CADET-Core v6 pre-releases and release strategy
Dear CADET users,
we would like to inform you about our plan regarding the further development of CADET-Core.
Version 6 of CADET-Core is planned and will introduce new features as well as a number of interface changes. With usability and long-term maintainability in mind, we aim to bundle all foreseeable interface changes of established features into this single major release.
There is currently no fixed release date. However, planned changes and features are tracked in the corresponding GitHub milestone.
With the upcoming interface changes, it is increasingly important to consult the correct interface documentation by selecting the appropriate branch or release version at https://cadet.github.io/.
Release strategy and code distribution
  • CADET-Core v5.1 will continue to be supported with bug fixes until v6 is fully released.
  • Pre-releases require CADET-Python>=1.1.2, old CADET-Core releases will still work with the updated CADET-Python.
  • Until the official release of v6, we will regularly publish v6 pre-releases on conda-forge.
    • Users can install a v6 pre-release (e.g. v6.0.0a3) via
      conda install -c conda-forge/label/cadet-core_dev cadet=6.0.0a3
      or pip install CADET-Core==6.0.0a3
    • the latest v5 release will remain the default and as usual be install via
      conda install -c conda-forge cadet or pip install CADET-Core
    • Users interested in new features can already use these pre-releases but should be prepared to adapt to the evolving interface.
    • While we cannot guarantee a stable interface during the pre-release phase, we aim to modify each affected part of the interface only once.
Continuation of v5
No new features are currently planned for v5 or its legacy interface.
If there is strong interest (e.g., for joint publications or other collaborative efforts), please reach out to usโ€”we may be able to find a solution, including more formal arrangements.
v5 will be supported with bug fixes.
CADET-Process
CADET-Process will maintain its current API until after the release of CADET-Core v6. Following the v6 release, we will begin adapting to the new CADET-Core interface and implementing some internal restructuring. These changes may introduce breaking updates, but they will not occur immediately. We will communicate further details as the process unfolds.
If you have questions or would like to discuss specific use cases, feel free to contact us.
The CADET team
CADET-Core Version 6.0.0-alpha.1 Release Announcement
CADET-Core v6.0.0-alpha.1 is a pre-release introducing a new interface, new features and bug fixes.
We recommend updating to the pre-release version only if you need a new feature because the interface might change further. Otherwise, we suggest staying on the latest stable v5 release.
Breaking changes are highlighted using bold text
Added
Changed / Updated
Fixed
Deprecated
Full Changelog: Comparing v5.1.X...v6.0.0-alpha.1 ยท cadet/CADET-Core ยท GitHub
For a full change log, including highlighted interface/breaking changes, please refer to the release description on GitHub.
CADET-Core Version 6.0.0-alpha.2 Release Announcement
CADET-Core v6.0.0-alpha.2 is a pre-release introducing new features and bug fixes and updating the interface.
Added
Changed/Updated
Fixed
New Contributors
Full Changelog: Comparing v6.0.0-alpha.1...v6.0.0-alpha.2 ยท cadet/CADET-Core ยท GitHub
CADET-Core Version 6.0.0-alpha.3 Release Announcement
CADET-Core v6.0.0-alpha.3 is a pre-release introducing new features, bug fixes and improvements.
Added
Fixed
Updated
Full Changelog: Comparing v6.0.0-alpha.2...v6.0.0a3 ยท cadet/CADET-Core ยท GitHub
CADET-Core Version 6.0.0-alpha.4 Release Announcement
CADET-Core v6.0.0-alpha.4 is a pre-release introducing new features, bug fixes and improvements.
Added
Fixed
Changed
New Contributors
Full Changelog: Comparing v6.0.0a3...v6.0.0a4 ยท cadet/CADET-Core ยท GitHub
CADET-Core v6.0.0a5 release announcement
CADET-Core v6.0.0a5 is the fifth pre-release of v6.0.0 introducing new features, bug fixes and improvements.
Added
Fixed
New Contributors
Full Changelog: Comparing v6.0.0a4...v6.0.0a5 ยท cadet/CADET-Core ยท GitHub
