This code reproduces the process design study (Chapter 6) from Leweke and Lieres (2018) which takes its parameter values from Püttmann et al. (2013).
A process and corresponding process optimization problem can be created for:
A multi-component competitive SMA binding gradient elution separation of three components.
The code is placed in the project repository. The puetmann2013 [sic] module contains process.py wherein the processes are defined, optimization.py wherein the optimization problem and the optimizers are defined, and main.py and cli.py which serve as an entry point to the CADET RDM batch runner.
