Hello everyone,
My simulation failed showing INIT_Q does not contain enough values for all bound state. Can I please ask what this means and how I could fix this error?
Here is my script:
from CADETProcess.processModel import (Inlet, Cstr, TubularReactor, Cstr, TubularReactor, Cstr, Outlet)
# Component System
component_system.add_component('Lysozyme')
# Binding Model (Value needs to be changed)
binding_model = StericMassAction(component_system, name='SMA')
binding_model.adsorption_rate = [0.0, 35.5] #need to fit curve
binding_model.desorption_rate = [0.0, 1000] #need to fit curve
binding_model.characteristic_charge = [0.0, 4.7] #need to fit curve
binding_model.steric_factor = [0.0, 11.83] #need to fit curve
binding_model.capacity = 1200.0 #need to fit curve
# Unit Operations
#Inlet
load = Inlet(component_system, name='load')
load.c = [0, 0.0012] #mM
wash = Inlet(component_system, name='wash')
wash.c = [0,0]
elute = Inlet(component_system, name='elute')
elute.c = [1000, 0]
Q = 1.43333e-07 #m^3/s
#Mixer
valve = Cstr(component_system, 'valve')
valve.V = 9.1e-7 #m^3 (need to be adjusted)
valve.flow_rate = Q
#Tubes(need to verify)
tau = 60
tube_diameter = 0.25/1000 #m
cross_section_area = 1.96e-07 #m^2
pfr = TubularReactor(component_system, 'pfr')
pfr.length = 0.138/1000000/cross_section_area #m
pfr.cross_section_area = cross_section_area
pfr.axial_dispersion = 0
#Membrane upstream dead volume
UpstreamDead = Cstr(component_system, 'UpstreamDead')
UpstreamDead.V = 0.269/2/1000000 #m^3
UpstreamDead.flow_rate = Q
#Membrane Matrix
tau = 0.1
mem_diameter = 3/100 #m
mem_length = 0.12/100 #m
mem_cross_section_area = 0.002826 #m^2
membrane = TubularReactor(component_system, 'membrane')
membrane.length = mem_length
membrane.cross_section_area = mem_cross_section_area
membrane.axial_dispersion = 0.0013
membrane.binding_model = binding_model
#Membrane downstream dead volume
DownstreamDead = Cstr(component_system, 'DownstreamDead')
DownstreamDead.V = 0.269/2/1000000 #m^3
DownstreamDead.flow_rate = Q
#Outlet
flow_sheet.add_unit(load)
flow_sheet.add_unit(wash)
flow_sheet.add_unit(elute)
flow_sheet.add_unit(valve)
flow_sheet.add_unit(pfr)
flow_sheet.add_unit(UpstreamDead)
flow_sheet.add_unit(membrane)
flow_sheet.add_unit(DownstreamDead)
flow_sheet.add_connection(load, valve)
flow_sheet.add_connection(wash,valve)
flow_sheet.add_connection(elute,valve)
flow_sheet.add_connection(valve, pfr)
flow_sheet.add_connection(pfr, UpstreamDead)
flow_sheet.add_connection(UpstreamDead, membrane)
flow_sheet.add_connection(membrane, DownstreamDead)
flow_sheet.add_connection(DownstreamDead, outlet)
process.cycle_time = 5.41*60 #s
load_duration = 0.06*60 #s
t_gradient_start = 0.1*60 #s
gradient_duration = process.cycle_time - t_gradient_start
gradient_slope = Q/(process.cycle_time - t_gradient_start)
process.add_event('load_on', 'flow_sheet.load.flow_rate', Q)
process.add_event('load_off', 'flow_sheet.load.flow_rate', 0.0)
process.add_duration('load_duration', time=load_duration)
process.add_event_dependency('load_off', ['load_on', 'load_duration'], [1, 1])
process.add_event('wash_off', 'flow_sheet.wash.flow_rate', 0)
process.add_event(
'elute_off', 'flow_sheet.elute.flow_rate', 0
process.add_event(
'wash_on', 'flow_sheet.wash.flow_rate', Q, time=load_duration
process.add_event_dependency('wash_on', ['load_off'])
process.add_event(
'wash_gradient', 'flow_sheet.wash.flow_rate',
[Q, -gradient_slope], t_gradient_start
process.add_event(
'elute_gradient', 'flow_sheet.elute.flow_rate', [0, gradient_slope]
process.add_event_dependency('elute_gradient', ['wash_gradient'])
if __name__ == '__main__':
sec = SecondaryAxis()
sec.components = ['Salt']
sec.y_label = '$c_{salt}$'
simulation_results.solution.column.outlet.plot(secondary_axis=sec)"
Thank you very much!
Kind regards,
Annie
