negative elution with Langmuir MPM
Fit Langmuir MPM parameters (offline) to match desired pH dependence. Use fit params to simulate bind, wash, and elute.
With certain combinations of MPM params (Ka, gamma, beta) , no binding occurs and during elution the outlet concentration dives negative.
import pandas as pd
#from numpy import trapezoid
# import cadet packages
from CADETProcess.processModel import LangmuirLDF
from CADETProcess.processModel import MobilePhaseModulator
from CADETProcess.processModel import Inlet, LumpedRateModelWithoutPores, Outlet
from CADETProcess.processModel import TubularReactor, Cstr
# setup experiment
mLmin_to_m3s = 60*1e6 # conversion
exp_flow = 8. # MV/min (mL/min)
Q = exp_flow/(mLmin_to_m3s) # convert to m^3/s
size_kDa = 150 # protein size
Qmax = 80 # mg/mL = g/L
Qmax_mMol = Qmax/size_kDa
# load and wash and elute volumes and pH
loadVol = 60.1 #42.3 #43.0 #60.1 # mL
washVol = 35.35 #33.9 #25.0 #34.8 # mL
eluteVol = 12. # mL
protein_c = 3.5 #3.7 #3.6 #3.5 # g/L
pH_bind = 7.5
pH_elute = 3.8
pH_b_H = 10**(-pH_bind)
pH_e_H = 10**(-pH_elute)
#print(pH_range)
#print(pH_b_H, 'bind')
#print(pH_e_H,'elute')
# calculating timepoints for experiment
total_vol = loadVol + washVol + eluteVol # mL
exp_time = total_vol/exp_flow*60 # seconds
sample_vol = loadVol
load_time = loadVol/(exp_flow/60.)
wash_time = washVol/(exp_flow/60.)
elute_time = eluteVol/(exp_flow/60.)
# CSTR and tubing lenght parameters from system fit
sys_CSTR_vol = 0.116e-6 # m^3
sys_tubing_len = 3.086 # m
# MPM fitting coefficients, keq = Ka * \frac{e^{\gamma*[H+]}}{[H+]^\beta}
# !!!!!! varying combinations of these parameters introduces numerical artifacts,
# no bidning, negative elution, etc.... how do I avoid this?
Ka = 1.0e-9 # similar issue with beta
gamma = 0
beta = 2.3 # 2.29 works, not 2.3
# create component system
component_system = ComponentSystem(['pH','protein'])
# binding model
binding_model = MobilePhaseModulator(component_system, name='MPM')
# setup system to use keq = a * np.exp[H+]/[H+]^\beta
binding_model.desorption_rate = [0.,1.]
binding_model.capacity = [0,Qmax_mMol]
binding_model.ion_exchange_characteristic = [0, beta]
binding_model.hydrophobicity = [0, gamma]
binding_model.adsorption_rate =[0,Ka]
binding_model.desorption_rate = [0,1]
binding_model.bound_states=[0,1]
binding_model.check_required_parameters()
# setup BWE buffers
# feed (mAb05)
feed.c = [pH_b_H,protein_c/size_kDa]
# wash (washout buffer)
wash = Inlet(component_system, name='wash')
wash.c = [pH_b_H,0]
# elute (elution buffer)
elute = Inlet(component_system, name='elute')
elute.c = [pH_e_H,0]
# device
device = LumpedRateModelWithoutPores(component_system, name='device')
device.length = 0.0193*8/100 # m
device.diameter = 2.85/100 # m
device.total_porosity = 0.55 # estimate
device.axial_dispersion = 1e-12 # near zero
device.binding_model = binding_model
device.discretization.ncol = 20 # i've gone up to 1000, still an issu
device.c = [pH_b_H,0]
#device.discretization.use_analytic_jacobian = False
# feed tubing
load_tubing = TubularReactor(component_system, name='load_tubing')
load_tubing.c = [pH_b_H,0]
load_tubing.length = sys_tubing_len # m #270/100
load_tubing.diameter = 0.75/1000
load_tubing.axial_dispersion = 1e-12
load_tubing.discretization.ncol=20
# outlet
outlet.solution_recorder.write_solution_bulk = True
# inlet CSTR
cstr_vol = 0.18e-6 # m^3
inlet_mixer = Cstr(component_system, name='inlet_mixer')
inlet_mixer.c = [pH_b_H,0]
inlet_mixer.init_liquid_volume = 1.0*cstr_vol # m^3
inlet_mixer.check_required_parameters()
#inlet_mixer.solution_recorder.write_solution_bulk=True
# outlet CSTR
outlet_mixer = Cstr(component_system, name='outlet_mixer')
outlet_mixer.c = [pH_b_H,0]
outlet_mixer.init_liquid_volume = 7.0*cstr_vol # m^3
outlet_mixer.check_required_parameters()
#outlet_mixer.solution_recorder.write_solution_bulk=True
# detector CSTR
detector_mixer = Cstr(component_system, name='detector_mixer')
detector_mixer.c = [pH_b_H,0]
detector_mixer.init_liquid_volume = 0.2e-6 # m^3 (0.2 mL detector volume)
detector_mixer.check_required_parameters()
# system CSTR
system_mixer = Cstr(component_system, name='system_mixer')
system_mixer.c = [pH_b_H,0]
system_mixer.init_liquid_volume = sys_CSTR_vol # m^3
system_mixer.check_required_parameters()
# now we create the Flow Sheet
flow_sheet.add_unit(feed)
flow_sheet.add_unit(wash)
flow_sheet.add_unit(elute)
flow_sheet.add_unit(load_tubing)
flow_sheet.add_unit(device)
flow_sheet.add_unit(inlet_mixer)
flow_sheet.add_unit(outlet_mixer)
flow_sheet.add_unit(detector_mixer)
flow_sheet.add_unit(system_mixer)
# connect components
flow_sheet.add_connection(feed, system_mixer)
flow_sheet.add_connection(wash, system_mixer)
flow_sheet.add_connection(elute, system_mixer)
flow_sheet.add_connection(system_mixer, load_tubing)
flow_sheet.add_connection(load_tubing, inlet_mixer)
flow_sheet.add_connection(inlet_mixer,device)
flow_sheet.add_connection(device, outlet_mixer)
flow_sheet.add_connection(outlet_mixer, detector_mixer)
flow_sheet.add_connection(detector_mixer, outlet)
# now we create the process, i.e., turning feed on, swap to wash buffer, same flow rate
process = Process(flow_sheet, 'breakthrough')
process.add_event('feed_on','flow_sheet.feed.flow_rate',Q,time=0)
process.add_event('feed_off','flow_sheet.feed.flow_rate',0,time=load_time)
# wash
process.add_event('wash_on','flow_sheet.wash.flow_rate',Q,time=load_time)
process.add_event('wash_off','flow_sheet.wash.flow_rate',0,time=load_time+wash_time)
# elute
process.add_event('elute_on','flow_sheet.elute.flow_rate',Q,time=load_time + wash_time)
process.add_event('elute_off','flow_sheet.elute.flow_rate',0,time=exp_time)
# cycle time
process.cycle_time = exp_time # seconds
#process.n_cycles = 1
# simluate the process
if __name__ == '__main__':
    process_simulator.time_resolution = 0.1
# save x- and y- axis information
x_axis_sim_init = simulation_results.solution.outlet.outlet.time
x_axis_sim_min = x_axis_sim_init/60.
y_axis_sim_init = simulation_results.solution.outlet.outlet.solution
y_axis_sim_init = y_axis_sim_init[:,1]
# plot simulation
plt.plot(x_axis_sim_min*exp_flow,y_axis_sim_init*size_kDa,'-b',label='BWE simulation')
plt.ylabel('g/L')
plt.xlabel('mL')
plt.legend()
environment.yml (7.56 KB)
Is there a way to decrease the time stepping to help with stability? Reading through some of the documentation it isn’t quite clear how to control some of these numerical instabilities when they arise
I believe I found the issue. When Keq > 1e8 the simulation does not run successfully. Why this is the case? I’m unsure… I’m assuming it has to do with floating point operations.
Is there a way I can make a conditional statement for the simulation in CADET-Process?
Something like:
If Keq > 1e8 then Keq == 1e8
I was quite curious about how this model would work for proA or other affinity systems with low pH elution. A really good way to understand how the isotherm model works is to calculate the equilibrium solid phase concentration q as a function of the liquid phase concentrations – c_p (protein) and c_0 (H+ ion). In this way, we can isolate the isotherm from the transport model and analyze the isotherm properties as a function of model parameters. In other words, we can play with the model parameters and directly assess what the impact will be.
First, let’s derive the single component MPM isotherm formalism in equilibrium form:
Start with single-component kinetic form
\frac{\mathrm{d} q}{\mathrm{~d} t}=k_{a} \exp({\gamma c_{0})} c_{p} q_{\max}\left(1-\frac{q}{q_{max}}\right)-k_{d} c_{0}^{\beta} q
At equilibrium, \frac{\mathrm{d} q}{\mathrm{~d} t}=0, therefore
0=k_{a} \exp\left({\gamma c_{0}}\right) c_{p} q_{\max}\left(1-\frac{q}{q_{max}}\right)-k_{d} c_{0}^{\beta} q
As a simplification, we use k_{eq} = k_a/k_d – dividing by k_d gives us
0=k_{eq} \exp\left({\gamma c_{0}}\right) c_{p} q_{\max}\left(1-\frac{q}{q_{max}}\right)-c_{0}^{\beta} q
Algebraic manipulation gives us the final equation
q = \frac{k_{eq}\exp\left({\gamma c_{0}}\right)q_{max}c_p}{k_{eq}\exp\left({\gamma c_{0}}\right)c_p+c_0^\beta}
c_0 is the modulator concentration – in this case it is the H+ concentration in mol/m^3 or mM. So, pH 7 would correspond to c_0 = 10^{-4}. We also need to make sure that q and q_{max} are in units of mmol protein / L solid phase. For example, a q_{max} of 50 g/L would be converted by dividing by molecular weight (kDa) and dividing by (1-\varepsilon_t), where \varepsilon_t is the total porosity (set to 0.9 in this example). After our calculations of q, we can convert all units back to their original state to help with interpretation.
Example isotherm:
Analysis of isotherm shapes allows us to define some appropriate (example) ranges of parameters k_{eq}, q_{max}, \gamma, and \beta.
q_{max} \in \left[0,100\right], a realistic range (in \mathrm{g/L})
k_{eq} \in \left[0,1000\right], a realistic range (in \mathrm{L/g})
\gamma \in \left[-100,0\right], to ensure that q decreases exponentially with increasing c_0. This parameter needs to be negative and cannot be neglected. Units are \mathrm{mM^{-1}}.
\beta\ \in [-0.5,0.5], this is a weird one – as \beta increases, q rapidly approaches
q_{max}. Conversely, as \beta decreases, q rapidly approaches 0. I would treat this as a fitting parameter or set it to zero to ignore it (this should be acceptable, I think).
Applying some reasonable estimates give us the isotherm, first at pH 7.0 – should expect favorable isotherm.
Then at pH 4.5 – should expect weaker affinity as compared to pH 7.0, but still maintaining capacity.
Then at pH 4.0 – should expect almost no more binding.
These isotherms follow the expected trends in proA. You can also see how critical \gamma is in the model since it entirely controls the pH dependence. \beta can be finely tuned in a narrow range – I suppose it might help with capturing subtleties, but definitely be careful with it.
You should be able to use these ranges for your simulations in CADET, just make sure to keep all the units consistent. For example, if you used c_0 in M you’d need to change your range for \gamma.
Hope this helps!
Also, to your previous comments: I think you are getting strange behavior because the parameters you specified lead to extremely high affinities which also can break the solver. If you stick to the ranges we derived, I don’t think you should have any issues with stability.
BTW, this is the isotherm I got with the inputs in your original post. You can see that it is unrealistically square, which breaks the solver. This is why it is so important to isolate the isotherm
model and study the model parameter relationships! Otherwise, it is quite difficult to understand what reasonable parameter values would even be.
As Scott mentioned, it could be because your value is too large, leading to solver instabilities. You could play around the solver settings and see if it addresses the issue.
As I mentioned in another post, the mobile phase modulator Langmuir does not modify q_{max}, which usually also changes as a function of pH. ACT isotherm modifies both q_{max} and K_{eq} as a function of pH.
