** I tried several cases that all appeared unable to draw**
Here’s my code.
#Basic 4-zone SMB setup
import math
#Cadet.cadet_path = "C:/Users/kosh_000/cadet_build/CADET-dev/MS_SMKL_RELEASE/bin/cadet-cli.exe"
Cadet.cadet_path = r"C:\ProgramData\Anaconda3\pkgs\cadet-4.3.0-hbe28382_2\bin\cadet-cli.exe"
#use to render results
#number of columns in a cycle
cycle_size = 8
#number of cycles
cycles = 4
#number of times flows have to be expanded for a 4-zone model
repeat_size = int(cycle_size/4)
def gen_connections(units, cycle_size, size, step, flows, flows_static):
temp = []
connections = list(zip(units, np.roll(units,-1), flows))
io = np.roll(units, step)[[0, size*2, size-1, size*3-1]]
ios = list(zip([0, 1, 2, 3], io))
for connection in connections:
temp.append([connection[0], connection[1], -1, -1, connection[2]])
#inputs
idx = 0
for io in ios[:2]:
temp.append([io[0], io[1], -1, -1, flows_static[idx]])
idx+=1;
#outputs
for io in ios[2:]:
temp.append([io[1], io[0], -1, -1, flows_static[idx]])
idx+=1;
return np.array(temp)
def expand_flow(seq, inlet1, inlet2, number):
"expand the flows for smb, this is more complex since we need link values"
temp = []
temp.extend([seq[3] + inlet1] * (number-1))
temp.append(seq[0])
temp.extend([seq[0]] * (number-1))
temp.append(seq[1])
temp.extend([seq[1] + inlet2] * (number-1))
temp.append(seq[2])
temp.extend([seq[2]] * (number-1))
temp.append(seq[3])
return temp
def main():
smb = Cadet()
smb.filename = 'SMB.h5 '
createSimulation(smb)
print("Simulated Created")
smb.save()
smb.run()
smb.load()
print("Simulation Run")
plotSimulation(smb)
def createSimulation(simulation):
simulation.root.input.model.nunits = 4 + cycle_size
simulation.root.input.model.solver.gs_type = 1
simulation.root.input.model.solver.max_krylov = 0
simulation.root.input.model.solver.max_restarts = 0
simulation.root.input.model.solver.schur_safety = 1e-8
#setup connections
simulation.root.input.model.connections.nswitches = cycle_size
units = range(4, 4+cycle_size)
flows = expand_flow([7.66E-07, 7.66E-07, 8.08E-07, 8.08E-07], 0.98e-7, 1.96e-07, repeat_size)
flows_static = np.array([0.98e-7, 1.96e-7, 1.4e-7, 1.54e-7])
for i in range(cycle_size):
simulation.root.input.model.connections["switch_%03d" % i].section = i
simulation.root.input.model.connections["switch_%03d" % i].connections = gen_connections(units, cycle_size, repeat_size, -i, np.array(list(np.roll(flows, i))), flows_static )
#setup inlets
simulation.root.input.model.unit_000.inlet_type = 'PIECEWISE_CUBIC_POLY'
simulation.root.input.model.unit_000.ncomp = 2
simulation.root.input.model.unit_000.unit_type = 'INLET'
#section
simulation.root.input.model.unit_000["sec_%03d" % i].const_coeff = [0.55/180.16, 0.55/180.16]
simulation.root.input.model.unit_000["sec_%03d" % i].lin_coeff = [0.0, 0.0]
simulation.root.input.model.unit_000["sec_%03d" % i].quad_coeff = [0.0, 0.0]
simulation.root.input.model.unit_000["sec_%03d" % i].cube_coeff = [0.0, 0.0]
simulation.root.input.model.unit_001.inlet_type = 'PIECEWISE_CUBIC_POLY'
simulation.root.input.model.unit_001.ncomp = 2
simulation.root.input.model.unit_001.unit_type = 'INLET'
#section
simulation.root.input.model.unit_001["sec_%03d" % i].const_coeff = [0.0, 0.0]
simulation.root.input.model.unit_001["sec_%03d" % i].lin_coeff = [0.0, 0.0]
simulation.root.input.model.unit_001["sec_%03d" % i].quad_coeff = [0.0, 0.0]
simulation.root.input.model.unit_001["sec_%03d" % i].cube_coeff = [0.0, 0.0]
#create columns
for unit in range(4, 4 + cycle_size):
simulation.root.input.model["unit_%03d" % unit].unit_type = 'GENERAL_RATE_MODEL'
col = simulation.root.input.model["unit_%03d" % unit]
col.ncomp = 2
col.cross_section_area = math.pi * (0.02**2)/4.0
col.col_dispersion = 3.8148e-20
col.col_length = 0.25/repeat_size
col.col_porosity = 0.83
col.init_c = [0.0, 0.0]
col.init_q = [0.0, 0.0]
col.film_diffusion = [100.0, 100.0]
col.par_diffusion = [1.6e4, 1.6e4]
col.par_radius = 0.0005
col.par_porosity = 0.000001
col.par_surfdiffusion = [0.0, 0.0]
col.adsorption_model = 'LINEAR'
col.velocity = 1.0
col.adsorption.is_kinetic = 0
col.adsorption.lin_ka = [5.72, 7.7]
col.adsorption.lin_kd = [1.0, 1.0]
col.discretization.gs_type = 1
col.discretization.max_krylov = 0
col.discretization.max_restarts = 0
col.discretization.nbound = [1, 1]
col.discretization.ncol = 40
col.discretization.npar = 1
col.discretization.par_disc_type = 'EQUIDISTANT_PAR'
col.discretization.par_disc_vector = [0.0, 0.5, 1.0]
col.discretization.reconstruction = 'WENO'
col.discretization.schur_safety = 1e-8
col.discretization.use_analytic_jacobian = 1
col.discretization.weno.boundary_model = 0
col.discretization.weno.weno_eps = 1e-12
col.discretization.weno.weno_order = 3
#create outlets
simulation.root.input.model.unit_002.ncomp = 2
simulation.root.input.model.unit_002.unit_type = 'OUTLET'
simulation.root.input.model.unit_003.ncomp = 2
simulation.root.input.model.unit_003.unit_type = 'OUTLET'
#create output information
simulation.root.input['return'].write_solution_times = 1
ret = simulation.root.input['return']
ret.write_solution_last = 1
ret.unit_002.write_sens_column = 0
ret.unit_002.write_sens_column_inlet = 0
ret.unit_002.write_sens_column_outlet = 0
ret.unit_002.write_sens_flux = 0
ret.unit_002.write_sens_particle = 0
ret.unit_002.write_solution_column = 0
ret.unit_002.write_solution_column_inlet = 1
ret.unit_002.write_solution_column_outlet = 1
ret.unit_002.write_solution_flux = 0
ret.unit_002.write_solution_particle = 0
ret.unit_003.write_sens_column = 0
ret.unit_003.write_sens_column_inlet = 0
ret.unit_003.write_sens_column_outlet = 0
ret.unit_003.write_sens_flux = 0
ret.unit_003.write_sens_particle = 0
ret.unit_003.write_solution_column = 0
ret.unit_003.write_solution_column_inlet = 1
ret.unit_003.write_solution_column_outlet = 1
ret.unit_003.write_solution_flux = 0
ret.unit_003.write_solution_particle = 0
simulation.root.input.solver.nthreads = 0
simulation.root.input.solver.user_solution_times = np.linspace(0, cycles*180*4, 1000*cycle_size*cycles)
simulation.root.input.solver.sections.nsec = cycle_size*cycles
simulation.root.input.solver.sections.section_continuity = [0] * (cycle_size*cycles -1)
simulation.root.input.solver.sections.section_times = [float(i) * 180*4.0/cycle_size for i in range(cycle_size*cycles+1)]
simulation.root.input.solver.time_integrator.abstol = 1e-10
simulation.root.input.solver.time_integrator.algtol = 1e-10
simulation.root.input.solver.time_integrator.init_step_size = 1e-14
simulation.root.input.solver.time_integrator.max_steps = 1e6
simulation.root.input.solver.time_integrator.reltol = 1e-6
def plotSimulation(simulation):
solution_times = simulation.root.output.solution.solution_times
e_0 = simulation.root.output.solution.unit_002.solution_outlet_comp_000
e_1 = simulation.root.output.solution.unit_002.solution_outlet_comp_001
r_0 = simulation.root.output.solution.unit_003.solution_outlet_comp_000
r_1 = simulation.root.output.solution.unit_003.solution_outlet_comp_001
fig = plt.figure(figsize=[10, 2*10])
graph = fig.add_subplot(2, 1, 1)
graph.set_title("Extract")
graph.plot(solution_times, e_0, 'r', label='1')
graph.plot(solution_times, e_1, 'g', label='2')
graph.legend()
graph = fig.add_subplot(2, 1, 2)
graph.set_title("Raffinate")
graph.plot(solution_times, r_0, 'r', label='1')
graph.plot(solution_times, r_1, 'g', label='2')
graph.legend()
if __name__ == "__main__":
import sys
print(sys.version)
main()
And the error is follow.
ValueError Traceback (most recent call last)
Input In [3], in <cell line: 237>()
238 import sys
239 print(sys.version)
--> 240 main()
Input In [3], in main()
67 smb.load()
68 print("Simulation Run")
---> 69 plotSimulation(smb)
Input In [3], in plotSimulation(simulation)
221 graph = fig.add_subplot(2, 1, 1)
222 graph.set_title("Extract")
--> 224 graph.plot(solution_times, e_0, 'r', label='1')
225 graph.plot(solution_times, e_1, 'g', label='2')
226 graph.legend()
File C:\ProgramData\Anaconda3\lib\site-packages\matplotlib\axes\_axes.py:1632, in Axes.plot(self, scalex, scaley, data, *args, **kwargs)
1390 """
1391 Plot y versus x as lines and/or markers.
1392
1629 (``'green'``) or hex strings (``'#008000'``).
1630 """
1631 kwargs = cbook.normalize_kwargs(kwargs, mlines.Line2D)
-> 1632 lines = [*self._get_lines(*args, data=data, **kwargs)]
1633 for line in lines:
1634 self.add_line(line)
File C:\ProgramData\Anaconda3\lib\site-packages\matplotlib\axes\_base.py:312, in _process_plot_var_args.__call__(self, data, *args, **kwargs)
310 this += args[0],
311 args = args[1:]
--> 312 yield from self._plot_args(this, kwargs)
File C:\ProgramData\Anaconda3\lib\site-packages\matplotlib\axes\_base.py:487, in _process_plot_var_args._plot_args(self, tup, kwargs, return_kwargs)
484 kw[prop_name] = val
486 if len(xy) == 2:
--> 487 x = _check_1d(xy[0])
488 y = _check_1d(xy[1])
489 else:
File C:\ProgramData\Anaconda3\lib\site-packages\matplotlib\cbook\__init__.py:1304, in _check_1d(x)
1302 """Convert scalars to 1D arrays; pass-through arrays as is."""
1303 if not hasattr(x, 'shape') or len(x.shape) < 1:
-> 1304 return np.atleast_1d(x)
1305 else:
1306 try:
1307 # work around
1308 # https://github.com/pandas-dev/pandas/issues/27775 which
1319 # This code should correctly identify and coerce to a
1320 # numpy array all pandas versions.
File <__array_function__ internals>:5, in atleast_1d(*args, **kwargs)
File C:\ProgramData\Anaconda3\lib\site-packages\numpy\core\shape_base.py:65, in atleast_1d(*arys)
63 res = []
64 for ary in arys:
---> 65 ary = asanyarray(ary)
66 if ary.ndim == 0:
67 result = ary.reshape(1)
ValueError: invalid __array_struct__
