Error in Cadet process tutorial: Exercise 1: Combine nonbinding tracer with binding components
I trying to learn CADET-Process through tutorials.
I got an error.
Input
from CADETProcess.processModel import Langmuir
from CADETProcess.processModel import Inlet, LumpedRateModelWithPores, Outlet
# Component System
component_system.add_component('Dextran')
# Binding Model
binding_model = Langmuir(component_system, name='langmuir')
binding_model.adsorption_rate = [0, 0.02, 0.03]
binding_model.desorption_rate = [1, 1, 1]
binding_model.capacity = [100, 100, 100]
inlet = Inlet(component_system, 'inlet')
inlet.flow_rate = 2.88e-8
column.length = 0.1
column.diameter = 0.01
column.bed_porosity = 0.37
column.particle_porosity = 0.33
column.axial_dispersion = 2.0e-7
column.film_diffusion = [0, 1e-4, 1e-4]
outlet = Outlet(component_system, 'outlet')
process = Process(flow_sheet, 'dextran')
process.cycle_time = 1200
process.add_event('inject_on', 'flow_sheet.inlet.c', [1.0, 1.0, 1.0], 0)
process.add_event('inject_off', 'flow_sheet.inlet.c', [0.0, 0.0, 0.0], 50.0)
_ = simulation_results.solution.column.outlet.plot()
Output:
~\AppData\Local\Temp\1\ipykernel_18476\876603644.py in <module>
----> 1 from CADETProcess.processModel import ComponentSystem
      2 from CADETProcess.processModel import Langmuir
      3 from CADETProcess.processModel import Inlet, LumpedRateModelWithPores, Outlet
      4 from CADETProcess.processModel import FlowSheet
      5 from CADETProcess.processModel import Process
~\Anaconda3\lib\site-packages\CADETProcess\__init__.py in <module>
     25 from . import plotting
     26 from . import dynamicEvents
---> 27 from . import processModel
     28 from . import smoothing
     29 from . import solution
~\Anaconda3\lib\site-packages\CADETProcess\processModel\__init__.py in <module>
    121 from .flowSheet import *
    122
--> 123 from . import process
    124 from .process import *
    125
~\Anaconda3\lib\site-packages\CADETProcess\processModel\process.py in <module>
      5 from addict import Dict
      6 import numpy as np
----> 7 from scipy import integrate
      8 from scipy import interpolate
      9
~\Anaconda3\lib\importlib\_bootstrap.py in _handle_fromlist(module, fromlist, import_, recursive)
~\Anaconda3\lib\site-packages\scipy\__init__.py in __getattr__(name)
    214     def __getattr__(name):
    215         if name in submodules:
--> 216             return _importlib.import_module(f'scipy.{name}')
    217         else:
    218             try:
~\Anaconda3\lib\importlib\__init__.py in import_module(name, package)
    125                 break
    126             level += 1
--> 127     return _bootstrap._gcd_import(name[level:], package, level)
    128
    129
~\Anaconda3\lib\site-packages\scipy\integrate\__init__.py in <module>
     90
     91
---> 92 from ._quadrature import *
     93 from ._odepack_py import *
     94 from ._quadpack_py import *
~\Anaconda3\lib\site-packages\scipy\integrate\_quadrature.py in <module>
      6 from collections import namedtuple
      7
----> 8 from scipy.special import roots_legendre
      9 from scipy.special import gammaln, logsumexp
     10 from scipy._lib._util import _rng_spawn
~\Anaconda3\lib\site-packages\scipy\special\__init__.py in <module>
    770 from ._sf_error import SpecialFunctionWarning, SpecialFunctionError
    771
--> 772 from . import _ufuncs
    773 from ._ufuncs import *
    774
~\Anaconda3\lib\site-packages\scipy\special\_ufuncs.pyx in init scipy.special._ufuncs()
ValueError: numpy.ndarray size changed, may indicate binary incompatibility. Expected 96 from C header, got 88 from PyObject
Can someone please help me out in this.
Thanks
Hello Mohd,
that looks like a problem between scipy and numpy. A fresh python env (virtualenv or conda env) should solve this. We have a guide on good practices for that here. If that doesn’t help, let us know.
Best wishes,
Ron
Thanks @ronald.jaepel, it has been solved by upgrading Anaconda and reinstalling Cadet process.
