Comparison and Optimisation of multiple experiments with multiple simulations - Cadet Process
I am trying to optimise the film diffusion for three experiments. Each of the experiments was previously simulated and saved in a simulation_results list.
Now I am trying to compare experiment 1 (reference1) with simulation 1 (simulation_results[0]), experiment 2 with simulation 2 and experiment 3 with simulation 3 and optimise the film diffusion for all 3 experiments.
However, this does not work as the simulation is compared with all previously added experiments and I have no further idea how to implement this.
My current code for the comparison and optimisation is as follows:
comparator = Comparator()
comparator.add_reference(reference1) #Experiment 1
comparator.add_difference_metric('Shape', reference1,'outlet.outlet', components="Protein")
comparator.plot_comparison(simulation_results[0],  plot_individual=True)
comparator.add_reference(reference2) #Experiment 2
comparator.add_difference_metric('Shape', reference2,'outlet.outlet', components="Protein")
comparator.plot_comparison(simulation_results[1],  plot_individual=True)
comparator.add_reference(reference3) #Experiment 3
comparator.add_difference_metric('Shape', reference3,'outlet.outlet', components="Protein")
comparator.plot_comparison(simulation_results[2],  plot_individual=True)
optimization_problem = OptimizationProblem('Film_diffusion')
optimization_problem.add_evaluation_object(process1) #Process of Simulation 1
optimization_problem.add_evaluation_object(process2) #Process of Simulation 2
optimization_problem.add_evaluation_object(process3) #Process of Simulation 3
    name='film_diffusion', parameter_path='flow_sheet.column.film_diffusion',
    lb=1e-10, ub=0.1,
    transform='auto'
optimization_problem.add_evaluator(simulator)
    comparator,
    n_objectives=comparator.n_metrics,
    requires=[simulator]
def callback(simulation_results, individual, evaluation_object, callbacks_dir='./'):
        simulation_results,
        file_name=f'{callbacks_dir}/{individual.id}_{evaluation_object}_comparison.png',
        show=False
optimization_problem.add_callback(callback, requires=[simulator])
optimizer = U_NSGA3()
if __name__ == '__main__':
    optimization_results = optimizer.optimize(
        optimization_problem,
        use_checkpoint=True
I would be very grateful for any help!
Stefanos
Hey Stefanos,
you’ll need multiple comparators.
I’ve recently created an example to illustrate using multiple experiments in one optimization problem. As that hasn’t made it into the master branch yet, you’ll have to use the link above and can’t find it on the regular readthedocs website.
Let me know if you need further input.
Hello Ronald,
Thanks for the quick reply! I was able to use your example for my own code.
However, I get the following error:
File ~\anaconda3\envs\Test\lib\site-packages\pymoo\core\problem.py:355, in Problem._format_dict(self, out, N, return_values_of)
    354 try:
--> 355     v = v.reshape(shape[name])
    356 except Exception as e:
ValueError: cannot reshape array of size 612 into shape (34,6)
During handling of the above exception, another exception occurred:
Exception                                 Traceback (most recent call last)
Cell In[13], line 7
      5 optimizer.pop_size = 50
      6 optimizer.n_max_gen = 5
----> 7 optimization_results = optimizer.optimize(
      8     optimization_problem,
      9     use_checkpoint=False
     10      )
File ~\anaconda3\envs\Test\lib\site-packages\CADETProcess\optimization\optimizer.py:260, in OptimizerBase.optimize(self, optimization_problem, x0, save_results, results_directory, use_checkpoint, overwrite_results_directory, exist_ok, log_level, reinit_cache, delete_cache, *args, **kwargs)
    256 plt.switch_backend('agg')
    258 start = time.time()
--> 260 self.run(self.optimization_problem, x0, *args, **kwargs)
    262 self.results.time_elapsed = time.time() - start
    264 if delete_cache:
File ~\anaconda3\envs\Test\lib\site-packages\CADETProcess\optimization\pymooAdapter.py:155, in PymooInterface.run(self, optimization_problem, x0)
    152 X = pop.get("X").tolist()
    154 # Evaluate objectives and report results
--> 155 algorithm.evaluator.eval(problem, pop)
    157 F = pop.get("F").tolist()
    158 if optimization_problem.n_nonlinear_constraints > 0:
File ~\anaconda3\envs\Test\lib\site-packages\pymoo\core\evaluator.py:69, in Evaluator.eval(self, problem, pop, skip_already_evaluated, evaluate_values_of, count_evals, **kwargs)
     65 # evaluate the solutions (if there are any)
     66 if len(I) > 0:
     67
     68     # do the actual evaluation - call the sub-function to set the corresponding values to the population
---> 69     self._eval(problem, pop[I], evaluate_values_of, **kwargs)
     71 # update the function evaluation counter
     72 if count_evals:
File ~\anaconda3\envs\Test\lib\site-packages\pymoo\core\evaluator.py:90, in Evaluator._eval(self, problem, pop, evaluate_values_of, **kwargs)
     87 X = pop.get("X")
     89 # call the problem to evaluate the solutions
---> 90 out = problem.evaluate(X, return_values_of=evaluate_values_of, return_as_dictionary=True, **kwargs)
     92 # for each of the attributes set it to the problem
     93 for key, val in out.items():
File ~\anaconda3\envs\Test\lib\site-packages\pymoo\core\problem.py:257, in Problem.evaluate(self, X, return_values_of, return_as_dictionary, *args, **kwargs)
    254     only_single_value = not (isinstance(X, list) or isinstance(X, np.ndarray))
    256 # this is where the actual evaluation takes place
--> 257 _out = self.do(X, return_values_of, *args, **kwargs)
    259 out = {}
    260 for k, v in _out.items():
    261
    262     # copy it to a numpy array (it might be one of jax at this point)
File ~\anaconda3\envs\Test\lib\site-packages\pymoo\core\problem.py:302, in Problem.do(self, X, return_values_of, *args, **kwargs)
    299     self._evaluate_vectorized(X, out, *args, **kwargs)
    301 # finally format the output dictionary
--> 302 out = self._format_dict(out, len(X), return_values_of)
    304 return out
File ~\anaconda3\envs\Test\lib\site-packages\pymoo\core\problem.py:357, in Problem._format_dict(self, out, N, return_values_of)
--> 357                 raise Exception(
    358                     f"Problem Error: {name} can not be set, expected shape {shape[name]} but provided {v.shape}",
    359                     e)
    361         ret[name] = v
    363 # if some values that are necessary have not been set
Exception: ('Problem Error: F can not be set, expected shape (34, 6) but provided (34, 18)', ValueError('cannot reshape array of size 612 into shape (34,6)'))
I understand that a certain array size is not appropriate for him, however I don’t know where exactly the problem is.
Here is my experimental data:
3e-05.csv (291.2 KB)
6.11e-05.csv (531.6 KB)
9e-05.csv (651.4 KB)
And here is the code I am using:
from CADETProcess.processModel import Inlet, GeneralRateModel, Outlet,TubularReactor, Cstr,LumpedRateModelWithPores
Q_ml_min = 0.5  # ml/min
Q_m3_s = Q_ml_min / (60 * 1e6)  # m3/s
V_tracer = 5e-8  # m3
starting_salt_conc = 1
component_system = ComponentSystem(['Salt', "Protein"])
binding_model = StericMassAction(component_system, name='SMA')
binding_model.adsorption_rate = [0, 1]
binding_model.desorption_rate = [0, (1/3.07545467548958)]
binding_model.steric_factor = [0, 1]
binding_model.capacity = 1185.185
binding_model.characteristic_charge = [0, 1.986895492003574]
# Unit Operations
inlet.flow_rate = Q_m3_s
column.length = 0.1
column.diameter = 0.0077
column.bed_porosity = 0.19
column.particle_radius = 3.4e-5
column.particle_porosity = 0.8333
column.axial_dispersion = 5.42572585e-08
column.film_diffusion = [5e-4, 6e-6]
column.c = [starting_salt_conc, 0]
column.cp = [starting_salt_conc, 0]
column.q = [starting_salt_conc, 0]
# Tubing1
tubing1 = TubularReactor(component_system, 'tubing1')
tubing1.length = 0.444
tubing1.cross_section_area = 4.418e-7
tubing1.axial_dispersion =  3.07515349e-05
tubing2 = TubularReactor(component_system, 'tubing2')
tubing2.length = 0.444
tubing2.cross_section_area = 4.418e-7
tubing2.axial_dispersion =  tubing1.axial_dispersion
uv_detector = Cstr(component_system, name='uv_detector')
uv_detector.V = 2e-9
uv_detector.c = [0,0]
flow_sheet.add_unit(tubing1)
flow_sheet.add_unit(tubing2)
flow_sheet.add_unit(uv_detector)
flow_sheet.add_connection(inlet, tubing1)
flow_sheet.add_connection(tubing1, column)
flow_sheet.add_connection(column, tubing2)
flow_sheet.add_connection(tubing2, uv_detector)
flow_sheet.add_connection(uv_detector, outlet)
def create_process(gradient_volume_length=30):
    process = Process(flow_sheet, f'{gradient_volume_length}')
    wash_start = V_tracer / Q_m3_s
    gradient_start = 1200
    concentration_difference = np.array([1000, 0]) - np.array([0, 0])
    process.cycle_time = gradient_start + (gradient_volume_length / Q_m3_s)
    gradient_duration = process.cycle_time - gradient_start
    gradient_slope = concentration_difference / gradient_duration
    _ = process.add_event('Load', 'flow_sheet.inlet.c', [500, 1], 0)
    _ = process.add_event('Wash', 'flow_sheet.inlet.c', [starting_salt_conc, 0], wash_start)
    'grad_start',
    [[starting_salt_conc, gradient_slope[0]], [0, gradient_slope[1]]],
    gradient_start
    return process
sec = SecondaryAxis()
sec.components = ['Salt']
sec.y_label = '$c_{salt}$'
for gradient_volume in [3e-5, 6.11e-5, 9e-5]:
    process = create_process(gradient_volume_length=gradient_volume)
    simulation_results.solution.outlet.outlet.plot(secondary_axis=sec)
def load_reference(file_name, component_index=1):
    data = np.loadtxt(file_name, delimiter=',')
    time_experiment = data[:, 0]*60
    c_experiment = data[:, component_index]
    reference = ReferenceIO(
        f'Peak {file_name}',
        time_experiment, c_experiment,
        component_system=ComponentSystem(["Protein"])
    return reference
def create_comparator(reference):
    comparator = Comparator(name=f"Comp {reference.name}")
    #comparator.add_difference_metric('Shape', reference,'outlet.outlet', components="Protein")
        'PeakPosition', reference,
        'outlet.outlet', components=["Protein"]
        'PeakHeight', reference,
    return comparator
comparators = dict()
for gradient_volume in [3e-5,6.11e-5, 9e-5]:
        process = create_process(gradient_volume)
        reference = load_reference(f"{gradient_volume}.csv")
        comparator = create_comparator(reference)
        comparators[str(gradient_volume)] = comparator
            comparator,
            name=f"Objective {comparator.name}",
            evaluation_objects=[process],  # limit this comparator to be applied to only this one process
lb=1e-10, ub=0.1,
transform='auto',indices=[1])
        comparator = comparators[evaluation_object.name]
            simulation_results,
            show=False
    optimizer.n_cores = 4
Your example doesn’t work for me either. I forgot to mention that.
I tried it both in the environment with the command you sent me here and via the release version.
It’s mysterious. I can reproduce the error on Linux with CADET-Process v0.8 but it works on Windows and Linux with the current Master branch. ¯\_(ツ)_/¯ I’m out of ideas what could be causing it on your end.
Can you join us at the next CADET Office Hours to discuss this further?
Hello Ronald,
thanks for the reply! :slight_smile:
Unfortunately I get the same error with the master branch.
It’s the following git command, isn’t it?
pip install git+https://github.com/fau-advanced-separations/CADET-Process.git@master
I create an environment in Anaconda Navigator (Python 3.10.13). Then I activate it and install Cadet with the standard command and then the master branch of Cadet Process with the above command. Then I open the file in this environment.
At least that worked for the problem with optimising the film diffusion.
Yes I could participate in the next Office hours. :slight_smile: but as the project I’m working is ending next week, my model should be ready by mid of next week, if possible :sweat_smile:
Hey Stefanos,
I can reproduce the error on master and it works on dev.
After isolating the issue a bit more I noticed, that pip doesn’t reinstall if you tell it to install from a different git branch. That might be why sometimes the behavior didn’t change even though different branches were installed. So, you can try to run, in your current environment, whichever that may be:
pip uninstall cadet-process
and that should fix the optimization bug.
Hey Ronald,
now it works perfectly! Many thanks! :slight_smile:
Hi there I had a question along a similar line. If I have 4 sets of experimental data for a single simulation (in this case 4 repeats of a dextran pulse),does the following below code make sense whereby I add a reference to my comparator for each tracer experiment (tracer_peak_1 to 4)?
Also if a situation arises where there are potentially 3 sets of optimal solution as some runs are minimised with 1 set of parameters and others with slightly different parameters, how does the output decide on the ‘optimal’ solution ?
Thanks
comparator.add_reference(tracer_peak_1)
comparator.add_reference(tracer_peak_2)
comparator.add_reference(tracer_peak_3)
comparator.add_reference(tracer_peak_4)
    'Shape', tracer_peak_1, 'outlet.outlet',)
    'Shape', tracer_peak_2, 'outlet.outlet',)
    'Shape', tracer_peak_3, 'outlet.outlet',)
    'Shape', tracer_peak_4, 'outlet.outlet',)
    comparator.plot_comparison(simulation_results)
optimization_problem = OptimizationProblem('porosity_Dax')
    name='column_axial_dispersion', parameter_path='flow_sheet.column.axial_dispersion',
    lb=0, ub=1e-3,
    transform='auto'
    name='column_total_porosity', parameter_path='flow_sheet.column.total_porosity',
    lb= 0, ub= 1
    transform='auto'
    comparator,
        simulation_results,
        show=False
optimizer.n_max_gen = 50
    optimization_results = optimizer.optimize(optimization_problem,use_checkpoint=False)
    optimizer.results.plot_objectives()
    optimizer.results.plot_figures
Hi Will,
that works. I’d personally use one line of code to add the references to stick to DRY principles.
for tracer_peak in tracers:
    comparator.add_reference(tracer_peak)
        'Shape', tracer_peak, 'outlet.outlet',
    comparator,
Also note that the references need unique names. But yes, that works.
Multi-objectives
Regarding:
In multi-objective optimization tasks you’ll get all individuals on the Pareto front from the optimization alorithm. Which of those you choose as your optimum is a complicated issue that depends on your specific problem. You could use the average over all objectives, or the geometric mean, or a desirability function. For your case, where multiple technical replicates are used together, I think one can argue for the average, but that’s just my opinion.
Note that CADET-Process also supports meta scores for multi-criteria decision-making.
