq_dest_{state_idx}', 'flow_sheet.output_states.equil', rec_inlet_map, cur_t)
        cur_t += t_equil
        process.add_event(f'eq_stop_{state_idx}', 'flow_sheet.equil.flow_rate', 0.0, cur_t)
    # Add events
    add_phase_events(0)
    add_phase_events(1)
    add_phase_events(2)
    print(f"\nProcess created with {len(process.events_dict)} events")
    return process
def run_pcc_simulation():
    process = create_pcc_process()
    simulator.evaluate_stationarity = True
    simulator.n_cycles_max = 1
    simulator.n_cycles_min = 1
    simulator.timeout = 3600  # 1 hour timeout
    try:
        print(f"Simulation completed successfully!")
        print(f"Cycles simulated: {simulation_results.n_cycles}")
        return process, simulation_results
    except Exception as e:
        print(f"Simulation failed with error: {e}")
        import traceback
        traceback.print_exc()
        return process, None
def plot_results(process, simulation_results):
    if simulation_results is None:
        print("No results to plot")
        return
    try:
        fig, axes = plt.subplots(2, 1, figsize=(14, 8))
        fig.suptitle('PCC Chrom Process', fontsize=16)
        # Plot Product outlet
        ax = axes[0]
        if hasattr(simulation_results.solution, 'product'):
            product_data = simulation_results.solution.product.outlet.solution
            product_time = simulation_results.solution.product.outlet.time / 60
            ax.plot(product_time, product_data[:, 1], label='Protein', color='green', linewidth=2)
            # Mark cycle switches
            for i in range(4):
                cycle_start = i * 40
                ax.axvline(x=cycle_start, color='k', linestyle='--', alpha=0.5)
                if i < 3:
                    ax.text(cycle_start + 2, ax.get_ylim()[1]*0.9, f'Cycle {i+1}', fontsize=10)
        ax.set_ylabel('Concentration [mol/L]')
        ax.set_title('Product Collection (Protein)')
        ax.legend()
        ax.grid(True, alpha=0.3)
        # Plot Waste outlet
        ax = axes[1]
        if hasattr(simulation_results.solution, 'waste'):
            waste_data = simulation_results.solution.waste.outlet.solution
            waste_time = simulation_results.solution.waste.outlet.time / 60
            ax.plot(waste_time, waste_data[:, 1], label='Protein', color='red', linewidth=2)
            for i in range(4):
        ax.set_xlabel('Time [min]')
        ax.set_title('Waste Collection (Protein)')
        ax.legend()
        plt.tight_layout()
        plt.savefig('pcc_chromatography_results.png', dpi=300, bbox_inches='tight')
        print("\nResults saved as: pcc_chromatography_results.png")
        print(f"Error plotting results: {e}")
        import traceback
if __name__ == "__main__":
    process, results = run_pcc_simulation()
    if results:
        plot_results(process, results)
        print("\nSimulation failed")
Kindly help me with this.
Thanks
Naveen J
Hi Naveem,
Our expert on this (@j.schmoelder) and our staff member (@h.lanzrath) are currently on vacation, and since your issue requires a deeper look, our response may be delayed. Thanks for your patience.
If you manage to solve the problem in the meantime, please share your solution here.
Hi Jan,
Thank you for your response. No problem.
I am trying to rectify the issue. Once it is done, I will post the outcome.
Thanks
Warm Regards,
Naveen J
Hi Naveen,
Have you made progress with this issue in the meantime?
Hi Hannah,
Thank you for your response. I was not able to resolve the error. I tried to separate the simulation into two parts: the first compartment simulates the batch, and the second compartment calculates the new loading amount. It would be really helpful if you could suggest this method. I can attach the code and the result.
Thank you!
Naveen J
Hey Naveen,
My first advise would be to plot your events and make sure everything there, the timing as well as the concentrations, are what you expect.
Hi Hannah,
Thank you for the suggestion. I am working on it. I will update with the results soon.
Thank you!
Naveen J
