Simulation failed using HIC isotherm
Hi everyone,
I am trying to use HICConstantWaterActivity isotherm. I found an unexpect phenomenon, when I added a ‘CSTR’ the simulation never stops, but when I annotated “CSTR” code, the simulation succeeds very quickly. Would anyone know how to solve this problem? Thank you for your help.
Regards
Yang
The simulation never stops
from CADETProcess.processModel import Inlet
from CADETProcess.processModel import Cstr
from CADETProcess.processModel import HICConstantWaterActivity
from CADETProcess.processModel import GeneralRateModel
from CADETProcess.processModel import Outlet
from matplotlib.lines import Line2D
import matplotlib
matplotlib.use('Agg')
def Simulation():
    # Component System
    # Binding Model
    binding_model = HICConstantWaterActivity(component_system)
    binding_model.adsorption_rate = [0.0, 0.7, 1]
    binding_model.desorption_rate = [0.0, 1000, 1000]
    binding_model.hic_characteristic = [0.0, 10, 13]
    binding_model.capacity = [0.0, 10000000, 10000000]
    binding_model.beta_0 = 10. ** -0.5
    binding_model.beta_1 = 10. ** -3.65
    binding_model.bound_states = [0, 1, 1]
    Q = 1.94e-8
    salt_gradient_start_concentration = 3000
    salt_gradient_end_concentration = 50
    # Unit Operations
    inlet.flow_rate = Q
    inlet.c = [salt_gradient_start_concentration, 0, 0]
    column.length = 0.014
    column.diameter = 0.02
    column.bed_porosity = 0.37
    column.particle_porosity = 0.75
    column.axial_dispersion = 5.75e-8
    column.film_diffusion = column.n_comp * [6.9e-6]
    column.pore_diffusion = [7e-10, 6.07e-11, 6.07e-11]
    column.surface_diffusion = column.n_bound_states * [0.0]
    column.c = [salt_gradient_start_concentration, 0, 0]
    column.cp = [salt_gradient_start_concentration, 0, 0]
    column.q = [0, 0]
    # CSTR1
    cstr1 = Cstr(component_system, 'cstr1')
    cstr1.V = 1840.556e-9  # m^3
    cstr1.c = [salt_gradient_start_concentration, 0, 0]
    flow_sheet.add_unit(cstr1)
    flow_sheet.add_connection(inlet, cstr1)
    flow_sheet.add_connection(cstr1, column)
    # flow_sheet.add_connection(inlet, column)
    # flow_sheet.add_connection(column, outlet)
    process.cycle_time = 2000.0
    load_duration = 9
    t_gradient_start = 90.0
    gradient_duration = process.cycle_time - t_gradient_start
    c_load = np.array([salt_gradient_start_concentration, 1, 1])
    c_wash = np.array([salt_gradient_start_concentration, 0.0, 0.0])
    c_elute = np.array([salt_gradient_end_concentration, 0.0, 0.0])
    gradient_slope = (c_elute - c_wash) / gradient_duration
    process.add_event('load', 'flow_sheet.inlet.c', c_load)
    process.add_event('wash', 'flow_sheet.inlet.c', c_wash, load_duration)
    process.add_event('grad_start', 'flow_sheet.inlet.c', c_gradient_poly, t_gradient_start)
    # simulate
    results = simulator.simulate(process)
    t_SIM = results.solution.outlet.outlet.time
    c_A_SIM = results.solution.outlet.outlet.solution[:, 1]
    c_B_SIM = results.solution.outlet.outlet.solution[:, 2]
    t_salt_SIM = results.solution.outlet.outlet.time
    c_salt_SIM = results.solution.outlet.outlet.solution[:, 0]
    fig, ax1 = plt.subplots(figsize=(10, 6))
    coloura = np.array([247, 172, 83]) / 255
    colourcyto = np.array([236, 110, 102]) / 255
    coloursalt = np.array([120, 149, 193]) / 255
    ax1.set_xlabel('time s')
    ax1.set_ylabel('protein mg/mL', color='tab:blue')
    ax1.plot(t_SIM, c_A_SIM, '-', color=coloura)
    ax1.plot(t_SIM, c_B_SIM, '-', color=colourcyto)
    ax2 = ax1.twinx()
    ax2.set_ylabel('salt mM', color='tab:green')
    ax2.plot(t_salt_SIM, c_salt_SIM, '-', color=coloursalt)
    ax1.set_xlim([0, max(t_salt_SIM)])
    legend_elements_1 = [
        Line2D([0], [0], color=coloura, marker='o', linestyle='None', label='a'),
        Line2D([0], [0], color=colourcyto, marker='o', linestyle='None', label='cyto'),
        Line2D([0], [0], color=coloursalt, marker='o', linestyle='None', label='salt'),
    legend_elements_2 = [
        Line2D([0], [0], color=coloura, linestyle='-', label='SIM'),
    ax1.legend(handles=legend_elements_1, loc='upper left', fontsize=16)
    ax2.legend(handles=legend_elements_2, loc='upper right', fontsize=16)
    plt.tight_layout()
    plt.savefig('simulation_results.png')
Simulation()
Hello Yang,
thank you for the bug report! I can reproduce the problem with CADET-Core 4.4.0. With CADET-Core 5.0.3 both simulation setups run fine on my test machines on both Windows and Linux. If you’re on CADET-Core 4.4.0, please try updating CADET-Core. If that doesn’t help, please send me the output of conda env export > environment.yml.
Hello Ronald,
Thank you for your reply. It worked! I updated CADET-core to 5.0.3.
