Often times, we need to index certain parts of an array.
array = 0.1 * np.arange(24).reshape(4, 6)
print(array)
[[0. 0.1 0.2 0.3 0.4 0.5]
[0.6 0.7 0.8 0.9 1. 1.1]
[1.2 1.3 1.4 1.5 1.6 1.7]
[1.8 1.9 2. 2.1 2.2 2.3]]
To index these arrays, we use can use slicing. E.g., to index the first element in the first row:
array[0, 0]
0.0
and to index the entire first row:
array[0, :]
array([0. , 0.1, 0.2, 0.3, 0.4, 0.5])
Now, this becomes a bit more complicated when want to expose indexing in a method
def index_array(array, indices):
return array[indices]
E.g. indexing the first element does not yield the desired result:
index_array(array, [0, 0])
array([[0. , 0.1, 0.2, 0.3, 0.4, 0.5],
[0. , 0.1, 0.2, 0.3, 0.4, 0.5]])
And indexing entire dimensions using index notation raises an SyntaxError
index_array(array, [0, :])
File "<stdin>", line 2
SyntaxError: invalid syntax
Instead, we need to pass a slice:
help(slice)
Help on class slice in module builtins:
class slice(object)
| slice(stop)
| slice(start, stop[, step])
| Create a slice object. This is used for extended slicing (e.g. a[0:10:2]).
| Methods defined here:
| __eq__(self, value, /)
| Return self==value.
| __ge__(self, value, /)
| Return self>=value.
| __getattribute__(self, name, /)
| Return getattr(self, name).
| __gt__(self, value, /)
| Return self>value.
| __le__(self, value, /)
| Return self<=value.
| __lt__(self, value, /)
| Return self<value.
| __ne__(self, value, /)
| Return self!=value.
| __reduce__(...)
| Return state information for pickling.
| __repr__(self, /)
| Return repr(self).
| indices(...)
| S.indices(len) -> (start, stop, stride)
| Assuming a sequence of length len, calculate the start and stop
| indices, and the stride length of the extended slice described by
| S. Out of bounds indices are clipped in a manner consistent with the
| handling of normal slices.
| Static methods defined here:
| __new__(*args, **kwargs) from builtins.type
| Create and return a new object. See help(type) for accurate signature.
| Data descriptors defined here:
| start
| step
| stop
| Data and other attributes defined here:
| __hash__ = None
In this case, we would need to write:
sl = slice(None)
index_array(array, (0, sl))
While this works, it’s not really pretty.
Instead, we can use numpy’s s_ functionality.
index_array(array, np.s_[0, :])
