Hello Forum,
I observed some unexpected behavior when setting up a simple column model in CADET-Process while trying to use the add_event functionality to change the film diffusion coefficient (k_film) at some time point during the process. I am not sure if this is an issue or if I am just doing something wrong so I just figured I’d ask. An example to illustrate is below.
from CADETProcess.processModel import LumpedRateModelWithPores
from CADETProcess.processModel import Inlet, Outlet
component_system = ComponentSystem(['1'])
feed.c = [24,]
column = LumpedRateModelWithPores(component_system, name='column')
column.length = 0.1
column.diameter = 0.016
column.particle_radius = 25e-6
column.bed_porosity = 0.4
column.particle_porosity = 0.93
column.axial_dispersion = 5e-8 # m^2/s
column.film_diffusion = [2.2e-5,]
flow_sheet.add_unit(feed)
flow_sheet.add_connection(feed, column)
flow_sheet.feed.flow_rate = 1e-7
process = Process(flow_sheet, 'fs')
process.cycle_time = 400
if __name__ == '__main__':
_ = simulation_results.solution.outlet.inlet.plot()
However if I try to change k_film at some point in the process when there is only a single component as
process.add_event(
'change_k_film',
'flow_sheet.column.film_diffusion',
[2.5e-5,],
time=100
I get this error message:
File ~/opt/anaconda3/envs/CADET-env/lib/python3.9/site-packages/CADETProcess/dynamicEvents/event.py:166 in add_event
evt = Event(name, self, parameter_path, state, time=time, indices=indices)
File ~/opt/anaconda3/envs/CADET-env/lib/python3.9/site-packages/CADETProcess/dynamicEvents/event.py:880 in __init__
self.indices = indices
File ~/opt/anaconda3/envs/CADET-env/lib/python3.9/site-packages/CADETProcess/dynamicEvents/event.py:1022 in indices
raise e
File ~/opt/anaconda3/envs/CADET-env/lib/python3.9/site-packages/CADETProcess/dynamicEvents/event.py:1020 in indices
_ = self.indices
File ~/opt/anaconda3/envs/CADET-env/lib/python3.9/site-packages/CADETProcess/dynamicEvents/event.py:994 in indices
indices = generate_indices(self.parameter_shape, self._indices)
File ~/opt/anaconda3/envs/CADET-env/lib/python3.9/site-packages/CADETProcess/dynamicEvents/section.py:663 in generate_indices
raise ValueError("Scalar parameters cannot have index slices.")
ValueError: Scalar parameters cannot have index slices.
where it looks like the error is just raised because the length of the list used to update k_film is 1. However should that not be the case when there is only one component in the system? When I run this example with two components it seems to work fine.
Thanks in advance for your help ![]()
