AttributeError when running check_cadet() method
I am trying to follow the CADET Process workshop available on GitHub.
In … / 02.1.1_breakthrough.ipynb I run
simulator.check_cadet()
and get the following error:
AttributeError                            Traceback (most recent call last)
Cell In[10], line 1
----> 1 simulator.check_cadet()
File ~\AppData\Local\anaconda3\envs\cadet_workshop\Lib\site-packages\CADETProcess\simulator\cadetAdapter.py:319, in Cadet.check_cadet(self)
    316 data = cadet_model.run()
    317 os.remove(lwe_hdf5_path)
--> 319 if data.returncode == 0:
    320     flag = True
    321     print("Test simulation completed successfully")
AttributeError: 'ReturnInformation' object has no attribute 'returncode'
Additional details: Installed using conda and running in a JupyterLab notebook. I didn’t clone from github because I am on my company labtop (Windows 10 Enterprise) but I built the environment from the .yml file as recommended in the readme (copy of my env is in attachment). I have also tried the same on my personal Linux machine (Fedora 40) with the same result.
I already tried running as python script (.py file instead of running inside a iPython notebook) and also tried specifying the location of the cadet-cli executable wirh
simulator = Cadet(install_path=‘C:/Users/at1mad2/AppData/Local/anaconda3/pkgs/cadet-5.0.1-h6c8fd53_0/bin/cadet-cli.exe’)
but I still get the same error message.
Can someone help me finding out what is happening here? I guess I am making some error during the installation process, but I can’t solve it myself. Do I need to configure something in the cadet-cli before?
Thank you in advance,
Duarte Martins
environment-export.txt (5.5 KB)
thank you for the detailed and thorough report! I think you did everything right and this is a bug that we have fixed, but have not released in an update yet. Can you try running this command in your conda environment?
This will install the current development version of CADET-Process and should fix that issue. If not, let me know and I’ll look more into it.
Best wishes,
Ron
Hi Roland,
Thank you for quick answer.
I installed the dev branch as suggested in the same env however it did not fix the issue and the same issure remains. Just in case, I copied below the messages shown when I installed the dev version:
(cadet_workshop) C:\Users\at1mad2>pip install git+https://github.com/fau-advanced-separations/CADET-Process.git@dev
Collecting git+https://github.com/fau-advanced-separations/CADET-Process.git@dev
  Cloning https://github.com/fau-advanced-separations/CADET-Process.git (to revision dev) to c:\users\at1mad2\appdata\local\temp\pip-req-build-13d0zy3d
  Running command git clone --filter=blob:none --quiet https://github.com/fau-advanced-separations/CADET-Process.git 'C:\Users\at1mad2\AppData\Local\Temp\pip-req-build-13d0zy3d'
  Running command git checkout -b dev --track origin/dev
  branch 'dev' set up to track 'origin/dev'.
  Switched to a new branch 'dev'
  Resolved https://github.com/fau-advanced-separations/CADET-Process.git to commit 8384f14e2b49529cc92c47909a9e18b4bea8085d
  Installing build dependencies ... done
  Getting requirements to build wheel ... done
  Preparing metadata (pyproject.toml) ... done
Requirement already satisfied: addict==2.3 in c:\users\at1mad2\appdata\local\anaconda3\envs\cadet_workshop\lib\site-packages (from CADET-Process==0.9.1) (2.3.0)
Requirement already satisfied: cadet-python>=1.0 in c:\users\at1mad2\appdata\local\anaconda3\envs\cadet_workshop\lib\site-packages (from CADET-Process==0.9.1) (1.0.1)
Requirement already satisfied: corner>=2.2.1 in c:\users\at1mad2\appdata\local\anaconda3\envs\cadet_workshop\lib\site-packages (from CADET-Process==0.9.1) (2.2.3)
Requirement already satisfied: diskcache>=5.4.0 in c:\users\at1mad2\appdata\local\anaconda3\envs\cadet_workshop\lib\site-packages (from CADET-Process==0.9.1) (5.6.3)
Requirement already satisfied: hopsy>=1.4.0 in c:\users\at1mad2\appdata\local\anaconda3\envs\cadet_workshop\lib\site-packages (from CADET-Process==0.9.1) (1.5.2)
Requirement already satisfied: joblib>=1.3.0 in c:\users\at1mad2\appdata\local\anaconda3\envs\cadet_workshop\lib\site-packages (from CADET-Process==0.9.1) (1.4.2)
Requirement already satisfied: numpy>=1.21 in c:\users\at1mad2\appdata\local\anaconda3\envs\cadet_workshop\lib\site-packages (from CADET-Process==0.9.1) (1.26.4)
Requirement already satisfied: matplotlib>=3.4 in c:\users\at1mad2\appdata\local\anaconda3\envs\cadet_workshop\lib\site-packages (from CADET-Process==0.9.1) (3.9.2)
Requirement already satisfied: numba>=0.55.1 in c:\users\at1mad2\appdata\local\anaconda3\envs\cadet_workshop\lib\site-packages (from CADET-Process==0.9.1) (0.60.0)
Requirement already satisfied: pathos>=0.2.8 in c:\users\at1mad2\appdata\local\anaconda3\envs\cadet_workshop\lib\site-packages (from CADET-Process==0.9.1) (0.3.3)
Requirement already satisfied: psutil>=5.9.8 in c:\users\at1mad2\appdata\local\anaconda3\envs\cadet_workshop\lib\site-packages (from CADET-Process==0.9.1) (6.1.0)
Requirement already satisfied: pymoo>=0.6 in c:\users\at1mad2\appdata\local\anaconda3\envs\cadet_workshop\lib\site-packages (from CADET-Process==0.9.1) (0.6.1.3)
Requirement already satisfied: scipy>=1.11 in c:\users\at1mad2\appdata\local\anaconda3\envs\cadet_workshop\lib\site-packages (from CADET-Process==0.9.1) (1.14.1)
Requirement already satisfied: h5py in c:\users\at1mad2\appdata\local\anaconda3\envs\cadet_workshop\lib\site-packages (from cadet-python>=1.0->CADET-Process==0.9.1) (3.12.1)
Requirement already satisfied: filelock in c:\users\at1mad2\appdata\local\anaconda3\envs\cadet_workshop\lib\site-packages (from cadet-python>=1.0->CADET-Process==0.9.1) (3.16.1)
Requirement already satisfied: PolyRound>=0.2.10 in c:\users\at1mad2\appdata\local\anaconda3\envs\cadet_workshop\lib\site-packages (from hopsy>=1.4.0->CADET-Process==0.9.1) (0.3.0)
Requirement already satisfied: optlang>=1.7.0 in c:\users\at1mad2\appdata\local\anaconda3\envs\cadet_workshop\lib\site-packages (from hopsy>=1.4.0->CADET-Process==0.9.1) (1.8.2)
Requirement already satisfied: mcbackend in c:\users\at1mad2\appdata\local\anaconda3\envs\cadet_workshop\lib\site-packages (from hopsy>=1.4.0->CADET-Process==0.9.1) (0.5.2)
Requirement already satisfied: pandas in c:\users\at1mad2\appdata\local\anaconda3\envs\cadet_workshop\lib\site-packages (from hopsy>=1.4.0->CADET-Process==0.9.1) (2.2.3)
Requirement already satisfied: tqdm in c:\users\at1mad2\appdata\local\anaconda3\envs\cadet_workshop\lib\site-packages (from hopsy>=1.4.0->CADET-Process==0.9.1) (4.67.1)
Requirement already satisfied: scikit-learn in c:\users\at1mad2\appdata\local\anaconda3\envs\cadet_workshop\lib\site-packages (from hopsy>=1.4.0->CADET-Process==0.9.1) (1.5.2)
Requirement already satisfied: arviz in c:\users\at1mad2\appdata\local\anaconda3\envs\cadet_workshop\lib\site-packages (from hopsy>=1.4.0->CADET-Process==0.9.1) (0.20.0)
Requirement already satisfied: contourpy>=1.0.1 in c:\users\at1mad2\appdata\local\anaconda3\envs\cadet_workshop\lib\site-packages (from matplotlib>=3.4->CADET-Process==0.9.1) (1.3.1)
Requirement already satisfied: cycler>=0.10 in c:\users\at1mad2\appdata\local\anaconda3\envs\cadet_workshop\lib\site-packages (from matplotlib>=3.4->CADET-Process==0.9.1) (0.12.1)
Requirement already satisfied: fonttools>=4.22.0 in c:\users\at1mad2\appdata\local\anaconda3\envs\cadet_workshop\lib\site-packages (from matplotlib>=3.4->CADET-Process==0.9.1) (4.55.0)
Requirement already satisfied: kiwisolver>=1.3.1 in c:\users\at1mad2\appdata\local\anaconda3\envs\cadet_workshop\lib\site-packages (from matplotlib>=3.4->CADET-Process==0.9.1) (1.4.7)
Requirement already satisfied: packaging>=20.0 in c:\users\at1mad2\appdata\local\anaconda3\envs\cadet_workshop\lib\site-packages (from matplotlib>=3.4->CADET-Process==0.9.1) (24.2)
Requirement already satisfied: pillow>=8 in c:\users\at1mad2\appdata\local\anaconda3\envs\cadet_workshop\lib\site-packages (from matplotlib>=3.4->CADET-Process==0.9.1) (11.0.0)
Requirement already satisfied: pyparsing>=2.3.1 in c:\users\at1mad2\appdata\local\anaconda3\envs\cadet_workshop\lib\site-packages (from matplotlib>=3.4->CADET-Process==0.9.1) (3.2.0)
Requirement already satisfied: python-dateutil>=2.7 in c:\users\at1mad2\appdata\local\anaconda3\envs\cadet_workshop\lib\site-packages (from matplotlib>=3.4->CADET-Process==0.9.1) (2.9.0.post0)
Requirement already satisfied: llvmlite<0.44,>=0.43.0dev0 in c:\users\at1mad2\appdata\local\anaconda3\envs\cadet_workshop\lib\site-packages (from numba>=0.55.1->CADET-Process==0.9.1) (0.43.0)
Requirement already satisfied: ppft>=1.7.6.9 in c:\users\at1mad2\appdata\local\anaconda3\envs\cadet_workshop\lib\site-packages (from pathos>=0.2.8->CADET-Process==0.9.1) (1.7.6.9)
Requirement already satisfied: dill>=0.3.9 in c:\users\at1mad2\appdata\local\anaconda3\envs\cadet_workshop\lib\site-packages (from pathos>=0.2.8->CADET-Process==0.9.1) (0.3.9)
Requirement already satisfied: pox>=0.3.5 in c:\users\at1mad2\appdata\local\anaconda3\envs\cadet_workshop\lib\site-packages (from pathos>=0.2.8->CADET-Process==0.9.1) (0.3.5)
Requirement already satisfied: multiprocess>=0.70.17 in c:\users\at1mad2\appdata\local\anaconda3\envs\cadet_workshop\lib\site-packages (from pathos>=0.2.8->CADET-Process==0.9.1) (0.70.17)
Requirement already satisfied: autograd>=1.4 in c:\users\at1mad2\appdata\local\anaconda3\envs\cadet_workshop\lib\site-packages (from pymoo>=0.6->CADET-Process==0.9.1) (1.7.0)
Requirement already satisfied: cma==3.2.2 in c:\users\at1mad2\appdata\local\anaconda3\envs\cadet_workshop\lib\site-packages (from pymoo>=0.6->CADET-Process==0.9.1) (3.2.2)
Requirement already satisfied: alive-progress in c:\users\at1mad2\appdata\local\anaconda3\envs\cadet_workshop\lib\site-packages (from pymoo>=0.6->CADET-Process==0.9.1) (3.2.0)
Requirement already satisfied: Deprecated in c:\users\at1mad2\appdata\local\anaconda3\envs\cadet_workshop\lib\site-packages (from pymoo>=0.6->CADET-Process==0.9.1) (1.2.15)
Requirement already satisfied: swiglpk>=5.0.8 in c:\users\at1mad2\appdata\local\anaconda3\envs\cadet_workshop\lib\site-packages (from optlang>=1.7.0->hopsy>=1.4.0->CADET-Process==0.9.1) (5.0.12)
Requirement already satisfied: sympy>=1.12.0 in c:\users\at1mad2\appdata\local\anaconda3\envs\cadet_workshop\lib\site-packages (from optlang>=1.7.0->hopsy>=1.4.0->CADET-Process==0.9.1) (1.13.3)
Requirement already satisfied: pytz>=2020.1 in c:\users\at1mad2\appdata\local\anaconda3\envs\cadet_workshop\lib\site-packages (from pandas->hopsy>=1.4.0->CADET-Process==0.9.1) (2024.2)
Requirement already satisfied: tzdata>=2022.7 in c:\users\at1mad2\appdata\local\anaconda3\envs\cadet_workshop\lib\site-packages (from pandas->hopsy>=1.4.0->CADET-Process==0.9.1) (2024.2)
Requirement already satisfied: six>=1.5 in c:\users\at1mad2\appdata\local\anaconda3\envs\cadet_workshop\lib\site-packages (from python-dateutil>=2.7->matplotlib>=3.4->CADET-Process==0.9.1) (1.16.0)
Requirement already satisfied: about-time==4.2.1 in c:\users\at1mad2\appdata\local\anaconda3\envs\cadet_workshop\lib\site-packages (from alive-progress->pymoo>=0.6->CADET-Process==0.9.1) (4.2.1)
Requirement already satisfied: grapheme==0.6.0 in c:\users\at1mad2\appdata\local\anaconda3\envs\cadet_workshop\lib\site-packages (from alive-progress->pymoo>=0.6->CADET-Process==0.9.1) (0.6.0)
Requirement already satisfied: setuptools>=60.0.0 in c:\users\at1mad2\appdata\local\anaconda3\envs\cadet_workshop\lib\site-packages (from arviz->hopsy>=1.4.0->CADET-Process==0.9.1) (75.6.0)
Requirement already satisfied: xarray>=2022.6.0 in c:\users\at1mad2\appdata\local\anaconda3\envs\cadet_workshop\lib\site-packages (from arviz->hopsy>=1.4.0->CADET-Process==0.9.1) (2024.11.0)
Requirement already satisfied: h5netcdf>=1.0.2 in c:\users\at1mad2\appdata\local\anaconda3\envs\cadet_workshop\lib\site-packages (from arviz->hopsy>=1.4.0->CADET-Process==0.9.1) (1.4.1)
Requirement already satisfied: typing-extensions>=4.1.0 in c:\users\at1mad2\appdata\local\anaconda3\envs\cadet_workshop\lib\site-packages (from arviz->hopsy>=1.4.0->CADET-Process==0.9.1) (4.12.2)
Requirement already satisfied: xarray-einstats>=0.3 in c:\users\at1mad2\appdata\local\anaconda3\envs\cadet_workshop\lib\site-packages (from arviz->hopsy>=1.4.0->CADET-Process==0.9.1) (0.8.0)
Requirement already satisfied: wrapt<2,>=1.10 in c:\users\at1mad2\appdata\local\anaconda3\envs\cadet_workshop\lib\site-packages (from Deprecated->pymoo>=0.6->CADET-Process==0.9.1) (1.17.0)
Requirement already satisfied: betterproto==2.0.0b6 in c:\users\at1mad2\appdata\local\anaconda3\envs\cadet_workshop\lib\site-packages (from mcbackend->hopsy>=1.4.0->CADET-Process==0.9.1) (2.0.0b6)
Requirement already satisfied: hagelkorn in c:\users\at1mad2\appdata\local\anaconda3\envs\cadet_workshop\lib\site-packages (from mcbackend->hopsy>=1.4.0->CADET-Process==0.9.1) (1.2.3)
Requirement already satisfied: grpclib<0.5.0,>=0.4.1 in c:\users\at1mad2\appdata\local\anaconda3\envs\cadet_workshop\lib\site-packages (from betterproto==2.0.0b6->mcbackend->hopsy>=1.4.0->CADET-Process==0.9.1) (0.4.7)
Requirement already satisfied: threadpoolctl>=3.1.0 in c:\users\at1mad2\appdata\local\anaconda3\envs\cadet_workshop\lib\site-packages (from scikit-learn->hopsy>=1.4.0->CADET-Process==0.9.1) (3.5.0)
Requirement already satisfied: colorama in c:\users\at1mad2\appdata\local\anaconda3\envs\cadet_workshop\lib\site-packages (from tqdm->hopsy>=1.4.0->CADET-Process==0.9.1) (0.4.6)
Requirement already satisfied: mpmath<1.4,>=1.1.0 in c:\users\at1mad2\appdata\local\anaconda3\envs\cadet_workshop\lib\site-packages (from sympy>=1.12.0->optlang>=1.7.0->hopsy>=1.4.0->CADET-Process==0.9.1) (1.3.0)
Requirement already satisfied: h2<5,>=3.1.0 in c:\users\at1mad2\appdata\local\anaconda3\envs\cadet_workshop\lib\site-packages (from grpclib<0.5.0,>=0.4.1->betterproto==2.0.0b6->mcbackend->hopsy>=1.4.0->CADET-Process==0.9.1) (4.1.0)
Requirement already satisfied: multidict in c:\users\at1mad2\appdata\local\anaconda3\envs\cadet_workshop\lib\site-packages (from grpclib<0.5.0,>=0.4.1->betterproto==2.0.0b6->mcbackend->hopsy>=1.4.0->CADET-Process==0.9.1) (6.1.0)
Requirement already satisfied: hyperframe<7,>=6.0 in c:\users\at1mad2\appdata\local\anaconda3\envs\cadet_workshop\lib\site-packages (from h2<5,>=3.1.0->grpclib<0.5.0,>=0.4.1->betterproto==2.0.0b6->mcbackend->hopsy>=1.4.0->CADET-Process==0.9.1) (6.0.1)
Requirement already satisfied: hpack<5,>=4.0 in c:\users\at1mad2\appdata\local\anaconda3\envs\cadet_workshop\lib\site-packages (from h2<5,>=3.1.0->grpclib<0.5.0,>=0.4.1->betterproto==2.0.0b6->mcbackend->hopsy>=1.4.0->CADET-Process==0.9.1) (4.0.0)
I also noted that the version number of cadet-process did not change (neither did those of cadet and cadet-python) but I am note sure if that is relevant/expected as I am fairly inexperienced with git and version control.
I also tried running as .py script but with the same result.
Do you have a further suggestion?
Thank you again for the help.
Duarte
Hey,
if that’s the full output then it didn’t reinstall CADET-Process (because it was already installed).
Let’s try this again with
pip install git+https://github.com/fau-advanced-separations/CADET-Process.git@dev --force-reinstall --no-deps
hi,
I ran the force reinstall command you suggested above and got the following output:
(cadet_workshop) C:\Users\at1mad2>pip install git+https://github.com/fau-advanced-separations/CADET-Process.git@dev --force-reinstall --no-deps
  Cloning https://github.com/fau-advanced-separations/CADET-Process.git (to revision dev) to c:\users\at1mad2\appdata\local\temp\pip-req-build-zhuqa46g
  Running command git clone --filter=blob:none --quiet https://github.com/fau-advanced-separations/CADET-Process.git 'C:\Users\at1mad2\AppData\Local\Temp\pip-req-build-zhuqa46g'
Building wheels for collected packages: CADET-Process
  Building wheel for CADET-Process (pyproject.toml) ... done
  Created wheel for CADET-Process: filename=CADET_Process-0.9.1-py3-none-any.whl size=46249 sha256=6777f6ddea07dce0b4d4a780eb6cf63d8fffced339cb1f53bdb3ea3c360c8ed1
  Stored in directory: C:\Users\at1mad2\AppData\Local\Temp\pip-ephem-wheel-cache-sv7ogmmw\wheels\7f\39\3c\45357f9169a582bfd0e80a5f98bb719999797bf20e036dd5f7
Successfully built CADET-Process
Installing collected packages: CADET-Process
  Attempting uninstall: CADET-Process
    Found existing installation: CADET-Process 0.9.1
    Uninstalling CADET-Process-0.9.1:
      Successfully uninstalled CADET-Process-0.9.1
Successfully installed CADET-Process-0.9.1
however when I go back to workshop file I get a different error message at the very first import, more specifically while importing ComponentSystem, see below the details.
ModuleNotFoundError                       Traceback (most recent call last)
Cell In[1], line 1
----> 1 from CADETProcess.processModel import ComponentSystem
      3 component_system = ComponentSystem(1)
File ~\AppData\Local\anaconda3\envs\cadet_workshop\Lib\site-packages\CADETProcess\__init__.py:20
     16 from .CADETProcessError import *
     18 from . import log
---> 20 from .settings import Settings
     22 settings = Settings()
     24 from . import sysinfo
File ~\AppData\Local\anaconda3\envs\cadet_workshop\Lib\site-packages\CADETProcess\settings.py:22
     19 import tempfile
     20 from warnings import warn
---> 22 from CADETProcess.dataStructure import Structure
     23 from CADETProcess.dataStructure import Bool, Switch
     26 __all__ = ['Settings']
ModuleNotFoundError: No module named 'CADETProcess.dataStructure'
can you advise me further?
thank you,
Duarte
Hi Duarte,
please excuse the current state of CADET-Process. We were very focussed on the release CADET-Core v5 and now we need to catch up in the higher level packages so we will have to ask for a bit of patience.
The latest issue you’re describing is related to this here: Dev branch pip install not working. An update will follow shortly.
Hi Johannes,
I understand that. I will keep an eye on that post.
Thank you,
Duarte
