Error when completing simulation with polynomial flow ramp
Hi there,
I am having some issues with polynomial flow terms. I am trying to run a simple bind and elute experiment using the multistate steric mass action model in CADET-Process (dev). As part of this I am trying to incorporate some pump flow ramps. Currently I have just implemented a step ramp using the code at the bottom of this message and the simulation runs fine. However when I change one line of code
process.add_event('load_pump_ramp', 'flow_sheet.inlet.flow_rate', (5/(60*1e6)), 0)
to
process.add_event('load_pump_ramp', 'flow_sheet.inlet.flow_rate', [0,5e-9], 0)
to incorporate a linear ramp instead of a step, my events look good in that it appears to have had the desired effect but when i come to run the actual; simulation it doesnt complete and the kernel gets stuck on ‘busy’.
I tried updating the CADET dev branch by running ‘pip install git+https://github.com/fau-advanced-separations/cadet-process.git@dev’ , but this didn’t work either.
from CADETProcess.processModel import MultistateStericMassAction
from CADETProcess.processModel import Inlet,Cstr,TubularReactor,  LumpedRateModelWithoutPores, Outlet
# Component System
# Binding Model
binding_model = MultistateStericMassAction(component_system,bound_states=[1,2,2], name='MSSMA')
binding_model.adsorption_rate = [0.0, 100,100,100,100]
binding_model.desorption_rate = [0.0, 30,30,3,3]
binding_model.conversion_rate = [0,0,10,100,10,0,0,0,0]
binding_model.characteristic_charge = [0.0, 10,10,25,25]
binding_model.steric_factor = [0.0, 2,2,2,2]
binding_model.capacity = 300.0
binding_model.reference_liquid_phase_conc = 1500
binding_model.reference_solid_phase_conc = 300
# Unit Operations
inlet_2 = Inlet(component_system, name='inlet_2')
tubing= TubularReactor(component_system, 'tubing')
tubing.length=1
tubing.diameter=0.001
tubing.axial_dispersion=0.004
tubing.c=[150,0,0]
probe= Cstr(component_system, name='probe')
probe.c=[150,0,0]
probe.V=2e-07
connector= TubularReactor(component_system, name='connector')
connector.length=3e-3
connector.diameter=0.02
connector.axial_dispersion= 0
connector.c=[150,0,0]
mixer= Cstr(component_system, name='mixer')
mixer.V=1e-06
mixer.c=[150,0,0]
column.cross_section_area = 3.5e-4
column.length = (1.005e-6)/(column.cross_section_area)
column.total_porosity = 0.8
column.axial_dispersion = 1e-8
column.c = [150, 0,0]
column.q = [binding_model.capacity, 0,0,0,0]
conductivity= Cstr(component_system, name='conductivity')
conductivity.V=2E-07
conductivity.c=[150,0,0]
flow_sheet.add_unit(inlet_2)
flow_sheet.add_unit(probe)
flow_sheet.add_unit(tubing)
flow_sheet.add_unit(connector)
flow_sheet.add_unit(mixer)
flow_sheet.add_unit(conductivity)
flow_sheet.add_connection(inlet, tubing)
flow_sheet.add_connection(inlet_2, tubing)
flow_sheet.add_connection(tubing,probe)
flow_sheet.add_connection(probe,connector)
flow_sheet.add_connection(connector,mixer)
flow_sheet.add_connection(mixer,column)
flow_sheet.add_connection(column, conductivity)
flow_sheet.add_connection(conductivity, outlet)
process.cycle_time = 14*60
load_duration = 2.2*60
t_gradient_start = 4.5*60
grad_end=(10*60)
gradient_duration = grad_end - t_gradient_start
c_load = np.array([150, 0.00125,0.00125])
c_wash = np.array([150.0, 0.0,0])
c_elute = np.array([1350.0, 0.0,0])
gradient_slope = (c_elute - c_wash)/gradient_duration
process.add_event('load', 'flow_sheet.inlet.c', c_load,0)
process.add_event('load_flow_on', 'flow_sheet.inlet.flow_rate',  (65/(60*1e6)), 40)
process.add_event('buffer_flow_off', 'flow_sheet.inlet_2.flow_rate',  (0/(60*1e6)), dependencies=['load_pump_ramp'])
process.add_event('load_flow_off', 'flow_sheet.inlet.flow_rate',  0, load_duration )
process.add_event('buffer_flow_on', 'flow_sheet.inlet_2.flow_rate',  (10/(60*1e6)), 150)
process.add_event('wash', 'flow_sheet.inlet_2.c',  c_wash, 0)
process.add_event('grad_start', 'flow_sheet.inlet_2.c', c_gradient_poly, t_gradient_start)
process.add_event('grad_end', 'flow_sheet.inlet_2.c',c_elute, grad_end)
_ = process.plot_events()
if __name__ == '__main__':
    sec = SecondaryAxis()
    sec.components = ['Salt']
    sec.y_label = '$c_{salt}$'
    simulation_results.solution.column.outlet.plot(secondary_axis=sec)
Hey George,
thanks for reporting. I can reproduce the bug and will investigate further.
Cheers
Edit: bug is now tracked on Github.
Hey George,
we found the issue but it’s not trivial to fix. It has to do with consistent initialization when using polynomial flow rates. Currently, CADET-Core seems to struggle when the initial flow rate is 0. So until we have a proper fix, maybe you could start with a very small constant value for the ramp. It shouldn’t change the outlet profile by any substantial amount but it will make the simulation run. This way, you could at least continue until we have a proper solution.
process.add_event('load_pump_ramp', 'flow_sheet.inlet.flow_rate', [1e-12,5e-9], 0)
Amazing, thanks Johannes!
Hi Johannes,
Further to this I just updated my Dev branch by running
pip uninstall cadet-process
Now even the initial code I put up (without the ramp) seems to get stuck in the simulation and cannot complete. Do you get the same error or is this an installation issue on my behalf.
I can run examples fine using the MSSMA and this example fine. So it would seem to be a bug perhaps, but I’m not sure?
I think it could be related to this.
