Radial Flow chromatography modelling
I am trying to model radial flow chromatography in CADET, but I am stuck on how to import the RFC in the code.
Does anyone want to share their experience on this matter?
Hi Kauthar and welcome to the forum!
Maybe you could give us some more information about what you’ve already tried?
Hi, I tried using one of the projects in the CADET process. I tried to modify it for RFC but I was getting an error ā€œImportError: cannot import name ā€˜radialcolumn’ from ā€˜CADETProcess.processModelā€™ā€
Q = 1e-6/60
from CADETProcess.processModel import Langmuir
    Inlet, Cstr, LumpedRateModelWithPores, Outlet
# Component System
component_system = ComponentSystem(['Protein'])
# Binding Model
binding_model = Langmuir(component_system, name='langmuir')
binding_model.adsorption_rate = [0.02]
binding_model.desorption_rate = [1]
binding_model.capacity = [100]
# Unit Operations
feed.c = [10]
eluent.c = [0]
# Mixer
valve = Cstr(component_system, 'valve')
valve.V = 1e-6
valve.flow_rate = Q
# Column
column.length = 0.1
column.diameter = 0.01
column.bed_porosity = 0.37
column.particle_porosity = 0.33
column.axial_dispersion = 2.0e-7
column.film_diffusion = [1e-4]
flow_sheet.add_unit(feed)
flow_sheet.add_unit(eluent)
flow_sheet.add_unit(valve)
flow_sheet.add_connection(feed, valve)
flow_sheet.add_connection(eluent, valve)
flow_sheet.add_connection(valve, column)
process = Process(flow_sheet, 'batch elution')
## Create Events and Durations
process.add_event('feed_on', 'flow_sheet.feed.flow_rate', Q, 0)
process.add_event('feed_off', 'flow_sheet.feed.flow_rate', 0.0, 60)
process.add_event('eluent_off', 'flow_sheet.eluent.flow_rate', 0.0, 0)
process.add_event('eluent_on', 'flow_sheet.eluent.flow_rate', Q, 60)
## Set Process Times
process.cycle_time = 1200
_ = simulation_results.solution.column.inlet.plot()
_ = simulation_results.solution.column.outlet.plot() or paste code here
Since the radial flow code is still quite experimental in CADET-Core, it’s not yet supported in CADET-Process. I’ve opened an issue on Github to track progress. If you want to work on this, I’m happy to review a PR.
Hi Kauthar,
alternatively you can use the CADET-Python interface and configure the radial flow column according to the CADET-Python documentation Radial Flow Models — CADET
Hi Jan,
Thanks for the suggestions. I will have a look at that.
Regards
Kauthar
