I am performing simulations to investigate the impact of how changing column dimensions affects the efficacy of impurity removal, where the separation is governed by differential pore diffusion rates under strong binding conditions.
When changing column size, what is the appropriate way in CADET to maintain the same resolution in discretization? Presumably, the number of axial discretizations (mGrm.nCellsColumn) should scale linearly with column length (mGrm.columnLength). I am a bit unsure about the scaling of particle discretization (mGrm.nCellsParticle) with respect to column cross sectional area (mGrm.crossSectionArea). Should the number of particle discretizations scale linearly with cross sectional area or is this unnecessary?
Thanks for the help,
Scott
