Simulation not running with 'LumpedRateModelWithoutPores' in latest CADET Process Dev
Hi There,
I recently installed the latest branch of CADET Process using the following commands from an environment with CADET-Process 8.0 previously installed.
pip uninstall cadet-process
When I run a simulation for the MSSMA using the general rate model , the simulation runs fine. (First Code below). However if I simply change the column model to lumped rate without pores the simulation doesn’t complete (second code below). Are people able to replicate this error as I can’t tell if this is an installation issue on my end. I have an environment with an older branch of CADET that seems to run fine but I was unable to run multi simulation optimisations using that so had to upgrade, as reported here.
GeneralRateModel CODE
from CADETProcess.processModel import MultistateStericMassAction
from CADETProcess.processModel import Inlet, GeneralRateModel,TubularReactor, Outlet
# Component System
component_system.add_component('Protein A')
component_system.add_component('Protein B')
# Binding Model
binding_model = MultistateStericMassAction(component_system,bound_states=[1,2,2], name='MSSMA')
binding_model.adsorption_rate = [0.0, 20,30,1,10]
binding_model.desorption_rate = [0.0, 3,30,3,3]
binding_model.conversion_rate = [0,100,10,100,100,100,100,100,100]
binding_model.characteristic_charge = [0.0, 2,4,6,8]
binding_model.steric_factor = [0.0, 2,2,2,2]
binding_model.capacity = 300.0
binding_model.reference_liquid_phase_conc = 1350
binding_model.reference_solid_phase_conc = 300
# Unit Operations
inlet.flow_rate = 0/(60*1e6)
inlet_2 = Inlet(component_system, name='inlet_2')
inlet_2.flow_rate = 0
V_column_void_in= TubularReactor(component_system, name='V_column_void_in')
V_column_void_in.length=0.003545772724442985
V_column_void_in.diameter=0.0215
V_column_void_in.axial_dispersion= 0
V_column_void_in.c=[150,0,0]
column.length = 0.25
column.diameter = 0.0115
column.bed_porosity = 0.37
column.particle_porosity = 0.33
column.axial_dispersion = 2.0e-7
column.film_diffusion = [2.0e-5, 2.0e-7, 2.0e-7]
column.pore_diffusion = [7e-5, 1e-9, 1e-9]
column.surface_diffusion = [0.0, 0.0, 0.0,0,0]
flow_sheet.add_unit(inlet_2)
flow_sheet.add_unit(V_column_void_in)
flow_sheet.add_connection(inlet_2, V_column_void_in)
flow_sheet.add_connection(V_column_void_in, column)
process.cycle_time = 19000.0
gradient_end = 15000.0
## Create Events and Durations
wash_start = 7500.0
gradient_start = 9500.0
concentration_difference = np.array([1350.0, 0.0]) - np.array([150.0, 0.0])
gradient_duration = gradient_end - gradient_start
gradient_slope = concentration_difference/gradient_duration
_ = process.add_event('load', 'flow_sheet.inlet.c', [150.0,((0.000016275/4.17)*2.36), ((0.000016275/4.17)*(4.17-2.36))],0)
_ = process.add_event('load_flow_on', 'flow_sheet.inlet.flow_rate',10/(60*1e6),0 )
_ = process.add_event('wash_flow_set', 'flow_sheet.inlet_2.flow_rate',0/(60*1e6),0 )
_ = process.add_event('load_flow_off', 'flow_sheet.inlet.flow_rate',0,wash_start,)
_ = process.add_event('wash', 'flow_sheet.inlet_2.c', [150.0, 0.0, 0.0], 0)
_ = process.add_event('wash_flow', 'flow_sheet.inlet_2.flow_rate',10/(60*1e6) , wash_start,dependencies=['load_flow_off'] )
    'grad_start',
    [[150.0, gradient_slope[0]], [0, gradient_slope[1]], [0, gradient_slope[1]]],
    gradient_start
_ = process.add_event('gradient_end', 'flow_sheet.inlet_2.c', [1350.0, 0.0, 0.0], gradient_end)
column.c = [150, 0, 0]
column.q = [binding_model.capacity, 0, 0,0,0]
_ = process.plot_events()
sec = SecondaryAxis()
sec.components = ["Salt"]
sec.y_label = 'csalt'
_ = simulation_results.solution.column.outlet.plot(secondary_axis=sec)
Lumped rate without pores code
from CADETProcess.processModel import Inlet, LumpedRateModelWithoutPores,TubularReactor, Outlet
# Component System
# Binding Model
# Unit Operations
column.total_porosity = 0.33
wash_start = 7500.0
    'grad_start',
    gradient_start
Hi George,
cannot reproduce, runs fine for me on dev, seems like an installation issue. I do realize that we need to make a new release for CADET-Process which contains a lot of the recent bug fixes and I hope we can do that rather sooner than later but it takes some time…
Cheers
Thanks Jo,
That’s good will have a look at the installation. Thank you !
