There are a couple of challenges that I face when writing examples:
- The examples should be provided as Jupyter Notebooks so that they can include equations, figures, links, etc. and can be included in our documentation.
- Additionally, the examples should be directly executable so that users can download and run them immediately. Equally important, I can easily import the examples into other scripts without having to rewrite (and maintain) large sections of boilerplate model-setup code.
However, maintaining the examples both as .ipynb and .py files is a PITA.
Enter jupytext. This handy tool allows me to achieve exactly this: synchronizing two versions so that any change in one version is automatically transferred to the other.
To install jupytext, run
pip install jupytext
or
[conda/mamba] install -c conda-forge jupytext
There are different ways to sync the files. For a detailed introduction, refer to their documentation, but here’s the way I do it:
I write my notebooks in MyST (highly recommended!). For this purpose, I add the following header to the file:
jupytext:
formats: md:myst,py:percent
main_language: python
text_representation:
extension: .md
format_name: myst
format_version: 0.13
jupytext_version: 1.14.5
kernelspec:
display_name: Python 3
This configuration registers the file for jupytext. It also defines the file formats to which I want to synchronize the file. Besides md:myst, I use py:percent, a representation of Jupyter notebooks as scripts.
To sync, I can run:
jupytext --sync
which will sync all files in the current directory.
To automate this in my Git workflow, I installed pre-commit, which automatically runs this command on every commit, ensuring that both versions are synced.
repos:
# Jupytext
- repo: https://github.com/mwouts/jupytext
rev: v1.14.5
hooks:
- id: jupytext
files: 'examples/[^/]+/'
types_or: [markdown, python]
exclude: |
(?x)^(
README.md|
examples/[^/]+/index.md|
examples/[^/]+/index.py
args: [--sync]
Note that I used some regex magic to specify which files to sync (and which to ignore).
There are also other useful things to do with pre-commit. For example, you could automatically remove trailing whitespace, or check YAML files (who understands YAML syntax anyway?
repos:
# pre-commit-hooks
- repo: https://github.com/pre-commit/pre-commit-hooks
rev: v4.1.0
hooks:
- id: check-merge-conflict
- id: check-yaml
- id: end-of-file-fixer
- id: trailing-whitespace
