CADET Match fit with total concentration
I am trying to use CADET Match to fit the multicomponent model (2 components or 3 components). I have lerned from the cadet tutorial we can fit the model with the experimental data of one componente while setting output_path as β€˜/output/solution/unit_001/SOLUTION_OUTLET_COMP_000’. But I dont know is it possible to fit with the total concentration.
I really appreciate if someone can help.
All you should have to do is assign the outlet concentration profiles for each component (COMP_000, _001, _002, …) to an array and use this as the input to CADET-match instead.
