Trouble with the requirement for initial c and initial q in MobilePhaseModulator binding in CADET-Process
Hi, I was trying to use the Mobile Phase Modulator binding model in CADET-Process with component 1 being modulator and component 2 and 3 being some proteins.
I have 2 questions:
  1. The process does not converge when the initial c for the modulator component is set to 0 or a very low number like 1e-8, it does not matter that I provide a non-zero concentration through the inlets. If the initial c is set to 0 or any number 1e-8 or lower, it is not converging.
  2. Specifically for ion_exchange_characteristic: If I have let’s say 3 events. Load, wash and elute. If I have a non-zero concentration for modulator in wash event, the process does not converge for non-zero value of ion_exchange_characteristic. If I put 0 for ion_exchange_characteristic for all 3 components and some non-zero values for hydrophobicity, it works fine.
Here is my code (Commented out the trouble lines):
from CADETProcess.processModel import MobilePhaseModulator
from CADETProcess.processModel import Inlet, GeneralRateModel, Outlet
component_system.add_component('Elution Modulator')
component_system.add_component('Protein 1')
component_system.add_component('Protein 2')
binding_model = MobilePhaseModulator(component_system, name='Lang')
binding_model.adsorption_rate = [0, 2.6, 3]
binding_model.desorption_rate = [0, 0.005, 0.010]
binding_model.capacity = [1, 1, 1]
binding_model.ion_exchange_characteristic = [0, 0.2, 0.4] #[0,0,0] #
binding_model.hydrophobicity = [0, 1e-1, 2e-1] #[0,0,0] #
inlet.flow_rate = 2.88e-8
column.length = 0.65
column.diameter = 0.011286
column.bed_porosity = 0.37
column.particle_porosity = 0.33
column.axial_dispersion = 2.0e-7
column.film_diffusion = [2.0e-7, 2.0e-7, 2.0e-7]
column.pore_diffusion = [1e-7, 1e-7, 1e-7]
column.surface_diffusion = [0.0, 0.0, 0.0]
process.cycle_time = 500000
## Create Events and Durations
wash_start = 400
elute_start = 12000
_ = process.add_event('load', 'flow_sheet.inlet.c', [0.1, 0.1, 0.1])
_ = process.add_event('wash', 'flow_sheet.inlet.c', [0.1, 0.0, 0.0], wash_start)
# Trouble number 2: Not allowing 0 c during wash if non-zero ion_exchange_characteristic
# Non-zero hydrophobicity with 0 ion_exchange_characteristic converges
# _ = process.add_event('wash', 'flow_sheet.inlet.c', [0.0, 0.0, 0.0], wash_start)
_ = process.add_event('elute', 'flow_sheet.inlet.c', [70, 0.0, 0.0], elute_start)
column.c = [1, 0, 0]
# Trouble number 1: initial column c value for modulator component doesn't converge if 1e-8 or lower or 0
# column.c = [1e-8, 0, 0]
# column.c = [0, 0, 0]
column.q = [0, 0, 0]
if __name__ == '__main__':
    process_simulator = Cadet(install_path="/Users/name/CADET/install")
    simulation_results.solution.column.outlet.plot()
Hi Ronan,
the Mobile Phase Modulator binding model raises the modulator concentration to a non-integer power, which creates NaNs if the modulator concentrations gets negative and causes CADET to crash.
During abrupt changes in concentrations there are fluctuations in the local concentration, which can go into the negatives if you start at 0 or close to it.
Values fo c0 that worked for me were above 1e-6.
Hi, Ronan,
Can you help me answer some questions?
Have you solved your problem? Is your modulator an organic solvent?
