The simulation of the reaction works fine, and now I’m trying to implement a parameter scan with data we have measured. However, I am a bit lost in how to implement this, is there an example for this available, I could check out?
You can formulate this as an optimization problem, where you use an algorithmic approach to find a set of parameters that minimizes your objective function (residuals between experimental and simulated concentration profiles). There are many algorithms you can use but in essence you want to have your simulation and objective defined as function that the optimizer calls every iteration. Might be worth looking into CADET-Match as well.
Fortunately, this can also be done with CADET-Process nowadays.
@Stephan_Malzacher Should we have a call together? I think it might be easier to set this up together. We could still paste the final script here, once it works.
